Samsung ue49mu6120
This topic is closed.
  • paridelab
    • Nov 2021
    • 15
    • Italia
    #221
    Re: Samsung ue49mu6120
    Originally posted by lotas
    Try
    nothing makes the same defect
    • lotas
      • Jan 2016
      • 4598
      • Russia
      #222
      Try this one too.
      • paridelab
        • Nov 2021
        • 15
        • Italia
        #223
        Try this one too.
        with this you don't see the SMART TV logo, but it still makes the same defect
        • lotas
          • Jan 2016
          • 4598
          • Russia
          #224
          Then it turns out that the problem is in eMMC (it does not boot further).
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4326
            • Italy - Milan
            #225
            sorry i have seen reply late, the fault is in the panel for me, the same old fault, something shorted maybe in gate drivers, maybe in the panel small boards.. check if you have channels audio by putting in antenna cable and search for a good channel.. ** better to open own thread because of different model / symptom by the original thread!!! **
            • paridelab
              • Nov 2021
              • 15
              • Italia
              #226
              I don't think it's the panel because in addition to not hearing the audio, it stays blocked and won't even let me turn it off from the remote control
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                #227
                post the main board bn41 code
                it is not correct that one tv that pulses the status led is a tv with good standby software, sometimes not, already proven, so ask lotas or someone else for the correct spi file, then if it doesn't work try another file.
                • paridelab
                  • Nov 2021
                  • 15
                  • Italia
                  #228
                  I make a video and see if I can upload it to show you the precise defect
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4326
                    • Italy - Milan
                    #229
                    if you have no video then you can simply explain the blinking sequence, no need of video clip (?)
                    • paridelab
                      • Nov 2021
                      • 15
                      • Italia
                      #230
                      the LED does not flash, i plug it in and the TV starts by itself showing the SMART TV logo for about 2 seconds and then disappears, only the backlight stays on. If I then try to turn it off from the remote control or from the button it doesn't turn off
                      • lotas
                        • Jan 2016
                        • 4598
                        • Russia
                        #231
                        Well, another option, try this dump
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          #232
                          Sorry, maybe i have confused the post from someone else, with this type of defect the main software could be the culprit, don't waste time flashing the spi..
                          • lotas
                            • Jan 2016
                            • 4598
                            • Russia
                            #233
                            Yes, I already wrote that the problem is most likely in eMMC.
                            • paridelab
                              • Nov 2021
                              • 15
                              • Italia
                              #234
                              and the emmc I can not flash it? i have a tl866
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                #235
                                no, you need at least a T48
                                • torrephone19
                                  • Sep 2022
                                  • malaga
                                  #236
                                  Samsung UE49MU6445UXXC
                                  • lotas
                                    • Jan 2016
                                    • 4598
                                    • Russia
                                    #237
                                    • torrephone19
                                      • Sep 2022
                                      • malaga
                                      #238
                                      • son_goku1976
                                        • May 2023
                                        • 17
                                        • Italia
                                        #239
                                        Samsung ue40mu6400uxzt
                                        buonasera ..anche io ho lo stesso problema della 25w40 corrotta .....potete aiutarmi in qualche modo.....difetto riscontrato led standby spento staccando connettore collegamento main board solo retro illuminazione. Provato un dump trovato in rete , e' tornato standby ma non si accende .....vi ringrazio in anticipo .... allego dump originale 25q40
                                        MAINBOARD : BN94-12398F
                                        CODE: BN41-02568B
                                        MODEL: BN41-02568
                                        PANNELLO : BN95-03473A CY-KK040HGNV2H
                                        PANEL REV.00 BN96-39904B REV.01 BN39821C
                                        BN64-03429A
                                        • lotas
                                          • Jan 2016
                                          • 4598
                                          • Russia
                                          #240
                                          Re: Samsung ue40mu6400uxzt
                                          CODE: BN41-02568B
                                          MODEL: BN41-02568
                                          BN64-03429A
                                          Try.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
