Originally posted by Jeffaas
View Post
Samsung ue49mu6120
This topic is closed.
Samsung UE40MU6400UXZT
Hello, could you help me with my file please. Thank you.Attached FilesLast edited by toptib; 03-28-2024, 06:30 PM.
Originally posted by lotas View Post
Try.
I programmed the IC1604 eprom with the supplied firmware, with the status register byte 0X88 and 0X42.
Now the standby LED is on, If I try to turn it on the LED will turn off and come back on immediately. The main activates the power supply that supplies the 12 volts for 20 seconds and then returns to 8v and repeats this operation continuously.
Strangely I find that at the output of the Q211 I find only 1.35 v while in the 2 outputs of Q209 I regularly find 12v.
No voltage on the L400-UT.
Unfortunately I can't find the schematic of the main board to investigate any hardwre problems or if it's the firmware still faulty.
Is this dump original, or have you already tried to write something there without keeping it original?
If the dump is not his native one, then it may turn out the way it is now, and the protection against panel malfunction may work (in this case, you need to disconnect the lvds cable from the motherboard...)
You won't find circuit diagrams for modern motherboards; they are not freely available, even in service centers.Last edited by lotas; 03-29-2024, 07:40 AM.
Originally posted by lotas View PostIs this dump original, or have you already tried to write something there without keeping it original?
The dump is original, I tried to disconnect the flat lvds but the problem persists
The other one will not suit you, since others will already have different versions of the software, as you programmed your spi flash, you unsoldered it and programmed it through an adapter on a programmer or through a clothespin, you can read the dump again and post it here, I'll look at it after I signed up data.
