Samsung ue49mu6120
This topic is closed.
    Re: Samsung ue49mu6120
    Hello Lotas, the TV didn't update via the internet because I didn't configure the network, I did a factory reset to correct a blue cast but then it worked and only after a couple of hours it malfunctioned until it stopped completely. the stand-by LED does not turn on the backlight works by disconnecting the main power supply.
      Any other Lotas help?
        Hola colegas ayudenme a limpiar este bios de samung un40mu6103g - bn41 02568b
        https://drive.google.com/file/d/1NJV...usp=drive_link
        LINK del bios, no enciende, ningun led.
          Try.
            hello Lotas I ask you if it is possible to use one of these cards, some tv ue49mu6500u ue55mu6120 ue49mu6100kxzt instead of ue49mu6120kxzt
              You can use any one, since the panels (model, company) they (49 ") may be different, you will have to transfer or rewrite spi flash 25Q80 from the native board, it belongs to T-CON and all the settings of your panel are stored in it.
                Re: Samsung ue55mu6125KXZT
                Hi Lotas,
                please fix my dump original tv: not standby led no power
                ue55mu6125KXZT
                bn94-12644Q
                bn41-02568b
                Thanks Luigi
                  Originally posted by over83 View Post
                  Hi Lotas,
                  ue55mu6125KXZT
                  bn94-12644Q
                  bn41-02568b
                  Thanks Luigi
                  Try.
                    55mu6400 is not working, I tried 1 of the bios edited here and it worked. Do you mind if I use this working bios without editing the original bios? I attached the corrupt bios.
                      Try.
                        Originally posted by lotas View Post
                        Try.
                        Thanks a lot for your help. I have another faulty card. Can you repair the software here?
                        55MU7400
                          55MU7400
                          Try.
                            Try.
                            Test ok,Thank you very much.
                              Hello i need help, i have samsung UN49MU6103K, no power, led standby on, the psu work fine, i disconect from main, voltages ok, leds on. the problem is i dont have my dump, i erased accidentally my memory (ic1604 - 25Q40CL)
                              Sorry for my english
                                Hi Lotas,
                                ue55mu6225KXXC
                                bn94-12778U
                                bn41-02568b
                                MOEDL: KANT_M_BUILT_IN
                                  Originally posted by mano115 View Post
                                  Hi Lotas,
                                  ue55mu6225KXXC
                                  bn94-12778U
                                  bn41-02568b
                                  Try.
                                    Hi Iotas, i have Samsung UE49MU6205
                                    TV will not turn on, no standby light, power supply BN44-00807F
                                    When i remove PSU cable from main board I get back lights
                                    Main board BN41-02568B
                                    Can you help me ??
                                    Thanks for your contribution to our community
                                      Can you help me ??
                                      Hello, but your dump is working, try again with this dump, if it doesn't start with it, then the problem is different.
                                        Thanks lotas for your fast response
                                        I damaged the SPI chip, will order a new W25Q40CL and let you know the outcome
                                          Try.
                                          hello not funtion, light gray screen
                                          thank you
