Samsung ue49mu6120
This topic is closed.
  • son_goku1976
    • May 2023
    • 17
    • Italia
    #261
    Re: Samsung ue49mu6120
    if I leave the 25x40 the tv could give problems?
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #262
      I can’t say anything, I didn’t do such a replacement, I always managed to restore the old flash (that is, 25Q40).
      • son_goku1976
        • May 2023
        • 17
        • Italia
        #263
        ok
        • lotas
          • Jan 2016
          • 4753
          • Russia
          #264
          Originally posted by son_goku1976
          ok
          Well, you have a working dump, if you can write it to another flash, but look if you update the software on the TV, then this dump will no longer help you, you need to save it again, the one that was currently installed on the TV.
          • son_goku1976
            • May 2023
            • 17
            • Italia
            #265
            Re: Samsung ue40mu6400
            buonasera ...ho la necessita di resettare la tv da menu servizio , in modo da cancellare anche account sansung che non è mio .... ho provato a fare la procedura " INFO, MENU, MUTE, POWER." ma non va' ....potete aiutarmi ?
            • lotas
              • Jan 2016
              • 4753
              • Russia
              #266
              https://www.hardreset.info/devices/s.../service-mode/
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4464
                • Italy - Milan
                #267
                You must write english !!
                • son_goku1976
                  • May 2023
                  • 17
                  • Italia
                  #268
                  Thank you
                  • son_goku1976
                    • May 2023
                    • 17
                    • Italia
                    #269
                    forgive me .... since I write first with the translator , I did not notice to copy and paste the English translation .
                    • nebula
                      • Apr 2010
                      • 16
                      • Spain
                      #270
                      Hi, I have a Samsung UE55MU6500U with no standby LED, can you please check and correct my dump file if necessary?
                      OK the dump for UE55MU6400U worked for me!
                      Last edited by nebula; 05-31-2023, 09:04 AM. Reason: Found a working edited dump in the thread
                      • cickos
                        • Jun 2023
                        • 12
                        Originally posted by Alberto
                        Problem solved. I have put in a new main board and everything works fine.
                        Thanks for all the help and interest shown Lotas.
                        Thank you
                        Question, where did you buy the new Motherboard?
                        • cickos
                          • Jun 2023
                          • 12
                          Hi Lotas,
                          Begging for a help. Sony tv with curved LCD, mode: UN49MU7600FXZC, BN41-02568 mainboard . Chip: IC1604 Winbond 25Q40CLSIP, no power, no stand by, power supply get back screen lighting when motherboard disconected.
                          Tried to connect and read the IC with the clip on cable, without removing the IC, it didn't work . . . empty reading. Hopefully it didn't get damaged. The chip must be removed and attached to SH341A socket?
                          Have hot air station for chip removal. Any good advice, before I proceed?
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #273
                            Originally posted by cickos
                            Hi Lotas,
                            Rather, it is not Sony, but Samsung, but you need to remove it and read the data (dump).
                            • cickos
                              • Jun 2023
                              • 12
                              Thanks for your prompted response. Yes, it is Samsung btw. I did take off the IC without problem and have attached to the CH341 adapter using clamp on the cable (picture attached). AsProgrammer is active, get the red and yellow light (while reading), however the reading is empty like without the IC (picture attached)?
                              Do I make it wrong, can you please review the attached picture.
                              [ATTACH]302435[/ATT[ATTACH]
                              • lotas
                                • Jan 2016
                                • 4753
                                • Russia
                                #275
                                If the dump is damaged, there will be one FF up to x1000 at the beginning.
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #276
                                  Post here what you thought with 25Q40 (dump).
                                  • cickos
                                    • Jun 2023
                                    • 12
                                    It could be dump damage or the IC wasn't read.
                                    When I press the question mark button the IC is not recognized. I am not sure did i place the IC properly in the right section.
                                    Should it be placed in 25 or 24 section?
                                    • cickos
                                      • Jun 2023
                                      • 12
                                      Hi Lotas,
                                      Finally the AsProgramer identify the W25Q40CL, however the IC is empty. Did I delete it while experimenting with the software.
                                      So, I don't have native dump. Would you please give me some just to try, I have nothing to loose.
                                      Board is BN41-02568B, TV: UN49MU7600FXZS.
                                      THX in advance . . .
                                      • lotas
                                        • Jan 2016
                                        • 4753
                                        • Russia
                                        #279
                                        Here in this version (MU) the motherboard number and panel diagonal are not important, it is important that the software version is the same in SPI Flash (25Q40) and in eMMC.
                                        • cickos
                                          • Jun 2023
                                          • 12
                                          [QUOTE=cickos;1246789]Hi Lotas,
                                          Here are original dumps.
                                          Finally the AsProgramer identify the W25Q40CL, however the IC is partially empty.
                                          So, I have attached two original dumps save by AsProgramer and NeoProgramer. Would you please ttry to fix them?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
