Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4753
    • Russia
    #281
    Re: Samsung ue49mu6120
    [QUOTE=cickos;1246813]
    Originally posted by cickos
    Hi Lotas,
    Here are original dumps.
    Finally the AsProgramer identify the W25Q40CL, however the IC is partially empty.
    So, I have attached two original dumps save by AsProgramer and NeoProgramer. Would you please ttry to fix them?
    Board is BN41-02568B, TV: UN49MU7600FXZS.
    THX in advance . . .
    Try.
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #282
      Corrected, what is the result?
      • alex39t
        • Nov 2013
        • 51
        • greece
        #283
        iotas help please i have 55mu66700 the dump is that thank you for any help
        • lotas
          • Jan 2016
          • 4753
          • Russia
          #284
          Try.
          • alex39t
            • Nov 2013
            • 51
            • greece
            #285
            You are the teacher !!!
            • alex39t
              • Nov 2013
              • 51
              • greece
              #286
              Good day iotas i wish you to be good and healthy i want to ask you i have Samsung ue40es 6100 and make 5 blinks the voltage is ok maybe it is the bin do you know for this model?
              • lotas
                • Jan 2016
                • 4753
                • Russia
                #287
                Does the backlight work if you disconnect the motherboard from the power supply? And what firmware do you need?
                • alex39t
                  • Nov 2013
                  • 51
                  • greece
                  #288
                  Yes the backlight work but i ask if you know that the tv the24c512 want reprogramming what is your opinion?
                  • lotas
                    • Jan 2016
                    • 4753
                    • Russia
                    #289
                    Try it, but don't forget to save your dump.
                    • cickos
                      • Jun 2023
                      • 12
                      Hi Lotas,
                      I did re-programed the IC successfully, resoldered back onto the board.
                      No change, no any light on the power switch, nothing happens when power button get pressed. As I mentioned earlier, when main board disconnected from the Power Supply the Screen get lighted in full.
                      Any suggestion what to do next?
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        #291
                        Hi Lotas,
                        And status register 0x88, 0x42 you set and wrote down after writing my corrected dump, if you didn't set it, then the first time you turn it on, the firmware flies again and it will be the same.
                        • cickos
                          • Jun 2023
                          • 12
                          Yes, I did it. Will take the IC back to reading station to confirm the content.
                          • tonysk
                            • Aug 2016
                            • 6
                            • Italy
                            #293
                            Hi Lotas, my ue49mu6120kxzt doesn't turn on, if I unplug the power supply it turns on the backlight, the first part of the dump has many FFs and from what I've read in this forum I think the SPI is corrupted. The power went out and it happened. I also noticed that from the power supply module the 13v voltage is reduced to about 9v. I'm sending you the dump, can you please fix it? I tried to program the w25q40cl with my modified black CH341A as you recommended inserting the data you sent to iu3ohw (W25Q40CL@SOIC8 _FIX.rar) and I set the status register 0x88 and 0x42 but it didn't work.
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              #294
                              Try.
                              • tonysk
                                • Aug 2016
                                • 6
                                • Italy
                                #295
                                thanks Lotas i will try tomorrow
                                • cickos
                                  • Jun 2023
                                  • 12
                                  Hi Lotas,
                                  The IC was desoldered again and saved dump from it is attached.
                                  • lotas
                                    • Jan 2016
                                    • 4753
                                    • Russia
                                    #297
                                    Hi Lotas,
                                    This dump is good, not damaged.
                                    • cickos
                                      • Jun 2023
                                      • 12
                                      Hi Loats,
                                      THX having time for me.
                                      If I look at the dump, there are many YYYYY somewhere after first 1/3 of file? Is this normal?
                                      What else can be a problem?
                                      Do you have some other dump in your database which might work on my TV, I can try?
                                      TV model: UN49MU7600FFXZ, board: BN41-02568B
                                      • tonysk
                                        • Aug 2016
                                        • 6
                                        • Italy
                                        #299
                                        Hi Lotas, sorry I didn't tell you the result of the flash of the repaired dump right away, it worked and I turned on the tv to see if everything was ok, it worked fine for a couple of hours then the remote stopped working and turned off and turned on by itself then it stopped working, I reprogrammed the flash but it didn't work, I programmed another one removed from a samsung main board but even with that it didn't work, I checked that registers 88 and 42 were OK and that it was write protected, it doesn't work, any advice? Thank you again
                                        • lotas
                                          • Jan 2016
                                          • 4753
                                          • Russia
                                          #300
                                          Samsung accidentally did not update with new software via an Internet cable or via wi-fi, after it began to work, if it is updated, then the dump that I corrected will no longer fit the new software on your TV.
                                          What is not working now, is the standby LED on?
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
