Pioneer Elit 1120HD Power Supply issue?
  • Boyd1966
    • Mar 2017
    • 128
    Re: Pioneer Elit 1120HD Power Supply issue?
    I disconnected the X/Z and Y board and the power supply was still on. 3 blinking red lights and the constant red light on the board.
    • freakaftr8
      • Oct 2012
      • 3743
      OK so the power supply went into shutdown state again?
      This could be a control board issue possibly.
      • freakaftr8
        • Oct 2012
        • 3743
        Disconnect cable.from power supply to control board. This is a board with the red flashing lights on it. And then power up
        • Boyd1966
          • Mar 2017
          • 128
          Yes it went into shut down state.
          I then disconnected the control board and now the front panel light is constant red.
          The control board is the one in the picture here, correct?
          • freakaftr8
            • Oct 2012
            • 3743
            Yes however I'm not sure if that's going to Tell what's going on now that I think about it. I don't think the TV can achieve turn on command with that board disconnected.
            I know that Pioneer is very tempermental with voltages and shutdowns.
            Wondering the power supply lost a voltage. The only way to tell would be to measure voltages when you can
            • Boyd1966
              • Mar 2017
              • 128
              Do I plug everything back in before I test the voltage?
              • freakaftr8
                • Oct 2012
                • 3743
                1st do the voltage test with nothing plugged in and then write down your finding then plug everything in 1 by 1 do your voltage test again in write down the finding.
                • Boyd1966
                  • Mar 2017
                  • 128
                  Please look at the picture of the full opened back and circle the pins I need to probe. That will help a lot.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    , I don't have a computer where I can circle at the moment however you could probe P4 connector on power supply pin labebeled VSUS
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      This pin should have somewhere around 150 to 200 V DC it will be quick but you should see the voltage come up before the shutdown. What I would like to see is the voltage there as you plug in both x and y one at a time. You can reconnect the control board now before the test.
                      Also on the scan drive boards or known as the buffer boards you see the square style ICs all in line? Do any of them look burned or hole blown through?
                      • Boyd1966
                        • Mar 2017
                        • 128
                        This is what i plan to do. Plug in the control board. Leave the x and y boards unconnected and then test the p4 connector. Is that right? Then connect the y board and test again? Then connect the x board and test again?
                        Not sure if this will be done tonight but will try.
                        I would be really helpful if you could circle the pins I need to test and what setting on my voltmeter should be again....
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Thats correct. Ill get a picture to yiu but you will need to get me a picture of P4 connector. Pin labeled VSUS on that connector is where you will place the red probe. Black probe to chassis ground and 400vdc setting on volt meter. This is the sectioin where it has one solid line and one dotted line on the voltmeter
                          • Boyd1966
                            • Mar 2017
                            • 128
                            Here are the pictures of the connectors. The one with the drawn circles are on the power supply board. P3 goes to the Y board. P4 goes to the X board. The other picture is the connector on the Y board that goes to the P3 connector on the power supply board.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Good picture of that connector.
                              From the bottom you have SUSGND. 4th pin up from that is VSUS. This is the pin you are going to put the red probe on.
                              Don't worry about putting a probe on the wrong pin if by accident, youre not going to hurt anything. With the probe stuck into the pin and holding it there and the black probe on anywhere chassis ground, And you are voltmeter set to DC like I explained before , quickly watch the Volt meter screen and tell me what voltage you see.
                              Repeat this after you connect the x board up and then after you connect the Y board back up.
                              See if the voltage stays the same after every reconnection.
                              When you connect these boards 1 by 1 make sure the TV is unplug and you let it sit for at least 5 minutes before connecting each board up as there will be residual held voltage in the power supply that needs to drain off or the connector will arc.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                The reason we are doing this is because I am looking for a severe drop of this VSUS voltage within either the X or the Y board when connected in circuit. This will determine which board is causing the issue and if it is within the Y board it may be a shorted buffer board.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  This is the pin I want you to put the red probe on.
                                  • Boyd1966
                                    • Mar 2017
                                    • 128
                                    Great thanks! I will test this afternoon and let you know.
                                    • Boyd1966
                                      • Mar 2017
                                      • 128
                                      I did the testing.
                                      Y connector not connected - 220 or so then once it shut off went to 15
                                      Y connector connected - 220 or so then down to 15
                                      X connector connected - 220 or so then down to 15
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Ok at this stage I am going to assume that your power supply is putting out good voltages and your sustain boards are free of shorts. We need to look at the scan boards (buffer boards). There are two of them. Upper and lower. On this board near the connector that goes to it, there is a test pad labeled VH.
                                        Test this with your voltmeter same way you did the test with VSUS, except red lead on VH instead.
                                        Do this with both upper and lower.
                                          You would need to check VH to the floating-ground output and it should be roughly 150V
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • KYBOSH
                                            Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                                            by KYBOSH
                                            I have a floodlight-security camera that recently died on me.
                                            its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                                            Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                                            07-01-2024, 06:54 AM
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • lp20th
                                            Samsung Plasma TV Power Supply Issue
                                            by lp20th
                                            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                            11-28-2023, 10:28 AM
