With original Firmware on 25q40 and 25q80 tv is dead, for testing I flashed 25q40 and 25q80 with dump fined on line and tv is turned on with sound on when I pressed key on remote control..only defect is blue screen and nothing image...I reflashed 25q80 with original dump and 25q40 with your fixed file but tv won't turn on..same defect as 25q40 not fixed
Eeprom dump thread!
This is a sticky topic.
Because in the package of files hosted online are present 25q80 and 25q40. Now i have restored original 25q80 and fixed 25q40 but nothing, dead.Comment
You correctly wrote down dump 25Q40, wrote down the status register (0x88, 0x42), I already asked you, but I didn’t get an answer, without setting SR, the firmware will spoil again the first time you turn it on.Attached Filesif you find these attachements useful please consider making a small donation to the site
No when i writed firmware i have not setted register o 25q40 and 25q80. Now i rewrited firmware on 25q40 and setted register such as yours image. 25Q80 required same setting status register?
thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
I don't know how you write everything down and why nothing works for you, if it was a native dump, then I fixed it and it should work...
Procedure for recording:
1. First you need to delete all status registers (uncheck all the boxes and click "Write")
2. Erase the chip.
3. Write down the corrected dump and check what was written down.
4. Set the status register (0x88, 0x42), check the boxes and click "Write"
5. Everything is ready, solder the chip in place....
Read this thread: https://www.badcaps.net/forum/troubl...ung-ue49mu6120Comment
I think native original dump of 25q80 or 25q40 or all are incorrect because I re-write 25q80 and 25q40 following procedure of recording but nothing tv is dead. Only solution I think is a original dump with same panel.I don't know how you write everything down and why nothing works for you, if it was a native dump, then I fixed it and it should work...
2. Erase the chip.
I used sop8 adapter, but i think my original dump of 25q80 is demaged because;
After dump of 25q40 and 25q80 i flashed a files finded on line with this referece
samsung UE40MU6450U
Øàññè: kant_m_built_in
BN41-02568b
BN94-11958k
panel cy-kk040hgnv3v
and after flashed on 25q40 and 25q80 tv is turn on but screen is blu..the problems is my panel is cy-kk040hgnv3h not cy-kk040hgnv3v such as the firmware finded on line.
when i reflashed 25q80 and 25q40 tv wont turn on..is dead and after flashed 25q40 fixed from lotas..tv already wont turn on..a this point i think my original dump is not very well or correct.
i haven't solution.Comment
Pack 1.
25q40(0x88,0x42) from dump on line
25q80(0x98,0x2) from dump on line
tv turn on but blue screen
Pack 2.
Pack 1.
25q80(0x98,0x2) from my dump
Pack 3.
25q40(0x88,0x42) original or fixed by lotus
tv dead
Solutions?
I don’t know what you messed up there, you posted a faulty dump, I corrected it for you, if you wrote it down correctly, then everything should turn on, try this one for your panel...Pack 1.
Pack 2.
Pack 1.
Pack 3.
tv dead
Solutions?
please take your time and do things well, in pack3 there is no 8mbit dump, only the 4mbit one, post only the 8mbit from original dump.. lets see if it is drammatically empty, no correct connection (!!)... one lesson: on original dump reading EVER check the content with hex editor..Comment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
