Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
  • my2k2
    • Dec 2018
    • 25
    • philippines
    Good day to every one,
    I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
    Does anybody have an eeprom dump file? I really appreciate any help.
    Thanks in advance.
  • PowellSkier
    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
    by PowellSkier
    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
    06-17-2024, 11:43 AM
  • holidayyy
    meed of an EEPROM dump for a Sony Trinitron
    by holidayyy
    I am in desperate need of an EEPROM dump for a Sony Trinitron KV-9AD1 (Japanese model) or its North American equivalent, the KV-8AD10.
    micom - Mitsubishi M50439-715SP
    jungle - Sanyo LA7655N
    eeprom - OKI MSM16911RS
    If anyone happens to have this specific dump file or owns one of these models and is able to perform a dump for me, it would be a huge help.
    I've been searching for this for a long time, so any leads or assistance would be greatly appreciated. Thank you so much in advance!
    01-03-2026, 06:08 PM
  • Gjjgfj
    Dell C1295 / Sony 1-684-189-41 EEPROM Dump
    by Gjjgfj
    I'm re-celling a Dell Latitude 505 battery (C1295 / NF398 - 11.1V, 4700mAh) and accidentally corrupted the EEPROM. I used the wrong I2C settings on my programmer instead of Microwire, overwriting my factory code with garbage.
    I need a working donor .bin dump.
    Board Specs:
    • PCB: Sony 1-684-189-41
    • MCU: M37516 (Mask: G02)
    • EEPROM: 93C56
    ​Does anyone have a clean dump for this specific board? I know it's a long shot, but I’d appreciate any help!
    07-16-2026, 03:25 AM
  • Tomylee
    Harman Kardon making noise
    by Tomylee
    Hello, I have a Harman Kardon SB 30 CNTR soundbar that started making a squealing/grinding noise after some time of use. When I opened it, I found a bulging and leaking capacitor , which I replaced. Since then, the noise is now constant.
    I also noticed a resistor that is overheating, but I can’t identify the root cause of the problem.
    Could someone help point me in the right direction for troubleshooting?
    Here is the service manual I found:
    https://fr.scribd.com/document/88984...Service-Manual
    Thanks in advance 🙏...
    02-02-2026, 01:32 PM
  • AlexGsmMaster
    Eizo CS2740 eeprom dump, search.
    by AlexGsmMaster
    Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
    07-26-2025, 03:24 PM
