p14s Gen 2 thunderbolt eeprom dump
  • Whale linguini
    • May 2024
    • 30
    P14s Gen 2
    HT4B0/HP4B0/HT5B1/HT4B2
    NM-D352 Rev 1.0
    sn PF-35P15W
    Requesting thunderbolt dump
    also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12340
    Originally posted by Whale linguini
    P14s Gen 2
    NM-D352 Rev 1.0​
    sn PF-35P15W
    You have selected the wrong chip. The backup file is only 1 MB.
      • 21986
      Its the Thunderbolt firmware,its what he needs.
        • 21986
        P14s Gen 2
        NM-D352 Rev 1.0
        sn PF-35P15W
        Try this way
        https://www.badcaps.net/forum/troubl...33#post1679233
        • Whale linguini
          • May 2024
          • 30
          Originally posted by SMDFlea
          So when I look up the firmware on lenovos site, its giving me n34br05w.exe
          https://download.lenovo.com/pccbbs/mobiles/n34br05w.exe
          Intel Thunderbolt Retimer Firmware Version 1.2.29.0
          when I extract that, I do not get a .bin of any type, just a .cap.
          I tried to extract from that, and modify the header etc, but not sure if I did it correctly along with the final padding. I do recall seeing that it said somewhere in their t14s gen2 / t15s gen2 (I think it was t15s) and both pointed to the same fw download.
          I did blank the tbt eeprom and attempted to charge/power it on, which it did not. I did not fill it with 0s. I did verify that the eeprom was blank though. Should I go back and fill it with 0's and see if I can get it to power on after that?
          Edit: I guess I could try flashing that t14s dump in the thread you linked. Worst case, still doesn't work.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12340
            Change .CAP to .bin
            • Whale linguini
              • May 2024
              • 30
              Change .CAP to .bin
              Oh awesome thank you! What did I mess up doing this?
              Mine clearly didn't work, the original FW would still negotiate 20v, the modified cap I had tried to make it wouldn't do anything other than 5v. Which, I am not shocked my attempt failed. I just saw at the start of the bin looking at the hex, the cap had a bunch of junk, but seemed to align a few dozen lines down, so I tried to swap that part around.
              • Whale linguini
                • May 2024
                • 30
                oh I see why I am confused some. Have 2x posts going on. I thought this looked like it was lacking some thing
                https://www.badcaps.net/forum/troubl...derbolt-eeprom
