Eeprom dump thread!
This is a sticky topic.
  • Cf elettronica
    • May 2023
    • 10
    • Italy
    #1541
    Re: Eeprom dump thread!
    I could try with your version. Do you think it could work as well?
    • lotas
      • Jan 2016
      • 4899
      • Russia
      #1542
      Are you sure you have a problem in firmware 25Q40? You can try with my dump, just don't forget to keep your native dump!
      • Cf elettronica
        • May 2023
        • 10
        • Italy
        #1543
        I'm pretty sure it's a firmware issue. I only have ch341 programmer so i'm not able to flash the nand chip. I hope for the best or i will buy new tv. My readings into chip are most FF and some others unsignificant values. Any ideas for tv stuck on boot logo?
        • lotas
          • Jan 2016
          • 4899
          • Russia
          #1544
          In this chassis, flashing eeprom (24C256) often helps from freezing on the "Smart TV" log, if it does not help, then flashing the entire set (eMMC, Spi flash and Eeprom).
          • Cf elettronica
            • May 2023
            • 10
            • Italy
            #1545
            Just in case, please do you have also the eeprom file? My eeprom is labeled IC901 part number s24c51. Thank you
            • Cf elettronica
              • May 2023
              • 10
              • Italy
              #1546
              Do anyone has it please?
              • lotas
                • Jan 2016
                • 4899
                • Russia
                #1547
                Who, exactly what?
                • datriad
                  • Jan 2014
                  Does anyone have a dump For Vizio m60 d1 please
                  • sylves
                    • Apr 2016
                    • 10
                    • usa
                    #1549
                    I have a Samsung un55ku6290f that turns on as soon as I plug it up. There is backlight but that's it. No image or remote control functions at all. Could this be a bad bios.
                    • rott
                      • Jan 2015
                      • cyprus
                      #1550
                      Hi guys I'm looking for a firmware for a Samsung tv, model UE55J6200AWXXH
                      Board code BN41-02353B
                      Model : BN41-02353
                      Thank you
                      • sylves
                        • Apr 2016
                        • 10
                        • usa
                        #1551
                        Insignia NS-50L260A13
                        Here is a working spi flash for Insignia ns-50L260A13
                        • kyowee
                          • Aug 2014
                          #1552
                          I need flash dump for Sharp LC-60LE740E mainboard DKEYDF733FM65, QPWBXF733WJN2
                          • lotas
                            • Jan 2016
                            • 4899
                            • Russia
                            #1553
                            Dump what eeprom, nand...? Post your non-working dump here.
                            • kyowee
                              • Aug 2014
                              #1554
                              The nand I need (IC8401), i thought mentioning flash would be enough.
                              The non working one is not relevant, the guy from whom the set is, upgraded the TV from USB stick for a different main board (LC-60LE745U) so now the lvds isn't working.
                              • lotas
                                • Jan 2016
                                • 4899
                                • Russia
                                #1555
                                Link to dupm nand in private messages, try it.
                                • kyowee
                                  • Aug 2014
                                  #1556
                                  Thank You lotas!
                                  • xurplusxhop
                                    • Jan 2012
                                    • 36
                                    #1557
                                    I need working bin for HAIER LE32F6500 TV (TP.VST59S.PB813).
                                    Attached is my dump bin file. thanks
                                    • lotas
                                      • Jan 2016
                                      • 4899
                                      • Russia
                                      #1558
                                      xurplusxhop Your dump soft is live, try with the nvm cut out.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 957
                                        Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
                                        I would need help trying to fix this dump for a Toshiba 32L310U20 believed to be corrupt. I've searched everywhere, but could not find the firmware for this model.
                                        When plugged in, the TV just turns on the red light, then off, then flashes 5 times. No response to power on, just stays off. If I unplug, and plug back in, again same scenario.
                                        Many thanks, or if anyone has a working dump, it would be appreciated!
                                        • lotas
                                          • Jan 2016
                                          • 4899
                                          • Russia
                                          #1560
                                          Re: Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
                                          Try
