Eeprom dump thread!
This is a sticky topic.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #1741
    Hi can anyone help with the firmware for a Digihome 43287fhddledcntd which has a flashing red light mainboard 17mb97 23326815 ves430undl 2d n12 thankyou
    (can i update firmware using usb or do i remove the eeprom ic
    • lotas
      • Jan 2016
      • 4759
      • Russia
      #1742
      This is suitable USB firmware from DigiHome 43268FHDT2 17MB97 VES430UNDL-2D-N12
      27796459_MB97_1Ghz_Low_Sentor_V0452339_SVN_226609_D7L ?​
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #1743
        no download?
        • lotas
          • Jan 2016
          • 4759
          • Russia
          #1744
          no download?
          What's not loading? I’m asking if this firmware is suitable for you, if so, I’ll send you the link in a private message.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #1745
            sorry lotas i am still learning when it comes to firmware i am willing to give it a try if you can send me the file plus tell me the correct way to install it many thanks vince
            • ransoms.juggles
              • Oct 2023
              • 6
              Does anyone have the eeprom dump for the Vizio E461-A1 MB? Board 715G5560-M01-000-004X (T) TXCCB02K0390002T
              • MF ELETTRONICA
                • Jun 2024
                • 41
                • italia
                #1747
                CIAO RAGAZZI QUALCUNO HA IL DUMP DEL TV SAMSUNG UE40MU6400U mi servirebbe il file per eprom 25q40
                • lotas
                  • Jan 2016
                  • 4759
                  • Russia
                  #1748
                  Write in English. Someone else's dump won't help you, post your original, non-working dump here, I'll fix it for you.
                  • MF ELETTRONICA
                    • Jun 2024
                    • 41
                    • italia
                    #1749
                    OK THANK
                    • MF ELETTRONICA
                      • Jun 2024
                      • 41
                      • italia
                      #1750
                      ciao caro ecco il file grazie
                      • lotas
                        • Jan 2016
                        • 4759
                        • Russia
                        #1751
                        Try.
                        • MF ELETTRONICA
                          • Jun 2024
                          • 41
                          • italia
                          #1752
                          no nulla e sempre spento come prima
                          • cheeky2
                            • Dec 2012
                            • 337
                            • uk
                            #1753
                            I suggest you learn how to use google translate to put your language into English! This is an English language forum. Don't expect answers if you write in Italian.
                            • MF ELETTRONICA
                              • Jun 2024
                              • 41
                              • italia
                              #1754
                              ok sorry I was saying
                              no nothing works and it's always off like before​
                              • lotas
                                • Jan 2016
                                • 4759
                                • Russia
                                #1755
                                This is because after recording the dump, you need to set and write the status register (0x88, 0x42) and your dump was damaged again when you turned on the TV for the first time.
                                • MF ELETTRONICA
                                  • Jun 2024
                                  • 41
                                  • italia
                                  #1756
                                  sorry but the tv never turned on please how do I write the status register (0x88, 0x42) can you give me a solution so I can reprogram it again
                                  • MF ELETTRONICA
                                    • Jun 2024
                                    • 41
                                    • italia
                                    #1757
                                    great eeeeeeeeeeeeeeeeeeeeeeeee I managed to write registry status and it works aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa thank you you are great
                                    • ransoms.juggles
                                      • Oct 2023
                                      • 6
                                      lotas how to you fix the firmware? Is there a specific software you use to analyze it that flags bad hex? Sorry my ignorance, I’m still learning.
                                      • MF ELETTRONICA
                                        • Jun 2024
                                        • 41
                                        • italia
                                        #1759
                                        hello everyone x lotas sorry could you check if this is ok? and if so does this also need to set the reg status? thanks
                                        • MF ELETTRONICA
                                          • Jun 2024
                                          • 41
                                          • italia
                                          #1760
                                          hi lotas can you check this too? and one thing also this I have to change the reg status? could you tell me what I have to insert is it always the same 0x88 0x42 or is it different thanks I send you file
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
