Eeprom dump thread!
This is a sticky topic.
  • bhangal.05
    Canon LBP 2900 / 2900B EEPROM Dump (Formatter RM1-3078)
    by bhangal.05
    I am looking for a verified EEPROM .bin dump for a Canon LBP 2900B printer.
    Device: Canon Laser Shot LBP 2900 / 2900B Logic Board / Formatter Part Number: RM1-3078 EEPROM Chip: (Look at the 8-pin chip on your board and type its number here, e.g., 24C64, 93C46, or W25Q32)
    The Issue: Replaced the formatter board because the original was not recognized by USB. The new board takes print commands and the mechanics/lasers spin up normally, but it outputs a completely blank page. I strongly suspect the firmware inside the BIOS/EEPROM on this replacement...
    08-29-2026, 04:19 AM
  • holidayyy
    meed of an EEPROM dump for a Sony Trinitron
    by holidayyy
    I am in desperate need of an EEPROM dump for a Sony Trinitron KV-9AD1 (Japanese model) or its North American equivalent, the KV-8AD10.
    micom - Mitsubishi M50439-715SP
    jungle - Sanyo LA7655N
    eeprom - OKI MSM16911RS
    If anyone happens to have this specific dump file or owns one of these models and is able to perform a dump for me, it would be a huge help.
    I've been searching for this for a long time, so any leads or assistance would be greatly appreciated. Thank you so much in advance!
    01-03-2026, 06:08 PM
  • Gjjgfj
    Dell C1295 / Sony 1-684-189-41 EEPROM Dump
    by Gjjgfj
    I'm re-celling a Dell Latitude 505 battery (C1295 / NF398 - 11.1V, 4700mAh) and accidentally corrupted the EEPROM. I used the wrong I2C settings on my programmer instead of Microwire, overwriting my factory code with garbage.
    I need a working donor .bin dump.
    Board Specs:
    • PCB: Sony 1-684-189-41
    • MCU: M37516 (Mask: G02)
    • EEPROM: 93C56
    ​Does anyone have a clean dump for this specific board? I know it's a long shot, but I’d appreciate any help!
    07-16-2026, 03:25 AM
  • ElectricMan
    Need Firmware Dump (.BIN) for Insignia NS-32E400NA14 (Main Board: T.MS3393.71 / Panel: O320FWSE01)
    by ElectricMan
    I am working on an older Insignia NS-32E400NA14 LCD TV.
    The Problem: The TV will not turn on and only displays a solid red standby light.
    Troubleshooting done: I have successfully narrowed the issue down to a corrupted SPI flash chip. To test this, I swapped in a flash chip from a different, similar donor board. With that donor chip, the TV successfully powers on! However, because the donor chip came from a board configured for a different screen size and display interface, the resolution and display mapping are completely scrambled.
    09-04-2026, 06:41 PM
  • AlexGsmMaster
    Eizo CS2740 eeprom dump, search.
    by AlexGsmMaster
    Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
    07-26-2025, 03:24 PM
