Eeprom dump thread!
This is a sticky topic.
  • Willail
    • Jan 2016
    • 29
    • France
    #1881
    Originally posted by lotas
    Re: Eeprom dump thread!
    Токаї ltl-1902e hk-7050-ci-v3.04-b
    Hello Lotas,
    I need the dump for a Hyundai TV. 32inch
    Model 32D9A
    Main TP.S506. PB801
    Panel HKC Electronics HK315LEDM-0H08H AJ32T03
    Thank you for your help.​
    • lotas
      • Jan 2016
      • 4881
      • Russia
      #1882
      Originally posted by Willail
      Hello Lotas,
      Model 32D9A
      Main TP.S506. PB801
      There is a white tag on the bottom bar of the panel and it has the panel number written on it, what is it?
      • juan667134
        • May 2019
        • 29
        • peru
        #1883
        EPROM help me please
        television model; QN55Q70RAG
        motherboard model; BN41-02695A
        IC1502-IC1503-IC801- IC701 EMMC​
        • Willail
          • Jan 2016
          • 29
          • France
          #1884
          Hello Lotas,
          I send you the pictures of the panel number
ID:	3597496 Click image for larger version
ID:	3597502 Click image for larger version
ID:	3597498 Click image for larger version
ID:	3597499 Click image for larger version
ID:	3597500 Click image for larger version
          • lotas
            • Jan 2016
            • 4881
            • Russia
            #1885
            Try this one, it's a dump from Akai though, the remote might not fit...
            • lotas
              • Jan 2016
              • 4881
              • Russia
              #1886
              Here's more...
              • Willail
                • Jan 2016
                • 29
                • France
                #1887
                Hello Lotas,
                Thank you for the dump. I test the Akai dump but it doesn't work.
                It could possible that the firmware is not the same on board TP.S506.PB801 and TP.S506.PB818.
                I will test the 2nd file today. If i will send you the dump of my TV, could you fix it?
                Thank a lot
                • lotas
                  • Jan 2016
                  • 4881
                  • Russia
                  #1888
                  Hello Lotas,
                  Thank a lot
                  Try this dump, it's smaller in size, don't pay attention, write it down as is.
                  • Willail
                    • Jan 2016
                    • 29
                    • France
                    #1889
                    Hello Lotas,
                    Thank a lot for your file, the TV works again. You are the best !!!
                    • lotas
                      • Jan 2016
                      • 4881
                      • Russia
                      #1890
                      Hello Lotas,
                      OK!
                      • PNI E.
                        • Nov 2024
                        • 101
                        • Italy
                        #1891
                        Hello guys, I need the dump file for a Samsung ue55tu7170u someone can help me thanks, main board bn94 15314t
                        • porfyriadhs
                          • Oct 2023
                          • 80
                          • Greece
                          #1892
                          Hello am looking for firmware for Vestel tv 17mb171 32 inch tv . If anyone please help
                          • yokoono
                            • Apr 2010
                            • 515
                            #1893
                            1. What is the problem with the TV?
                            2. What is the TV model?
                            3. What is the panel code (VES315xxxx-xx-xx)?​
                            • lotas
                              • Jan 2016
                              • 4881
                              • Russia
                              #1894
                              4. Which firmware, firmware via USB or Dump eMMC?
                              • porfyriadhs
                                • Oct 2023
                                • 80
                                • Greece
                                #1895
                                Hello again need firmware via usb because the tv goes to boot loop. It says not enought space and I couldn't make anything. Tv is Toshiba model 32la2063dg/2.
                                  • 22179
                                  Please post pictures that can be read that don`t need rotating..
                                  • porfyriadhs
                                    • Oct 2023
                                    • 80
                                    • Greece
                                    #1897
                                    • porfyriadhs
                                      • Oct 2023
                                      • 80
                                      • Greece
                                      #1898
                                      VES315UNGB-L3-N53 screen model
                                      • cheeky2
                                        • Dec 2012
                                        • 339
                                        • uk
                                        #1899
                                        Looking for a working dump for the following Bush TV
                                        Model: BUSH LE-40GCL-A1
                                        Main: TP.SIS231.PT751
                                        Screen: V400HJ6-PE1​
                                        Attached is the faulty dump from the TV.
                                        Thanks for any help
                                        • lotas
                                          • Jan 2016
                                          • 4881
                                          • Russia
                                          #1900
                                          Thanks for any help
                                          Try this dump, but the panel is unknown.
