Eeprom dump thread!
This is a sticky topic.
  • Denis J
    • Jul 2021
    • 17
    • FRANCE
    #1401
    Re: Eeprom dump thread!
    Originally posted by lotas
    try
    Hello Lotas,
    I finally took the time to copy the 2 firmwares
    on the TV eeprom and everything went back in, the TV works again. I wanted to thank you a thousand times thank you
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      #1402
      Need help guys.. need dump files of TCL- 43D2913D LED TV attached is the original bin files. thanks in advance..
      • lotas
        • Jan 2016
        • 4497
        • Russia
        #1403
        The software in the dump is fine, try with a clean eeprom.
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          #1404
          Thanks a lot...
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            #1405
            Originally posted by KYBOSH
            I jumping into the firmware dump game and wasted to see if I could find the dump for a Samsung UN55MU800. The board number is CY-SM055FLLV6H. The chip is a WINBOND 25Q32JVIG. I did a quick search on this thread but didn't see anything. Perhaps I am not searching for it correctly?
            Thank you in advance!
            I finally got around to getting the dump!
            I the chip is a Winbond 25Q32JVIG but that chip is not specifically supported so I used W25Q32FV instead. Attached is the dump from that read. Would someone please have a look a fix it for me? If I didnt read it right please let me know what I did incorrectly and I will sort it out ASAP. Thank you !
            • Dawarr
              • Mar 2021
              • Gemany
              #1406
              hi,
              Medion/vestel
              X14903
              MD-32030
              49"
              BOARD: 17MB130P 23462734 ?V3(NOT SURE) ser.nr.7970800
              PANEL: VES490QNDL-2D-N31 (LG32)
              PS: 17ips72
              hope u rescue me.
              thank u in advance
              greetz
              • KYBOSH
                • Oct 2011
                • 581
                • Unknown
                #1407
                Got another one for you good people.
                Samsung UN55HU8550
                Bootloop at Startup "SmartTV" logo.
                I found 2 chips but I am not sure which one is the firmware so Im including both.
                Both were relatively close to the processor and both were marked with a marker at the factory.
                • lotas
                  • Jan 2016
                  • 4497
                  • Russia
                  #1408
                  Samsung UN55HU8550
                  If you have a bootloop, then the problem is in the eMMC firmware.
                  • KYBOSH
                    • Oct 2011
                    • 581
                    • Unknown
                    #1409
                    You are amazing Sir.
                    Thank you for the knowledge.
                    I will proceed accordingly.
                    Any hope for the panel dump in Post #1412?
                    • lotas
                      • Jan 2016
                      • 4497
                      • Russia
                      #1410
                      What is this firmware from the panel bar from? If so, then I haven't encountered any problems with them.
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        #1411
                        The dump is from the LCD Panel board of Samsung UN55MU800.
                        The display panel's number is CY-SM055FLLV6H.
                        The LCD panel board that this W25Q32JVIG resides on is BN96-41982A (see attached picture).
                        It is believed that there is an issue with it as the panel is not getting picture but the mainboard is believed to be good and there are no shorted components on the LCD panel board.
                        Thank you very much!
                        • lotas
                          • Jan 2016
                          • 4497
                          • Russia
                          #1412
                          There is nothing special in it and does not affect the image (correction of broken pixels is set at the factory for each panel and the contents are different for them), the T-con firmware can be responsible for the image, it is located on the 25Q80 motherboard.
                          • KYBOSH
                            • Oct 2011
                            • 581
                            • Unknown
                            #1413
                            I very much appreciate the guidance Lotas. It was suggested that this maybe a source of my No Picture problem.
                            Are you able to check my EEPROM dump in post #1414 to see if it is in order?
                            That would be another unknown i cam eliminate as a source of my issues.
                            • cheeky2
                              • Dec 2012
                              • 336
                              • uk
                              #1414
                              I have this corrupted Blaupukt 32 147I-GB-5B-HBKUP-UK screen LVW320SSDX E2 V1 main TP.MSD309.BP85 C12415 that will not turn on could someone have a look at it for me and see where the corruption is please? I see Lotas has the relevant skills to do this.
                              I am going to try and work out how to do this in future so any tips would be appreciated in working it out as I try to understand and resolve problems myself.
                              • lotas
                                • Jan 2016
                                • 4497
                                • Russia
                                #1415
                                Hello, there was no time, dump is ready (there was a problem in it), try it.
                                • cheeky2
                                  • Dec 2012
                                  • 336
                                  • uk
                                  #1416
                                  Thanks Lotas. It will take a few days before I can try it. I will let you know how it goes when it's done.
                                  Regards Anthony
                                  • lotas
                                    • Jan 2016
                                    • 4497
                                    • Russia
                                    #1417
                                    Ok.
                                    • luzmina
                                      • May 2015
                                      • 17
                                      • US
                                      #1418
                                      I need bin file for TV Westinghouse Model: DWM32H1G1 using chip MSD3393LUM, attached is the broken bin file, Thanks
                                      • lotas
                                        • Jan 2016
                                        • 4497
                                        • Russia
                                        #1419
                                        What is the motherboard number?
                                        • luzmina
                                          • May 2015
                                          • 17
                                          • US
                                          #1420
                                          St3393lup-a1h
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
