Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    On the programmer - erase, write down my dump, check and solder back to the motherboard.
      thanks for all your help
      now i have same fault
      so i will order a new spi chip and reload your dump
      it could simply be the chip is faulty
      all the supplies are good and clean
      i will report back
        If you saved your old dump before updating via usb, then you could know for sure whether the problem is in the firmware or not. Always before experimenting with your firmware, you need to make a backup of your dumps, so that if something is wrong, then they can be returned back.
          i now understand thanks for advice
            hi can anyone help with dump for philips 65PUS6162,05
            MB NUM:715G8709 MOE BOO 005N
            maybe the same as 55inch model?
            chassis TPM17.7E LA
              Chassis TPM17.7E LA or TMP17.7E LA ?.
                im confused?
                  sorry its TPM i must remember to wear my glasses
                    jimbofz: in those Chinese tvs, if the only issue is no sound the problem is the sound amp, make sure the sound IC has power before replacing it, if no sound after replacing it then the issue is the microcomputer.
                      chassis TPM17.7E LA
                      Here the error is not "O", but "0" correctly so 715G8709 M0E B00 005N
                        Software pkg
                        https://files.fm/u/eqd8g2ejw
                          Originally posted by lotas View Post
                          Try
                          many thanks
                          new spi chip with your dump works fine on technika
                            Originally posted by yokoono View Post
                            many thanks for this dump
                            im having problem writing extracted .bin file to chip
                            my new chip is :st m24128b wmn6p
                            the ch341a programmer only has up to
                            m24c64 when you select manufacturer st from list
                            when i select atmel at24c128bi get
                            "chip memory with contents disagreement " message
                            can you advise please
                              What program do you have for CH341A?
                                version 1.30
                                  version 1.30
                                  Install this program
                                  https://www.badcaps.net/forum/showpo...7&postcount=51
                                    Or this
                                      can you help looking for firmeware for a hisense h55m3300 can anybody help
                                        ok installed siberia prog
                                        LOOKS GOOD DESIGN ,
                                        connected ch341a with new blank eeprom soldered on : m24128 bwmn6p
                                        changed language to english
                                        entered
                                        ;EEPROM 24XX
                                        24C128
                                        i get:recognition error?
                                        any ideas ?
                                          Do you correctly insert it (eeprom) into the programmer? Post a photo of how it's installed.
