Eeprom dump thread!
This is a sticky topic.
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #1441
    Re: Eeprom dump thread!
    can anyone help with eeprom dump for
    TECKNIKA LCD32-56 board :cv306 h-x 27t1005a
    contacted umc, they supplied incorrect f.w: cv306_merge.bin
    now menus wont come up ,
    (original fault loss of sound after 3 seconds)
    • lotas
      • Jan 2016
      • 4899
      • Russia
      #1442
      Do you still have the native, not working dump?
      • jimbofz
        • Apr 2013
        • 539
        • uk
        #1443
        yes i have the cv306-merge.bin file from umc
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #1444
          heres the bin file from umc
          sorry when i try to upload .bin file i get invalid file message?
          • lotas
            • Jan 2016
            • 4899
            • Russia
            #1445
            No, I need to dump his old native (not working), which was before the update.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              #1446
              ok i will remove eeprom
              and read and save the contents .using my ch341
              but how do i upload the bin file on this forum ?
              as .bin files cant be uploaded?
              • lotas
                • Jan 2016
                • 4899
                • Russia
                #1447
                The file (Dump), which you now want to read, has already been updated with an incorrect "cv306-merge.bin" file, but I need it before the update, the bin file can be packed into winrar.
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  #1448
                  removed spi read and packed to winrar
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #1449
                    heres the umc supplied MERGE ..bin
                    heres hoping you can help thanks
                    • lotas
                      • Jan 2016
                      • 4899
                      • Russia
                      #1450
                      How do you read dump? your dump size is very large, I asked you that you have an old dump left, the one that you did not update with the update.
                      • jimbofz
                        • Apr 2013
                        • 539
                        • uk
                        #1451
                        sorry my mistake .i did not read the data before the update
                        the tv was fine but no sound ,after the umc update no menu or sound
                        i read the spi using ch341a the spi number is 25q328vsig
                        the nearest on the list of programmer ,i used w25q256fv
                        does that matter ?
                        im still learning as ive only used the ch341a a few times
                        i did try the update a few times ,could that be why the dump is larger than normal?
                        • lotas
                          • Jan 2016
                          • 4899
                          • Russia
                          #1452
                          Is it native spi flash? There should be 25Q32 or 25Q64, but not like 25Q256.
                          And if there is no sound, this does not mean that the matter is in the firmware, there may be another problem in the hardware.
                          Do you have such a mother?
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            #1453
                            this ic is the original
                            it does not look like it was changed in the past
                            its possible that the spi number is 25q32"b"vsig
                            not 25q328vsig
                            as the markings are so small ive used two magnifiers to get the best chance of accurate reading
                            the pic looks similar but not the same
                            the board markings are CV306H-X
                            then the second number is 27T1005A D
                            I should add the original fault was :the sound would be ok for a few seconds
                            • lotas
                              • Jan 2016
                              • 4899
                              • Russia
                              #1454
                              Count again, like 25Q32, and lay it out again, the size should be 4Mb.
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                #1455
                                here it is fingers crossed
                                • lotas
                                  • Jan 2016
                                  • 4899
                                  • Russia
                                  #1456
                                  Try
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #1457
                                    thanks lotas
                                    should i erase the spi with ch341a first?
                                    then load the fresh dump to it ?
                                    or should i refit the chip in tv then use usb to write fresh dump
                                    • lotas
                                      • Jan 2016
                                      • 4899
                                      • Russia
                                      #1458
                                      On the programmer - erase, write down my dump, check and solder back to the motherboard.
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        • uk
                                        #1459
                                        thanks for all your help
                                        now i have same fault
                                        so i will order a new spi chip and reload your dump
                                        it could simply be the chip is faulty
                                        all the supplies are good and clean
                                        i will report back
                                        • lotas
                                          • Jan 2016
                                          • 4899
                                          • Russia
                                          #1460
                                          If you saved your old dump before updating via usb, then you could know for sure whether the problem is in the firmware or not. Always before experimenting with your firmware, you need to make a backup of your dumps, so that if something is wrong, then they can be returned back.
