T-CON Check Spreadsheet
  • perelandra
    • Sep 2010
    • 10
    Re: T-CON Check Spreadsheet
    here's the data for the 3 boards I've tried:
    t-con #1
    AVDD 16V
    VCOM 6.5V (labeled VCOM2 ?)
    VGH 27V
    VGL -8V
    VGMA1 15.4V
    VGMA2 15.4V
    VGMA3 13.3V
    VGMA4 12V
    VGMA5 11V
    VGMA6 10.5V
    VGMA7 10V
    VGMA8 10V
    VGMA9 9.75V
    VGMA10 12.9V
    VGMA11 7V
    VGMA12 15V
    VGMA13 14.9V
    VGMA14 13.9V
    VGMA15 14.9V
    VGMA16 13.5V
    VGMA17 14V
    VGMA18 13.9V
    VGMA19 12.9V
    VGMA20 12.5V
    VGMA21 12V
    VGMA22 11.5V
    t-con #2
    AVDD 16V
    VCOM 2.8V (labeled VCOM2 ?)
    VGH 26V
    VGL -7V
    VGMA1 15V
    VGMA2 16V
    VGMA3 12.9V
    VGMA4 11.5V
    VGMA5 10.9V
    VGMA6 10V
    VGMA7 9.8V
    VGMA8 9.7V
    VGMA9 9.2V
    VGMA10 7.5V
    VGMA11 7V
    VGMA12 6.9V
    VGMA13 6.3V
    VGMA14 5.9V
    VGMA15 4V
    VGMA16 4V
    VGMA17 3.1V
    VGMA18 3.3V
    VGMA19 3V
    VGMA20 2V
    VGMA21 0.01V
    VGMA22 0.01V
    t-con #3
    AVDD 16V
    VCOM 6.3V (labeled VCOM2 ?)
    VGH 27V
    VGL -7V
    VGMA1 2V
    VGMA2 7V
    VGMA3 7V
    VGMA4 7V
    VGMA5 7V
    VGMA6 7V
    VGMA7 7V
    VGMA8 7V
    VGMA9 7V
    VGMA10 7V
    VGMA11 7V
    VGMA12 6.8V
    VGMA13 6.8V
    VGMA14 13V
    VGMA15 12.3V
    VGMA16 10.3V
    VGMA17 10.5V
    VGMA18 11.3V
    VGMA19 12V
    VGMA20 13V
    VGMA21 16V
    VGMA22 16V
    • perelandra
      • Sep 2010
      • 10
      budm, I seem to be the only one active in this thread, but not sure you meant your reply for me? There is no heat transfer pad on the AS15 on this board.
        I am surprised that it did not have one on the AS15.
        Does the IC too hot to touch by fingers?
        • perelandra
          • Sep 2010
          • 10
          Hi budm, thanks for the help. I'll post an image of the board. This one (#3) does get screaming hot, and right away. Too hot to hold your finger on it. The last one I tested (#2) did not, so I didn't think to check this one until you asked.
          • perelandra
            • Sep 2010
            • 10
            It's an AS15-F, if that matters?
            • michael dranfield
              • Jan 2016
              • 232
              • England
              #26
              There is a very simple way to test this chip, leave the set on for 10 mins and if the chips faulty it will be hot to touch, it should run stone cold .
              • perelandra
                • Sep 2010
                • 10
                #27
                Thanks Michael, it was burning hot within seconds.
                  I just replaced the burnt out AS15 on the T-CON board on 46" SAMSUNG, power it up without the ribbon cables between the LCD panel and the T-CON, no heat no smoke, unplug the power and connect all the ribbon cables, applied the power and turned on the TV, in less than a minute the IC smoked!
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Originally posted by tom66
                    v1.1
                    Bug fix:
                    - handle symmetry curve check >18 items (typo)
                    - new symmetry display
                    - formatting improvements
                    - added "v1.1" to title
                    Tom66 nice piece of work. I'm sure those who repair TV's on a regular bases will find this invaluable.
                    • perelandra
                      • Sep 2010
                      • 10
                      #30
                      Tom66, your spreadsheet tool is great! Very helpful!
                      I'm sorry for tagging onto your thread, but I thought that's what I was supposed to do. Although I've been lurking on badcaps for over 5 years I wasn't allowed to start a new thread. Guess I jumped through the right hoops, now little status deal says I can. Still don't have edit/delete privileges so I can't remove.
                      Guessing that starting a new thread now with my issues would be wrong, so I hope the mods will see this and advise?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4943
                        • New Zealand
                        #31
                        Could a bad panel cause that?
                        -David VanHorn
                          Yes, it is the bad panel that takes out the AS15.
                          I took the T-CON board out and replace the IC again but install the T-CON on anther SAMSUNG same model and panel without any problem, so now I have spare power supply, T-CON, and Main board for the next repair works.
                          • perelandra
                            • Sep 2010
                            • 10
                            #33
                            So, am I correct in assuming that if I do not connect up the ribbon cables (from t-con to panel) I will not damage a t-con board, if I indeed have a bad panel?
                            Last "used" (supposedly tested by seller) t-con board I tired I did exactly this (no panel connections) and AS15 was screaming hot from the get-go (immediately after power on), and bad voltage readings too. Just want to make sure nothing coming through the LVDC could be taking out the t-con boards.
                            • grumpy_one
                              • Sep 2015
                              • 7
                              • australia
                              #34
                              I hope I'm not interrupting this thread, but I want to thank tom66 for all that he has revealed about AS15 ICs. It has been extremely helpful to me. I was just given a Samsung LA40B650 with a solarized picture (both picture and menu affected). Shopjimmy's videos assured me that I needed to look at the T-Con, and with tom66's posts I went straight to the AS15-U. It got warm after a couple of minutes running, though I could hold my finger on it without pain. So I checked the VGMA test points:
                              VG1 15.54
                              VG2 15.19
                              VG4 12.88
                              VG6 10.99
                              VG8 10.26
                              VG10 7.93
                              VG11 7.80
                              VG12 7.08
                              VG13 6.87
                              VG15 5.87
                              VG17 11.92
                              VG19 2.93
                              VG21 0.70
                              VG22 0.41
                              Based on tom66's posts, I mentally connected the warm AS15-U, and the very odd voltage on VG17, and decided I needed a new AS15-U. Unfortunately fate conspired against me - I then bought a heat gun on ebay, and when it arrived found it was defective. Seller would not give a refund until I posted it back to China for evaluation, so while I was waiting I bought a new T-Con board and fitted it. Great picture, no solarization. So, please chalk up one more win for tom66's posts.
                              If I eventually get the ebay situation sorted out I'll get a heat gun that works and replace the AS15-U on the original T-Con board - but this forum has already made it easy to repair what was previously a throw-away TV. Thanks everyone.
                              • steves7839
                                • Nov 2014
                                • 200
                                v1.1
                                Bug fix:
                                Cells B21 and B22 on the "Detailed..." tab have duplicate cell references to the Input tab. Easy fix but the reference should be sequential.
                                Question? Is there a generic way to find these test points, particularly VGMAn?
                                I'm fixing a Sony T-Con board.
                                • Ronald49
                                  • Dec 2016
                                  • 3
                                  • Nederland
                                  #36
                                  Thank you for this usefull tool!
                                  I am testing my v520h1-c06 TCON. It doesnt have a AVDD test point, but a VDD and VDA. Which one do i need to fill in the spreadsheet?
                                  It's for the Samsung LE40N87BD, problem is image persistence.
                                  • Schaefer
                                    • May 2018
                                    • Netherlands
                                    #37
                                    Thank you, this is very helpful
                                    • Brian10m
                                      • Jul 2017
                                      • 4
                                      • United Kingdom
                                      #38
                                      Tried the updated software V1.1 in excel 2016 32-bit, all seems ok. well done, nice job.
                                      • Wilderone
                                        • May 2018
                                        • 76
                                        Nice work, Thanks for sharing Tom66
                                        • nobbnobb1
                                          • Nov 2019
                                          • 76
                                          Thanks for this spreadsheet! I am diagnosing a blank screen issue on a Sony KLV-46W400A and these are my test values:
                                          VCOM_D 10.9
                                          VCOMG2L 6.4
                                          VCOMG1 6.2
                                          VON 20.8
                                          VOFF -7.5
                                          VMGA1 15.1
                                          VMGA2 15.1
                                          VMGA3 15.1
                                          VMGA4 15.1
                                          VMGA5 15.1
                                          VMGA6 15.1
                                          VMGA7 15.1
                                          VMGA8 15.1
                                          VMGA9 15.1
                                          VMGA10 0
                                          VMGA11 0
                                          VMGA12 0
                                          VMGA13 0
                                          VMGA14 0
                                          VMGA15 0
                                          VMGA16 0
                                          VMGA17 0
                                          VMGA18 0
                                          It's weird that VGMA #1-9 puts out the correct voltage but VMGA #10 - 18 puts out 0 volts. I'm guessing this is a definitive result that my T-Con board is bad?
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
                                          • alltvrepairs
                                            Lg TCon test pins for screen test
                                            by alltvrepairs
                                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                            Appreciate your help....
                                            06-13-2025, 06:33 AM
                                          • dreico33
                                            TL866 II Plus Check ID Error on various IC
                                            by dreico33
                                            Hellow guys , i really need your help here.
                                            Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                                            11-04-2024, 03:13 PM
                                          • hasel17
                                            CH341a can erase and read but can't write and blank check
                                            by hasel17
                                            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                            Code:
                                            Checking for blank...
                                            (Press
                                            10-26-2023, 06:20 AM
