T-CON Check Spreadsheet
    Re: T-CON Check Spreadsheet
    Excel isn't hard, it's just equations and overly-complicated IF-equations (just click any cell to view the formula!) I did it in openoffice because I don't have a copy of Excel.
    The voltage has to increase OR decrease, in other words, differential voltage from point to point, the sign of the number needs to stay the same. Also, the symmetry test mirrors the voltages around VCOM (AVDD/2 or mid point average of gamma voltages) and sees if they match up. The symmetry test is an additional test, both should be done. It's a lot harder to do in your head. If either of these fail, the result is a guaranteed fail.
    Note -- the Detailed Results tab is more of an internal debug tab -- you should look at Summary for overall conclusion.
    New version coming soon with improvements and bug fixes.
    how about this flickering screen with horizontal line
    INPUT 12.47V
    VGH 30.34V
    VGL -9.50V
    AVDD 16.30V
    VCOM 6.90V
    VSS -9.16V
    WP INV 3.39V
      Flickering/double images and horizontal lines are panel problems but may be repaired with a workaround using the tape cutoff method.
      https://techhometravel.com/repair-of...lines-on-a-tv/
