Lg TCon test pins for screen test
  • alltvrepairs
    • Jan 2014
    • 282
    • Malta
    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
    Appreciate your help.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4832
    • Italy - Milan
    Run a cable from ps board 12v to the tcon fuse, but there is probably a damage in the cof, it happened to me, check every cof tab with strong magnifier to find broken traces..
    • alltvrepairs
      UE82NU8000 Lines on screen after masking tcon pins
      by alltvrepairs
      This set came in no picture but backlight ok.
      I have found that covering a small portion of yhe pins will bring hack tv to live, confirming it us a screen problem.
      Saw on youtube someone grounding cfk pins to ground to remove lines but am not sure if legit.
      Any technical recommendation to get a better quality picture?
      Tks
      04-11-2026, 02:15 AM
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • thstuff
      Sony OLED XR-77A80J - Initially dead, now 4 Flashes
      by thstuff
      A) TV initially dead
      B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
      C) Was able to perform a Reset from Settings menu and completed out of box configuration.
      D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
      E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
      12-26-2024, 09:10 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • BoardHoarder
      XBR-65X850D Backlight/Power On Help
      by BoardHoarder
      Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
      02-09-2024, 11:00 PM
