TCL 43S423 TCON OR PANEL FAULTY???
  • netgearnetgear
    • Mar 2022
    • 47
    • Trinidad
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with no picture. The main chip on the tcon board is very hot that I can touch it for about 3 seconds. All voltages vin, vhg, vhl, vdd, vcom and the ladder resistor voltages are within normal range. The tc1 and tc2 voltages fluctuates from 8v to 30v. If I try to cover the ckv signals on ribbon eg. The right side one, it still comes on with the entire screen showing the logo with fine lines then attempts to update the software. If I apply 12v from my linear power supply, the tcon board draws around 240mA. Also if I disconnect both ribbons from the tcon, the main chip on it gets extremely hot and the Power ON light still gives the two blinks in quick succession. I'm trying to rule out if the panel or the tcon is the problem. Any help or advice would be greatly appreciated....regards.
  • EazyBone
    • Jun 2023
    • 1440
    • United states
    • Anything I can do with my hands
    These have panel issues. Likely that's what you have. I've yet to find one with a TCON issue.. but I don't have huge volume like a TV repair shop.
    • netgearnetgear
      • Mar 2022
      • 47
      • Trinidad
      Your response is noted. Thank you. I will start over double checking the tcon board and more importantly looking at the panel board that the COF are connected using datasheets where possible. Will provide an update....cheers
      • EazyBone
        • Jun 2023
        • 1440
        • United states
        Also the power light blinking.. generally when you get a Roku TV and it's not connected to Internet it will continue to blink that way. Connect it and it'll stop
        • howardc64
          • Jun 2017
          • 735
          Mine (TCL 55S425) has similar failure. One failure was TVS which got picture working pretty good other than some horizontal lines. Further tinkering probably caused more COF failure.
          https://www.badcaps.net/forum/troubl...l-buffer-board
          On a different TCL 55" model (55S405), I found 2 differnet panel+T-Con manufacturer despite same TV model. You might check your T-Con in case 43" had multiple panel t-con manufacturers.
          • netgearnetgear
            • Mar 2022
            • 47
            • Trinidad
            Ok. Noted. Thank you for your response. Will provide an update as soon as I can....cheers
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • AK_777
              Sony KD-65A1 Repair – 4 Red Blinks Error
              by AK_777
              Hi everyone!
              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
              02-20-2025, 04:15 PM
            • NWArkGuy
              Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
              by NWArkGuy
              Well, I will be the first to admit that I screwed up...
              In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
              I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
              I have 2 that I have found and have in my possession. ...
              10-12-2023, 10:13 PM
            • Chrissy-haras
              Toshiba 65UL2063DB tcon ribbon
              by Chrissy-haras
              I have been trying to repair the above tv , however , the tcon ribbon has frayed , if i swap the ribbon from opposite side I get no picture, the original ribbon is get full picture with 3 once line...
              03-28-2026, 12:51 AM
            • snirsnir
              Samsung QE65Q67AAUXXH (65" QLED) - Bootloop, no logo, no hot components found
              by snirsnir
              I have a Samsung QE65Q67AAUXXH (2021 QLED, 65").
              Panel: CY-QA065HGSV1H
              Main board: BN41-02844A (BN94-16448X) - T-CON integrated, no separate T-CON board.
              SYMPTOMS:
              - Immediate bootloop on power-on - backlight flashes on for ~1 second then shuts off, repeats endlessly.
              - No Samsung logo, no picture at any point.
              - Sound never plays.
              WHAT I'VE DONE SO FAR:
              1. Disconnected both 90-pin ribbon cables from mainboard → TV powers on, backlight stays on steady. No bootloop. Confirmed mainboard and PSU...
              04-23-2026, 06:10 AM
