Sony LED 65X9005A shuts down after few seconds - looking for help
  • tec3000
    • Mar 2024
    • 119
    here another pic. You don't see any blue line here. It was invisible, even though it was there at the time.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      #62
      Ok but now you moved the tv.. i mean this is why, not the flat cable..
      • tec3000
        • Mar 2024
        • 119
        I don't think so. Did you see the pictures I attached with the first post? There you see how the i-Manual was until two days ago. No issues there. It ONLY happened after I disconnected and reconnected the flat cable.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4333
          • Italy - Milan
          #64
          Are the lines moving? if them are moving then a possible damaged cable, but if them aren't it cannot be that cable, the cables doesn't control single lines them controls at maximum two or four pixels at the moment..
          • tec3000
            • Mar 2024
            • 119
            There was one horizontal line. It was definitely changing colours. Most of the time green, sometimes red, but also greyish/black. The grey/black line was very thin. It was only visible in bright scenes. When scenes changed the colour of the line also changed.
            And the size of the line also changed. Sometimes it was a straight line from one end of the TV to the other end (left/right), sometimes blocks of smaller lines.
            Only lately I noticed another horizontal line below this one. But not as large.
            And the vertical line also changed. Sometimes not visible, sometimes a clear blue.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4333
              • Italy - Milan
              #66
              .i.mean.NOW...
              • tec3000
                • Mar 2024
                • 119
                No not moving while the TV is running. It was worse though when I first disconnected the cable. After playing around with the cable (straighten it a bit) half of the screen is now full of lines. STATIC.
                • Diah
                  • Feb 2013
                  • 6376
                  Originally posted by tec3000
                  Ok guys, you convinced me. I will do it...Also I think I made a mistake yesterday. I disconnected a cable from the T-CON board. I think Diah that's exactly
                  the ribbon and LVDS i think you should know where... and do what i asked you before. no more or less.
                  Click image for larger version  Name:	1708473458948.jpg Views:	44 Size:	632.3 KB ID:	3241473
                  • Diah
                    • Feb 2013
                    • 6376
                    LVDS need to clean them from the main boards side.
                    • tec3000
                      • Mar 2024
                      • 119
                      Diah
                      alright, thank you for marking the CORRECT cables. [Super, ich hab also die ganze Zeit die falschen Kabel rausgezogen. Ich nehm's mit Humor....]
                      About the ribbon cables. Just to be 100% sure: You want me to take the ribbon cables carefully out one-by-one and turn on the TV and look if it stays on or not, correct?
                      • Diah
                        • Feb 2013
                        • 6376
                        LVDS clean them from MB side to get rids out the disruption in picture you have right now.
                        remove all 4 ribbon together to check the LED BL turn on and remain on so when you attempt to repair LED, at time the screen out from set..let you always can check and see that all yours LED BL lit on with out screen,i
                        who knows could be the turn off issue fixed too by cleaning the LVDS
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4333
                          • Italy - Milan
                          #72
                          deleted by admin... please refrain from arguing on the forum. if you think a post is a personal attack click the report button and i'll take action
                          • tec3000
                            • Mar 2024
                            • 119
                            so I took out one of the LVDS on the mainboard end, had a look and just plugged it back in and first pic happened. Then I played with the cable and plugged it back in and i-Manual is almost as good as it has ever been. (pic 2) BUT Diah can you take a look at pic 3 and 4 and tell me how I should clean it?
                            And in pic 5 you see the ribbon cables. Any hint how to carefully disconnect those cables? I should first peel off the tinfoil right? I really don't wanna mess this up....
                            • Diah
                              • Feb 2013
                              • 6376
                              stop to do any more on cables as you have now very clear screen., except the LED defect shadow ... i think now its enough reason to give you encourage to repair LED BL and have full function TV.... good luck.
                              • Diah
                                • Feb 2013
                                • 6376
                                • tec3000
                                  • Mar 2024
                                  • 119
                                  Thank you, It's been a rollercoaster journey so far, but I'm highly motivated again.
                                  I'll watch some YouTube videos and then get to work. So if I understand you guys correctly I can only order the backlights once I have removed the screen. So right now I can order a couple suction cups.
                                  That's it, right? Or is there anything else?
                                  • Donny2derby
                                    • Apr 2023
                                    • 228
                                    • Uk
                                    #77
                                    Another pair of hands is more useful than suction cups. Many hands make light work as they say.
                                    It's so valuable to have that additional help. 4 eyes and 4 hands is double the opportunity to see what is right and wrong or spot something the other person might not.
                                    And lifting things off with the help of another as opposed to with suction cups is far more stable.
                                    But yes. The first thing to do is break the telly down to the backlights, then read their part number and order the exact same type.
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      Yeah, I will definitely have some help.
                                      OK, I really hope I will be able to find the correct backlights.
                                      Thank you!
                                      • EazyBone
                                        • Jun 2023
                                        • 1337
                                        • United states
                                        #79
                                        Suction cups work fine, you don't need extra hands, I do it all the time. If you have two of these spaced out, there's no need for another. You don't need to remove the screen before purchasing the LEDs, of you have a room that is empty and no animals or anything is going to go in there, then fine. Do it so you feel good. Just make sure two things. One, have the ribbons/buffer boards taped with masking tape to the screen so they don't catch anything when you pull the screen off, be gentle with bending them, but they aren't as fragile as you'd think. And two, make sure you run a paper, not plastic, card under the screen along all the edges to make sure the screen isn't glued down (after bezel is removed). Except for the bottom. Sony doesn't usually glue the screen down that I've seen but if by chance it did, you can break it trying to pull the screen off. If there is tape/glue then you want to suction the screen semi close to the area and pull up gently and slide the paper card under the screen to release it. Once you've done that stick a piece of paper or cards under those areas so it doesn't restick while pulling it off. And then suction and pull straight up. Likely it's not glued but who knows. I prefer the double suction cups because if one of them fails, you still have one that will hold it.
                                        Good luck, we can answer questions as you go as long as you put some pictures also.
                                        AND when you put the screen back on, you are going to want new grounding tape to apply to buffer boards. You can probably use old tape but I always put new tape.
                                        • tec3000
                                          • Mar 2024
                                          • 119
                                          EazyBone
                                          Thank you very much. I will order the same suction cup. I was opting for single ones but this looks legit. And thank you for describing everything in detail. It really helps. Just need to find a video or two and see it all in action before I do it.
                                          One more question: When you say I don't need to remove the screen before buying the LEDs... how do I know which ones to buy? And how many do I need to buy? TV is from 2013.
                                          Much appreciated!
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • solveit68
                                            Lenovo L580 20LW-0010GE shuts down after a few seconds
                                            by solveit68
                                            Hello together,
                                            I am hoping for some tips here to repair a notebook.
                                            The notebook has following issue:
                                            After starting the notebook it shut down after a few seconds.
                                            Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                                            The time until shutdown varies slightly.
                                            What I've tried so far:
                                            - cmos cleared
                                            - removed all components that are not essential for motherboard testing including keyboard and touchpad
                                            - ram exchanged
                                            - same behaviour with power supply or battery...
                                            07-21-2023, 01:04 PM
                                          • doejohn11
                                            Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                                            by doejohn11
                                            Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                                            It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                                            04-19-2025, 07:38 AM
                                          • IamPritesh
                                            Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
                                            by IamPritesh
                                            So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
                                            ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
                                            What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
                                            07-31-2022, 05:23 AM
