Philips 42PFL5432D/37
    Re: Philips 42PFL5432D/37
    What I did on one of the TV I fixed is to leave the T-CON metal cover off, then I use a small CPU cooling fan to blow cool air on to the T-CON board using the switched 12VDC for powering up the fan, another TV I used heatsink to cool the IC.
    http://s807.photobucket.com/albums/y...%20LTV-32W3HD/
    Do you have a can of compressed air duster? They sell them at Costco 3 cans for about $6, just turn the can upside down and blow the cold air on the T-CON to see if it will start working again, then you can try just cool each IC or components on the T-CON board to find out which one is temperatue sensitive.
      That is a cap, C69 , in the picture that looks bad. You should be able to take a voltage reading on the cap, the bar is the Postive side in this case. You can try cool spray on this cap.
        By the way, your camera should have MACRO mode for closed up function.
        • bbjunkie
          • Dec 2011
          • 301
          #204
          Careful, some canned air contains liquid propellant and when the can is turned upside down, it comes out instead of air (I found out the hard way spraying "air" at my digital camera sensor) I suggest if you are going to try this, use a can of freezer spray instead.
            The one from Costco works just fine. I used to buy the expensive freeze spray made for electronics repair. You can try Radio Shack, they used to sell these freeze spray for electronics troubleshooting. You can verify if the canned air is OK or not by just spraying it on to a glass and see if it leaves any residue.
            • Lobo
              • May 2010
              • 59
              #206
              So looking at the pic named "top angle" would you say that the left side is positive?
              • Lobo
                • May 2010
                • 59
                #207
                Uh, I went to check the voltage with my multimeter and the solder holding the component was so hot that it fell right off the board...
                The funny thing is after that fell off, my picture came back. The TV works now. I'm baffled, what do I do now? Just leave it and worry about it being a fire hazard? Or what? haha
                  So right now the cap is no longer in place? I had a feeling that the cap has high leakage or shorting out, I will not run the TV without it since the circuits may be exposing AC ripple voltage due to missing filter cap, unless there is another cap with the same value hooked up in parallel with this cap.
                  • Lobo
                    • May 2010
                    • 59
                    #209
                    Yeah, the cap is no longer there. So what do I replace it with? My cheap multimeter was reading about 15-16 V.
                      15~22uf25v surface mounted or try using low ESR through hole type. But one thing that bother me is that the voltage is that high, I do not expect it to be higher than 12vdc. I would look for replacement T-CON because I think it will go out completely soon.
                      • Lobo
                        • May 2010
                        • 59
                        #211
                        Yeah, I was thinking of just replacing it because they are relatively cheap. I found one for 20 dollars.
                        But anyway, I wonder if PoteauPet has taken another look at her T-conn board? Curious to see if she has the same prob.
                          On the surface mounted polarized cap, the BAR is positive, you can verify that with the DMM.
                          • Abbeyjack
                            • Feb 2012
                            • 9
                            I have hit a wall. I was following this post here, just to quickly sum up my symptons for you......
                            I was following along nicely, things were good, then i got to the step where it was asked to measure the pins on the voltage regulators on the t-con board. I measured the first one, which would be the one of the top of the pic.
                            Post #170
                            Pin 1- 2.48
                            Pin 2- 0
                            Pin 3- 3.25
                            Exactly what the OP got, and was said it was accurate. cool .
                            Was going to check the second one( the right side of the pic), went i put the red tip of my meter on PIN 2 it caused a little "zap" and very high frequency sound and THE PICTURE CAME ON!! I fiddled with it a couple times and the picture would go on and off as i was poking it. with the zap and high frequency sound.
                            I sat back and it stayed on. So, i think i found the problem, although i dont know what i found!!
                            Could this be a bad voltage regulator? Is it just a bad soldering joint? I have never messed with it, so can joints just go bad over time and need to be fixed?
                            For clairification, while i am measuring the second voltage regulator, i have sound, green power light, back lights on, no picture.
                            Pin 1- 0
                            Pin 2- 5.38
                            Pin 3- 0
                            Thank you for reading this and I hope it makes sense.
                            I was able to measure the second voltage regulator while the picture was on and it was different.
                            Pin 1- 2.5
                            Pin 2- 3.5
                            Pin 3- 0
                            Please help me understand what's going on.
                              How about the pictures of your board, so we may see what is going on with YOUR board?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #215
                                Pin 1- 0
                                Pin 2- 5.38
                                Pin 3- 0
                                A part number and picture for the above would help.
                                --- begin sig file ---
                                --- end sig file ---
                                • Abbeyjack
                                  • Feb 2012
                                  • 9
                                  I circled the voltage regulator in question in red in the one photo.
                                  Part # 63A3 71Q5Z
                                    Going by its position I'd say that's a MOSFET not a voltage regulator.
                                    • Abbeyjack
                                      • Feb 2012
                                      • 9
                                      according to post #170 its a voltage regulator. Of course I am only going by what I read on here, I really dont know what either one are! Im learning as I go!
                                        That looks like MOSFET to me too, it is QP17 and its GATE pin driven by UP2 pin 4, it is part of the switching power supply. Can you read the P/N on UP2?
                                        You can see V5.6V input feeding the pin of the inductor LP4, the other pin is connected to the Drain (Middle/tab) pin of the MOSFET, the output Diode Anode (DP21) is also connected to the Drain pin, the Cathode pin is the output pin, so it looks like a Boost regulator.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #220
                                          Part # 63A3 71Q5Z
                                          As tom66 and budm both mentioned now, it is a mosfet.
                                          http://www.datasheetarchive.com/63A3-datasheet.html
                                          When I don't get clear focused pictures, I can only guess at what the part can be.
                                          Many people don't realize how difficult remote troubleshooting is when we don't have the board in front of us. You are the eyes, ears, etc for us.
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • Cornito
                                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                                            by Cornito
                                            Hello Team,
                                            New issue on LCD panel where I need to find out the cause and the potential solution.
                                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                                            VHG VGL CKV... are the sames on...
                                            03-08-2024, 06:41 AM
