Philips 42PFL5432D/37
  • PoteauPets
    • Jan 2012
    • 65
    #81
    Re: Philips 42PFL5432D/37
    Shopping List of all the other CrapXon caps on the power board. I already have the set of 3 (1500uV35) & the single (2200uF16V) in my basket at Digi-Key.
    Here are the others needed to totally re-cap all the CrapXons on the power board.......
    47uF35v KM105 (5mmX13mm)
    2.2uF50v NK105 (5mmX13mm)
    6.8uF50v KM (6mmX13mm)
    100uF25v KM105(5mmX13mm)
    10uF25v GS (5mmX13mm)
    Do you think I need them ?
    • retiredcaps
      • Apr 2010
      • 9271
      #82
      If this were my TV, I would have replaced them all in the intial go. Check diameter to make sure they fit. Plus all 5 caps below are $1.51 total so a no brainer really.
      Here are the suggested replacements.
      http://search.digikey.com/us/en/prod...1232-ND/356135
      http://search.digikey.com/us/en/prod...0313-ND/266322
      http://search.digikey.com/us/en/prod.../P936-ND/80642
      http://search.digikey.com/us/en/prod...413-ND/2433547
      http://search.digikey.com/us/en/prod...1212-ND/356116
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        #83
        PS. Just remember about polarity and putting the caps in the right direction.
        https://www.badcaps.net/forum/showpo...46&postcount=8
        And make sure the post office sends the caps to the right town this time.
        • PoteauPets
          • Jan 2012
          • 65
          #84
          Thanks so much Retiredcaps.. You have been so nice, and yes I will make sure they send them to the right post office this time.
          I took your advice and added 2 each of the five caps above. Remember, I have nearly the exact same flat screen t.v. in my bedroom, only difference is it's a 37" not a 42", and as yet no problems.
          Dig-Keys online ordering is down till 4:00 a.m., but everything is in my basket and ready to roll first thing in the morning. Hopefully, I will have them by Tuesday.
          I will hollar at you when they come in.
          • tbuch
            • Jan 2012
            • 31
            #85
            Hi everyone, I am new here with the same problem with this TV. However, when I go to turn it on I can here something trying to power on, but nothing happens and the led light just stays a steady red.
            PoteauPets... Any news, the suspense is killing me!!!!
            • retiredcaps
              • Apr 2010
              • 9271
              #86
              You can start by posting top down view pictures of your boards by following my sig file below exactly.
              • tbuch
                • Jan 2012
                • 31
                #87
                I haven't got the back cover off yet... Just brought the TV out of the closet But I have been studying all the posts on this subject for two days. I will post pictures as soon as I get the back off~ Thank You
                • tbuch
                  • Jan 2012
                  • 31
                  #88
                  Finally, here are my pictures... Hubby has the tools in his car so I had to go on a hunt for spares.
                  I hope I uploaded them right.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #89
                    Those group of 3 green caps are bloated. They provide power to the inverter section so the backlights can come on.
                    If you or your husband are good at soldering, I suggest replacing all the caps on the power board.
                    You should also post a picture of the main/logic board. This is the board that holds the HDMI, RCA, component connectors.
                    edit: It seems the same 3 keep dying as evidence from other posters who have the same TV.
                    • tbuch
                      • Jan 2012
                      • 31
                      #90
                      Thanks retiredcaps, I also noticed that those three caps were bloated. I will pull off the cover and upload pictures of the main/logic board~ Thanks again!!
                      • tbuch
                        • Jan 2012
                        • 31
                        #91
                        Here are three more images of the next board... With 3 more obvious bad caps.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #92
                          I see 4.
                          • tbuch
                            • Jan 2012
                            • 31
                            #93
                            Is the 4th the gold colored cap on the opposite side as the three?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #94
                              Since I can't see the complete board and its relationship, it is the one circled in red. I think it is bloated, but it could also be a lighting trick?
                              • tbuch
                                • Jan 2012
                                • 31
                                #95
                                Yep, that is the one I was referring to, after closer inspection i did notice that it is bloated.
                                ~ You don't happen to know JavaScript coding do you? .. LOL!!!
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #96
                                  That is why we always ask for photos of your boards versus referring to stock or other people's photos.
                                  My programming days are long, long, over.
                                  • tbuch
                                    • Jan 2012
                                    • 31
                                    #97
                                    That's a very good idea!! My newbie eyes may not see what yours does
                                    Ahhh, mine are just starting. In fact the TV is on hold for the night so I can work on my schoolwork
                                    • tbuch
                                      • Jan 2012
                                      • 31
                                      #98
                                      Hi I'm back.... Javascript got boring.
                                      Anyway, I have compiled a list of all the recommended replacement capacitors that I will need to order with the exception of the one rated 220uf 25v, what do you suggest for this guy? ~Thanks!!!
                                      Also, I am having an issue locating the part number
                                      For replacements use Panasonic FR caps (91 cents each) at digikey. Shipping from digikey is about $2.75 USD and you get the parts in 48 hours or so.
                                      http://search.digikey.com/scripts/Dk...25v+fr&stock=1
                                      • PoteauPets
                                        • Jan 2012
                                        • 65
                                        #99
                                        Hi Guys,
                                        The caps finally made their arrival this afternoon. I removed and replaced all 9 of the CrapXon caps. Put the board back in, powered it on, and it's stayed on for a little over 2 hours now. I am sooooo soooo excited. Remember, I could barely get an hour before it would shut itself off. I think it's fixed !!!! Thank you guys for all your help. I couldn't have done it without you, that's for sure My 10 year old daughter is so excited to be able to watch her morning cartoons again before she starts her school day.
                                        Oh, and one more thing....when I started this whole adventure, I was a little nervous about soldering. I had to replace one cap, then re-do it because I put it in backwards, but after doing all 9 today, I think my solder joints are the prettiest ones on the board......lol
                                        I'm uploading some pics for your perusal. Thanks again guys, WE DID IT !!!!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #100
                                          main();
                                          printf(" http://search.digikey.com/us/en/prod...2383-ND/613744 ");
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
