Philips 42PFL5432D/37
  • backoi
    • Jan 2012
    • 6
    #41
    Re: Philips 42PFL5432D/37
    Originally posted by retiredcaps
    1) Do you have a source hooked up like a DVD player to see if there is a picture and sound?
    2) Does the power always go off after 1 minute?
    a) If you turn off the TV and turn it back on, does it stay on 1 minute and go off again?
    It can't be turned on. I tried to hold/release the power button on the side of the TV and sometimes, I was able to turn the unit on after hitting the power button few times, then the power button worked and I could turn it on/off as usual until I shut off the main power, then the problem re-occurred.
    3) Can we get a picture of the entire TV backside so all the boards are in view? We want to see the relationship and cabling between boards.
    See attached pictures.
    4) PS. Sharp eyed readers and future people will notice this is why we always INSIST on photos on your own TV. The boards are completely different even though backoi says the models are the same in post #36.
    Yes, I have one. Since TV can't turn on, so the dvd wouldn't do anything.
    Yes, after pluggin in the main power cord, one of the LEDs on main board stayed on 1 min, then it went off at the same time with a blue indicator LED in front of TV. See attached pictures.
    • PlainBill
      • Feb 2009
      • 7034
      The service manual is available from Elektrotanya. This TV uses a split power supply design that makes troubleshooting a LOT more interesting. I'd suggest downloading the service manual, Philips is excellent about supplying troubleshooting information. I'll be downloading a copy myself and be ready to help.
      The fact that you have 24 volts to the inverter and the blue light goes on and off indicates both power supplies may be working. The first step is to check that. Since it does not appear the connectors are labeled, the manual is going to be a big help.
      PlainBill
      • PoteauPets
        • Jan 2012
        • 65
        #43
        Dang it. Still no caps today. Ordered them Tuesday before noon, was hoping to have them today for sure..............=(
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Did you change any of the caps on the power board?
          All the caps look like Rubycon ("K" vent) and then there are 2 blue caps with the "+" vent.
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            From all the feedback Digikey usually delivers in 2 days with USPS 1st class to USA residents.
            • PoteauPets
              • Jan 2012
              • 65
              #46
              Tracked my caps and found they were mis-delivered to another town, but only 10 miles away, so I went and got them. Now, caps in hand, ready to begin.......=-)
              Looks like I have to take out the main power board before I start.
              • PlainBill
                • Feb 2009
                • 7034
                backoi, there is something very strange going on here. I downloaded the service manual for the 42PFL5432D/37 and got the chassis illustrated below, which is a good match to the one PoteauPets is working on, but not at all like the pictures you posted.
                What is the model number and chassis number of your TV?
                PlainBill
                • rmoody
                  Learning Member
                  • Jul 2011
                  • 262
                  #48
                  Not sure if you got any or not but Solder Wick is a great tool for desoldering the old caps, I have removed and replaced caps without solder wick but it's a pain and isn't as clean of a job as using the wick.
                  • backoi
                    • Jan 2012
                    • 6
                    #49
                    My apology to PlainBill! I checked the model and it's 42PFL7432D/37 chassis Q523.1U LA
                    I mixed up the 7432 with 5432. I am searching for the service manual, hope to find one soon.
                    Backoi
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Backoi
                      The service manual is available from Elektrotanya; you have to search on the chassis number.
                      There are already several threads for that chassis; I suggest asking the mods to either move your posts to this thread or to open a new thread.
                      PlainBill
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        Success??
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          If the sound and power light stayed on, that implies the main board is working correctly.
                          Check again when the TV goes off if 24V DC is present on the master and slave inverter board.
                          If not, that implies that the power board has a problem. Since other past owners of this set have posted pictures with bad caps on the power supply, I would suspect you will have to recap the power board given Capxon's poor reputation.
                          Remember caps don't have to bloat in order to be bad.
                          If 24V DC is present when the TV goes off, then that implies a bad t-con as PlainBill mentioned in post #20.
                          • PoteauPets
                            • Jan 2012
                            • 65
                            #53
                            I only re-capped the 2 that were bloated. Do you think that's my problem? I didn't want to tempt fate since it was my first time soldering, but now I am regretting it. I will re-check to see that the 24V DC is present on both master and slave, but if it was good before, shouldn't it be good now?
                            About the bad t-con in post #20, I never could see a picture when I shined a light inside, either before or now. But the green power light is staying on now after the recap, before the recap, it turned amber.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              In post #21, you reported that 24V DC was not present after the screen went blank. We are testing for the same thing. If 24V DC is not there, that points to the power supply.
                              • PoteauPets
                                • Jan 2012
                                • 65
                                #55
                                Sorry, I"ve been away. (Had some family emergencies) Anyway, I have re-tested both master and slave sides with power on and still get the 24v reading. Now, I am waiting for it to kick itself off or go black again to re-test. Be back in a few....=)
                                • PoteauPets
                                  • Jan 2012
                                  • 65
                                  #56
                                  Yep, it kicked off, no reading on either the slave or master side. Light on front is red or amber.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    If 24V DC is not present on the inverter boards, then I would suspect those Capxon caps on the power supply.
                                    Soldering on the power board will be easier than the logic board because most power boards are only single layer.
                                    I suggest changing all the caps on the power supply with Panasonic FM equivalents from digikey.com.
                                    Make a list of all the existing caps and we can help make the order.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      If you search this forum for 42PFL54*, you will see a lot of power boards with bloated Capxon caps.
                                      • PoteauPets
                                        • Jan 2012
                                        • 65
                                        #59
                                        Remember, I replaced the 2 capXons that were bloated but didn't replace the third one since it looked okay. Do you think I should replace that third one and re-test everything again?
                                        • PoteauPets
                                          • Jan 2012
                                          • 65
                                          #60
                                          Hey Retired, Just took a look at the two caps I replaced and one has already bloated !!
                                          What is causing that?
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
