Philips 8200 series 65PUS8204/12 stuck at Philips Logo
  • G33RT
    • Oct 2016
    • 69
    • Belgium
    • Computer, Networks, Electronics
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    Regards, Geert
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4740
    • Italy - Milan
    Contact Philips to ask them special restore software file for the usb stick.. many people solved it like so..
    • G33RT
      • Oct 2016
      • 69
      • Belgium
      Thanks !
      Do you happen to know if this restore software is available for download on the net somewhere ?
      Regards, Geert
      • lotas
        • Jan 2016
        • 5356
        • Russia
        If the eMMC is completely worn out, as in your case, then no recovery via USB will help you.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4740
          • Italy - Milan
          Commonly you do not find that type of file around..
          • G33RT
            • Oct 2016
            • 69
            • Belgium
            I got it fixed with a USB bootloader & firmware update.
            This ZIP file TPM191E_101.2.178.0_upgrade_loader.zip contains a file named upgrade_loader.pkg
            Just put it on a USB stick that is formatted MRB FAT32 clusters 64byte.
            Insert into the Black USB 2 (500mA) port on the TV and hold down power button while plugin the power plug.
            Now you see on the screen that a update is in progress and let go the power button, this takes about 15 to 20 minutes to finish.
            When the update is done the TV switch itself off and you have to power it on by power button on the TV, once it booted up you can use the remote control again.
            (Reference info)
            Brand: Philips
            Model: 65PUS8204/12
            Mainboard: 715GA006-MOF-B00-005K (WK1924)
            Firmware: TPM191E platform
            eMMC: KIOXIA THGBMJG7C1LBAIL
            Regards, Geert
            • nomoresonys
              • 12370
              • U.S.
              Well done G33RT
              • bohaboha
                • Nov 2012
                • 1108
                • sweden
                Hi can you please upload the file here thank you
                • porfyriadhs
                  Philips 55pus7304/12 stuck on boot logo
                  by porfyriadhs
                  Hello friends I need your help. I have a Philips 55pus7304/12 stuck on boot logo. Tried update via usb with no luck maybe wrong file dont know. Any one who knows about this situation will be helpfull. Thanks...
                  01-16-2026, 03:40 AM
                • fredyjbi
                  Please help me, my friend Dell 5420 La-k491p bios recovery failed stuck on logo, thank you
                  by fredyjbi
                  Please help my friend Dell 5420 La-k491p rev 2.0 vpro ST.BZD1JQ3 laptop turns on but error bios recovery failed stuck on logo thank you...
                  05-08-2026, 11:34 PM
                • odie34
                  TCL 55S451 Stuck on Logo Screen But Working Otherwise
                  by odie34
                  I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
                  So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
                  04-25-2026, 03:40 PM
                • NXTPRO
                  Sony Bravia KD-55X8000G stuck at Sony Logo
                  by NXTPRO
                  My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
                  Board: 1-982-454-51
                  04-03-2026, 07:28 PM
                • conghuyms
                  MacBook Air A2179 stuck logo , pls help me !
                  by conghuyms
                  Hey everyone,
                  I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                  When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                  I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                  11-05-2025, 08:30 AM
