Philips 42PFL5432D/37
  • tbuch
    • Jan 2012
    • 31
    #161
    Re: Philips 42PFL5432D/37
    Doide D925 reads 1 the other way
    Diode D912 reads the same both ways... 001
    • Mr Bill
      • Nov 2011
      • 648
      D925 would indicate its good. You should get a value one direction and either "0L" or "1" the other way if you reverse the probes. Desoldering and checking is still your best bet. Just try to not mess them up to bad incase they are good. That way you can atleast put them back.
      • tbuch
        • Jan 2012
        • 31
        #163
        Mr. Bill,
        Those two diodes were good after testing them off the board. I did what was posted in another board and used the Radio Shack Diodes to see if this fixed it and sure enough it did. I have the needed diodes on order and will replace them as soon as they come in. ~ Now I am testing to see if I have the problem of the set turning off when it heats up...Fingers crossed!! Thanks you guys for ALL your help!!!!
        • PoteauPets
          • Jan 2012
          • 65
          #164
          Hey Guys,
          I've been away for awhile taking care of my husbands elderly parents, but am still having TV issues.
          Here's what I have done so far :
          1) Re-capped bloated caps on Scaler board. (I think it was only 2 or 3)
          TV would still shut off after 20-30 mins or so.
          2) Re-capped most all caps on the power board
          TV still had same issue, but discovered that if we kept a fan running
          behind it it would stay on all day & all night.
          3) You guys had me doubt my original solder joints on the scaler board, so I went back and removed them and capped them all over again.
          4) Still same problem, only fix so far is to keep the fan on.
          5) Ordered more caps, (arrived Tues) re-capped the entire scaler board.
          6) Still same problem, only stays on with the fan running.
          HELP !!!!!!!!!!!!!
          • PoteauPets
            • Jan 2012
            • 65
            #165
            OH, and with the help of TBuch, I tested all the diodes while waiting for the last shipment of caps. They all checked out fine.
            • retiredcaps
              • Apr 2010
              • 9271
              #166
              1) My next best guess, and it is a guess, is that something on the t-con may be overheating.
              2) A replacement is at
              http://www.ebay.com/itm/220939145281
              3) To verify if that is the case or not, try to think of a way just to keep this card cool (instead of the entire backside of the TV). This may involve some "duct" work or portable hair dryer on the cool setting.
              4) There is a voltage regulator on the board (maybe two), but I'm afraid your analog multimeter may not provide enough precision to determine if it is bad or not. A voltage regulator should be within 1% of it specifications.
              Now if the voltage regulator is "obviously" bad, then a 3.3V regulator might read 4.5V or 2.4V which is enough to spot with an analog multimeter.
              --- begin sig file ---
              --- end sig file ---
              • PoteauPets
                • Jan 2012
                • 65
                #167
                I have a new digital multi-meter. It's the same one TBuch bought in an earlier post, with which I tested all the diodes.
                Where and what exactly is the T-Con???
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #168
                  https://www.badcaps.net/forum/attach...5&d=1327778579
                  PlainBill also mentioned it as a possibility way back in post #20.
                  It stands for timing control.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #169
                    BTW, it is not uncommon for a TV to have multiple problems in addition to the bad caps found earlier. Most of the time, it is just one thing.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #170
                      1) I marked the two voltage regulators. The pics are almost good enough for me to make out the part numbers, but I can't. So please list the part numbers.
                      2) To measure them, see my bookmarked answer at
                      https://www.badcaps.net/forum/showpo...13&postcount=3
                      Use a ground screw on the t-con for your black probe.
                      3) Obviously, we want comparison readings of these two when the TV is working and when it is not.
                      • PoteauPets
                        • Jan 2012
                        • 65
                        #171
                        Part numbers
                        ANE 8815
                        AECS 250
                        0719
                        6343
                        74J3Z
                        Will post readings momentarily.
                        • PoteauPets
                          • Jan 2012
                          • 65
                          #172
                          Yes, I remember that post....=(
                          • PoteauPets
                            • Jan 2012
                            • 65
                            #173
                            Readings with TV ON
                            ANE 8815 AECS 250 0719
                            Pin 1=2.49v
                            Pin 2=0
                            Pin 3=3.27v
                            6343 74J3Z
                            Pin 1=0
                            Pin 2=3.69v
                            Pin 3=2.81v
                            Readings when the TV kicks off=0 across the board.
                              That indicates that something is cutting power to the boards - suspicions rest on the power supply - as the 24V is shutting off as well.
                              If the power LED stays ON during the failure, the standby voltage is -probably- fine, but we must check that it is at 5V and not at a voltage which is too low.
                              Need a closer pic of this area. If there are any labels next to the connector, report them.
                              • PoteauPets
                                • Jan 2012
                                • 65
                                #175
                                Here are the latest pictures. By the way, Thank you all for your help !!!!
                                • PoteauPets
                                  • Jan 2012
                                  • 65
                                  #176
                                  The white label info is as follows:
                                  ADPF 24300R1P
                                  P4P77 773911322
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #177
                                    Readings with TV ON
                                    Pin 1=2.49v
                                    Pin 2=0
                                    Pin 3=3.27v
                                    1) The above is correct. The 250 indicates the output voltage. You have 2.49V.
                                    6343 74J3Z
                                    Pin 1=0
                                    Pin 2=3.69v
                                    Pin 3=2.81v
                                    2) I can't find a datasheet for the above and the readings don't match any of the "common" voltages. Common is 1.8, 2.5, or 3.3V. So this part could be suspect.
                                    3) Let's try another set of measurements.
                                    Circled in red are the t-con voltage rails. The red multimeter probe should fit into each of one of those small test points. Your black probe goes on a t-con board ground screw.
                                    4) List each legend and its value when the TV is working and not. Also please post a close up photo of just the section in red.
                                    5) Also please clarify the above "kicks off". The last I remember is that when the TV doesn't work, there was sound and backlights were on (white).
                                    • PoteauPets
                                      • Jan 2012
                                      • 65
                                      #178
                                      Close up of the area in red per your request. And yes, when it kicks off, we still have sound and back lights.
                                      What do I set the meter to to perform the above mentioned test?
                                      Tested with TV Powered On, Meter set @ DcV -20
                                      GND=0
                                      SDA=3.28
                                      VIN=12.00
                                      SCL=3.28
                                      TSTPGM=.01
                                      Tested when the TV Shut off, Meter set @ DcV -20
                                      GND=.01
                                      SDA=.01
                                      VIN=.45
                                      SCL=0
                                      TSTPGM=0
                                      • PoteauPets
                                        • Jan 2012
                                        • 65
                                        #179
                                        Just found this post in my local area. Wondering if this would be fixable or if I could use it for parts to fix mine. What do you guys think? I just sent her a message to see what her bottom dollar is. Here is her actual picture and description.
                                        ‎42' Phillips Flat Screen w/Ambulight for sale. Also comes with the remote.
                                        It has a black strip down the side of the screen other than that it works fine. My son uses it to play the 360 & watch movies on. Make me an offer.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #180
                                          VIN=12.00
                                          VIN=.45
                                          For some reason the t-con loses power when it gets hot, but the main and inverter board are still functioning. I have to think about this.
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
