Philips 42PFL5432D/37
Re: Philips 42PFL5432D/37
Reviewing other posts two bad diodes where the cause of this. Should I try replacing them also with part http://search.digikey.com/us/en/prod...ACT-ND/2770358 ?Comment
--- begin sig file ---
--- end sig file ---Comment
If you are going to buy one, get one with a symbol that has ->|- on it. Like the symbol circled in blue.
Same if you are borrowing one.
PS. If you are buying one, which one do you have in mind? I have a big interest in multimeters.--- begin sig file ---
WOW, I thought I had been seeing things because I had a hard time finding it myself. It was in the philips post regarding no picture, chirping. OP was twlztid and it was post #10 Re: Phillips 42PFL5432D/37 Chirping and No Picture
Quote:
Originally Posted by tw1ztid
I don't have a multi-meter or any experience with one.
There are 2 SMD fuses on each inverter board for a total of 4. If they are open (bad), then your backlight won't turn on.
If you don't have money, try to borrow a multimeter from someone to test the fuse and diodes as Mr Bill as pointed out.
If you live close to a Wal-Mart, they have this multimeter
http://www.walmart.com/ip/Equus-3300...meter/14644665
for $12.
Or if you prefer ebay, this one is $10 + free shiping
http://www.ebay.com/itm/150668723235
Both are beginner multimeters, but will do the job required for your purposes.
My personal choice would be the Uni-T. PS. I have no affiliation or experience with the seller.Comment
I happened to be in the "local" electronics store today and saw the same UT33C for $29.99 CDN. I couldn't believe the markup when an USA seller sells the same product for $10 + free shipping. I went into the store because their sign advertised a "gigantic" blowout with prices up to 90% off. Talk about major false advertising.Last edited by retiredcaps; 01-30-2012, 09:35 PM.--- begin sig file ---
That particular multimeter (Equus) will work, right?
That markup is crazy, WOW!!! I see that you prefer the Uni-T but I don't have the patience to wait for it. I used to have an amazing multimeter, I believe it was a craftsman back when I was taking Automotive Technology (1995). However, one day when I was at work my "X"- Husband sold all of my tools to the local pawn shop, and it happened to be in with themComment
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
you might have to desolder the diodes to get an accurate reading but my monies on the ZD902 & ZD904 being bad. 3 or 4 times now in about 30 days i've seen the chirping transformer on a philips lcd. It seems the diode failing with the capacitors on this power supply design is starting to become problematic.Comment
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by Ifixstuff9I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector... -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug...Today, 10:04 AM -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... -
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
- Loading...
