Philips 42PFL5432D/37
--- begin sig file ---
--- end sig file --- -
Re: Philips 42PFL5432D/37
Did you put it in the right way? Negative to negative? Looks like it is reversed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I suspected that, but wanted to see a picture for confirmation. It is reversed when compared to the original picture at
https://www.badcaps.net/forum/attach...7&d=1325569041
Notice how both negative (the one with the stripe) side is facing towards the RoHS label.
If this cap were put in backwards in the power supply, it would have popped immediately.
Well, good thing you ordered a spare!Last edited by retiredcaps; 01-21-2012, 04:45 AM.--- begin sig file ---
--- end sig file ---Comment
Either way, it looks like those capacitors are for the audio output. Probably not critical to the operation of the TV. (Might make the audio not sound as good, though.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
edit:
Just so it is clear to the OP, these Capxon caps (circled in red) on the power board are the ones likely to supply power to the master and slave inverter boards (the missing 24V DC). Even though they are not bloated, they could be low on capacitance.
In lay terms, it is just like you cannot tell if an AA battery is dead or not by looking at it.
PS. Of course, regulars here will recommend changing all the caps, but we have to consider her inexperience in soldering.Last edited by retiredcaps; 01-21-2012, 06:39 AM.--- begin sig file ---
Changing capacitors on a single layer board is not difficult especially if the OP has succeeded at changing them on a 4 layer (at least) board. I was a noob to soldering before I started repairing stuff and I still struggle to repair 2 layer boards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Notice how both negative (the one with the stripe) side is facing towards the RoHS label........
Yep, I see it.......
And not only did I order ONE extra, I ordered ONE MORE EXTRA EXTRA...lol
So, the green caps on the power board need to be re-capped? That group of 3 measures abt. 1/2" x 1 3/8" tall, or 13x35, but the only thing I can see on them until I take them out is GF 105 P724.Comment
BTW, to clarify some lingo that you guys are using.........
What is a single layer board, 2 layer board, 4 layer board, and what is OP ?
THANX GUYS YOU ARE SOOO AWESOME !!!!!!!Comment
2 layer board,
4 layer board,
and what is OP ?Comment
This is (hopefully, the right one) for the 1500v35 Group of 3....
http://search.digikey.com/scripts/Dk...27483128860735
Still looking for the 16v.Comment
Possibly the one to replace the 2200uF16v
http://search.digikey.com/us/en/prod...2369-ND/613730Comment
First link is broken but second is perfect. Panasonic FM are good for these power supplies.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
How bout this one for the group of three?
http://search.digikey.com/scripts/Dk...27540165450379Comment
Still getting "part not found" for that link...
35V to replace 16V is fine (the rated voltage is just the maximum voltage the capacitor can work at); but check the dimensions as a higher rated voltage will mean a bigger capacitor size.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Panasonic FM is fine for the 2200uF 16V.
I would recommend these United Chemi-con KZE for the 1500uF 35V caps.
http://search.digikey.com/us/en/prod...1700-ND/756216
They are almost half the cost of Panasonic FR and they will fit. The FR is 16mm diameter and a whopping $1.74 each. UCC KZE are good caps as well.
BTW, the 2200uF 16V cap is obviously not part of the 24V rail because of the cap rating. The group of 3 are rated at 35V and provide the 24V DC output for the inverters.Last edited by retiredcaps; 01-21-2012, 05:23 PM.--- begin sig file ---
Now the decision you have to make is do you replace ALL the caps on the power board or just the larger Capxon ones (1500uF 35V and 2200uF 16V)?
Most of us here would recommend the former and then you know all the caps are high quality brand name ones.Last edited by retiredcaps; 01-21-2012, 05:25 PM.--- begin sig file ---
I Put these on my order, thank you. I am posting a list of all the other CapXons that I need.Comment
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by Ifixstuff9I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector... -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... - Loading...
