mec 16xx dump with info block
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #161
    Re: mec 16xx dump with info block
    https://www.badcaps.net/forum/showpo...4&postcount=28
    Use this to write back machine info. Info is on stickers at bottom. They start with 1S and 8S.
    But still, what did you do with RT809H to get it working?
    • cgtec
      • Feb 2014
      • 56
      • France
      • firmware and embedded systems
      #162
      Originally posted by 69d0b913
      After a lot of persistence I managed to remove the T14 bios password! I believe that few here know how to do it and no one shares it, I understand that certain types of information are not shared and are sold! But I persisted, and I come to inform you that the (Thinkpad T14 1st 20S1) was unlocked by an RT809H the only programmer I have, as I don't have access to a vertyanov. Here are the photos in the attachment, now I just need to invert the bios information, but I had taken a photo before.
      you shold be 290K zise of MEC1663 and you see the HXD the information in the last 2k
      • 69d0b913
        • Mar 2018
        • 146
        • BR
        • Computing, Machines, Motorcycles, Cars
        #163
        Now I have another problem, I already corrected all the information in the T14 bios, but now I have an error at startup (2202: Product Name is Invalid) I tried with lenovo maintenance utility v1.08, 1.11, 1.89 and it is not working, does anyone know how to fix?
        • 69d0b913
          • Mar 2018
          • 146
          • BR
          #164
          Finally, I managed to solve this damn T14 again. Now it works perfectly without a password and without computrace.
          • andrew25
            • Feb 2016
            • 224
            • Malawi
            #165
            Originally posted by Ghamidi
            try..
            can you share me ec dump for t490s... its urgent please
            • 69d0b913
              • Mar 2018
              • 146
              • BR
              #166
              send SN
              • andrew25
                • Feb 2016
                • 224
                • Malawi
                #167
                send sn
                s/n pc- 1b4v1y
                • 69d0b913
                  • Mar 2018
                  • 146
                  • BR
                  #168
                  s/n pc- 1b4v1y
                  this is not a valid serial
                  • andrew25
                    • Feb 2016
                    • 224
                    • Malawi
                    #169
                    pc1b4v1y
                    • 69d0b913
                      • Mar 2018
                      • 146
                      • BR
                      #170
                      pc1b4v1y
                      try..
                      After flashing the file you will need to fix the bios information with LMU..
                      • andrew25
                        • Feb 2016
                        • 224
                        • Malawi
                        #171
                        try..
                        lt me try, will give feedback
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1642
                          • France
                          #172
                          pc1b4v1y
                          questions: Lenovo does not support unlocking as there is more than 350 days of warranty left
                          • andrew25
                            • Feb 2016
                            • 224
                            • Malawi
                            #173
                            try..
                            write error, readed size 258kb.. your file 256kb
                            • 69d0b913
                              • Mar 2018
                              • 146
                              • BR
                              #174
                              What tool are you using to record? MEC1663?
                              • andrew25
                                • Feb 2016
                                • 224
                                • Malawi
                                #175
                                micro vision programmer rev 4
                                • 69d0b913
                                  • Mar 2018
                                  • 146
                                  • BR
                                  #176
                                  I don't know this tool, I use rt809h and it works fine, I unlocked a lenovo T14 10th ger with the same technique, T490s has MEC1663 as well as T14. The genuine file extracted from the original lenovo .exe file is 257kb, so you need to remove the first byte to adjust-it.
                                  • 69d0b913
                                    • Mar 2018
                                    • 146
                                    • BR
                                    #177
                                    If you were able to read the file, you can insert it back, as this will reset the MEC password. If not, you will have to insert the file I sent you and use the tool to fix the BIOS information.
                                    • 69d0b913
                                      • Mar 2018
                                      • 146
                                      • BR
                                      #178
                                      try with this one
                                        • 24654
                                        never heard of that programmer,can you post a picture of it
                                          • 24654
                                          on site warranty, it makes you wonder why anyone would be unlocking it hmmm
                                          • BigPete
                                            Panasonic LED TV Dead after EMMC dump
                                            by BigPete
                                            I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
                                            The dump was successful and the program finished without errors.
                                            I used a XGecu T48 to do the dump.
                                            I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
                                            One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
                                            I also shorted out the crystal of the adjoining ECU together and at one...
                                            03-15-2026, 03:08 AM
                                          • s.izadbakhsh
                                            Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
                                            by s.izadbakhsh
                                            I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
                                            Here are the motherboard details:
                                            • Model: Tongfang GM5AGFO MB V1.1
                                            • CPU: Intel 12th Gen (Alder Lake)
                                            The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
                                            Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
                                            Could someone please provide...
                                            06-24-2026, 09:10 AM
                                          • delosit
                                            Lenovo IdeaPad XiaoXin Chao7000-15ARR – only motherboard available, need help reconstructing clean BIOS
                                            by delosit
                                            I’m working on a Lenovo IdeaPad XiaoXin Chao7000-15ARR (Ryzen platform) and I need some help with BIOS reconstruction.
                                            Unfortunately I only have the bare motherboard (no original chassis, no sticker, no working system).
                                            The laptop came with black screen.
                                            What I have:
                                            - Original SPI dump read from the board (W25Q64DW 1.8V, 8MB)
                                            - Official Lenovo BIOS update (.CAP file)
                                            - Photos of the motherboard (front and back)
                                            - Board powers on, but with original dump it stays black screen
                                            What I tested:
                                            01-15-2026, 09:11 AM
                                          • Trademark
                                            Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                            by Trademark
                                            I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                            This is NOT a BIOS password removal request.
                                            I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                            Laptop Information
                                            • Model: Acer Predator Triton 16 PT16-51-99GL
                                            • Motherboard: DA0ZQDMB8AE Rev. E
                                            • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                            • Secondary
                                            07-22-2026, 08:57 AM
                                          • weisian
                                            VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                            by weisian
                                            I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                            1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                            2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                            03-12-2026, 05:54 AM
