mec 16xx dump with info block
  • izaak94
    • Mar 2019
    • 140
    • mexico
    #341
    Re: mec 16xx dump with info block
    How can I disable computrace? t490s with vertyanov
    • volinakis
      • Jan 2021
      • 2875
      • N/A
      #342
      Originally posted by roadrun
      Hello, can you explain how to find the MEC-Image in an bios update? And how I trim it correct. I can read the CHIP ID, but after verifying the checksum is 0 and RT809H says it is encrypted.
      I have downloaded an bios update for LINUX, which contain 2 cab files. One is an bin for EC with 760kb , which is to much for an MEC1633.
      open 760kb file with UEFITool, extract as is file GUID: EFDC6654-780A-4EAF-8D45-23EE514310A6 and you will obtain a 262.200 bytes file. Your file should be 262.144 bytes so you have to trim 1st 56 bytes. It seems I used an old bios update version and I had to trim only 32 bytes.
      • rbvndonh
        • Mar 2021
        • 162
        • B
        #343
        Originally posted by AAAC
        @RethoricalCheese
        This is probably the tool that you need to write data back, you will need a USB flash drive.
        I was able to add unit type and machine serial number, bo no way to add board serial number. Could you please help how to do it in T490?
        Thank you
        Edit: i forgot to type whole number from the sticker (8SS...) instead of shorten number from BIOS
        Case solved.
        Thanks for great topic about MEC1663
        • didouche1200
          • Oct 2016
          • 373
          • 82679911441
          #344
          how to read mec1663 with vetyanov ihave nm-c881 motherbord thanks
          • mazoot
            iFixit
            • Jan 2019
            • 41
            • Moldova
            #345
            if you have original jig you can read/write but if you have dumb ass SAS then you can't
            Kill the state in yourself and you will be free like a wind...
            • ranajee7750
              • Mar 2022
              • 11
              • pakistan
              #346
              I NEED HELP I HAVE 2 T490S AFTER Write FILE LAPTOP DEAD HELP ME PLEAS
              • didouche1200
                • Oct 2016
                • 373
                • 82679911441
                #347
                I tried svod3 it didn't work
                • rbvndonh
                  • Mar 2021
                  • 162
                  • B
                  #348
                  Why 4 cables, not 5 cables?
                  You move resistor after write?
                  • aldopc
                    • Jul 2017
                    • 477
                    • Chilito
                    #349
                    Originally posted by dimah77
                    Using RT809F, choosing MEC1633-256K , unlock done.
                    Don't choose MEC1633#ISP , it provide 192K file and password is not removed after write back.
                    Hello friend, can you send me the schematic you used to connect the rt809f programmer to the jtag connector please.
                    • Kodza
                      • Jun 2016
                      • 194
                      • South Africa
                      #350
                      Hello Guys I am trying to read the MEC 1663 on this laptop Lenovo X1 Gen8 NM-C661 Rev 1.0 with RT809H but it's giving me error Mec Chip ID:0xFFFFFFFF, ID verification error. I have moved the 10k reset resistor in pic 1 and I have also tried to put the 4 pull up resistors pic 2 and it's still giving same error, I also tried to connect reset pin to RT809H but no change, is there anything I am missing. I have done different models before with no problems. I have tried to select different part number on RT809H but same result
                      • Kayhan 17#
                        • Feb 2012
                        • 5
                        #351
                        Originally posted by LenBios
                        @syladrian
                        select MEC1653 from RT809H List, connect the charger and read the chip it should be 290kb.
                        Erase the chip and write the File back
                        (done 2days ago)
                        Hey mate, thanks for the tip with the charger, that was what made it possible for me to read, erase and write.
                        However my device is dead now, is that resistor really necessary or can i also bridge that? i lost it already as its so small
                        • Kayhan 17#
                          • Feb 2012
                          • 5
                          #352
                          My power button is lit, and the fan goes on for a few seconds, but the display stays black
                          Sorry, but I can't find the EDIT button in this forum
                          • elmasryomda
                            • Aug 2016
                            • 15
                            • egypt
                            #353
                            help please
                            lenovo t590
                            nm-b901
                            When connecting jtag and working read id this message appears
                            • Kayhan 17#
                              • Feb 2012
                              • 5
                              #354
                              Originally posted by elmasryomda
                              help please
                              lenovo t590
                              nm-b901
                              You also put on charger of notebook and then press Read ID?
                              • elmasryomda
                                • Aug 2016
                                • 15
                                • egypt
                                #355
                                When programming ENE, for example, we press read id, then in another step, the programmer asks to connect the laptop charger and follow the programming process
                                Are the steps for programming a mec different from that?
                                Is it possible that a problem occurs when connecting the laptop charger before pressing read id?
                                Thank you all
                                • elmasryomda
                                  • Aug 2016
                                  • 15
                                  • egypt
                                  #356
                                  Thank you all
                                  Hello!
                                  Anyone can help me?
                                  • alfredposadas09
                                    • Aug 2020
                                    • 342
                                    • Philippines
                                    #357
                                    may i see your jumper wires into the motherboard?
                                    • Kayhan 17#
                                      • Feb 2012
                                      • 5
                                      #358
                                      I got my T14 Gen1 revived and could set the serial number and stuff, but I am still receiving the following error.
                                      Error: 2204 Product name is invalid
                                      I don't know where I can set it, any idea?
                                      • aldopc
                                        • Jul 2017
                                        • 477
                                        • Chilito
                                        #359
                                        Hello, do it with this tool and watch this video. https://www.youtube.com/watch?v=gKL9JUTgo-g&t=519s
                                        • Kayhan 17#
                                          • Feb 2012
                                          • 5
                                          #360
                                          Thank you for the tool mate, indeed this one is different to the one I had, and it also has that Point 1 PLANAR Service in the Menu.
                                          At least, the stuff in the video was obsolete for me as I had that already and redid it as in the Video, no it did not work.
                                          But what has worked was that I selected the Planar Service, selected the brand name from the INI file, retyped the Serial number and gave 0407 for German keyboard and now its fine
                                          Keyboard Language IDs
                                          https://www.autoitscript.com/autoit3...SLangCodes.htm
                                          Thank you very much
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
