This topic has been answered.
  • mkdj
    • Mar 2025
    • 51
    • France
    Dear all,
    When pressing power button, power led lights up, but no image on screen, fan not spinning. Caps lock not responding. Laptop is charging fine however.
    No short circuits detected.
    Measures made: laptop is taking approximately 700mA when on. 3.3V, 5V and other lower voltages are present.
    I would appreciate if someone could take time to explain the issue, so that I can learn. But I would also appreciate if you can send me the BIOS dump with clean ME.
    A snapshot of my BIOS dump in ME Analyzer:
    After having cleaned the ME region following the winraid guide. I used the file named 12.0.37.1429_CON_LP_C_PRD_RGN.
    I have also attached my BIOS dump, if it can help.
    Regards,
    mkdj
  • Answer selected by mkdj at 10-30-2025, 04:32 AM.
    mkdj
    • Mar 2025
    • 51
    • France
    Hi guys,
    I got my answer: it was clearly not a BIOS issue, but an onboard RAM issue. When I apply pressure on the RAM chips before pressing the power button, laptop boots up. So I tried to reflow the RAM chip, and made things worse. But that is another story
    To stay on topic (and it may interest others), I still would like to know what you have done to produce the BIOS file. Can you tell me more?
    Regards,
    mkdj
    • peste
      • 14018
      • ROMANIA
      Don't post pictures unless asked...
      post S/N, full name and model, motherboard model, etc.
      • mkdj
        • Mar 2025
        • 51
        • France
        Thank you peste for your answer, and sorry about pictures, I didn't know.
        S/N of laptop is KBN0CV09N337466
        Full name and model is ASUS UX480FD
        I did not plan to remove the motherboard to get access to the motherboard model, is this mandatory in this case? If so, can you let me know why (in order for me to gain knowledge)?
        Regards,
        mkdj
        • peste
          • 14018
          • ROMANIA
          Regards,
          mkdj
          depending on the motherboard model we will send you the bios..also post the picture here, with a white square (QR code), inscribed on the motherboard ...
          • m1ch43lzm
            • Mar 2019
            • 1179
            • Peru
            The screenshot in the winraid guide is on an older version of MEAnalyzer, it's always Type │Extracted on a BIOS dump, what you want to check is File System State │Configured
            Initialized = extracted from a working board
            Configured = "Clean", it will become Initialized after successful first boot
            If you dump the BIOS after first boot, it should show Initialized on MEAnalyzer
            Regards,
            mkdj
            There's a barcode sticker on this board, like this:
            https://www.badcaps.net/filedata/fetch?id=2254754
            From your BIOS dump and S/N on ASUS website it's UX450FDX, ASUS always does this, where the BIOS type doesn't always match the laptop model or board number in the silkscreen, but the correct BIOS type is always on a barcode or QR sticker on the motherboard
            Try, clean ME + BIOS 313 + DMI inserted
            UX450FDX
            S/N KBN0CV09N337466
            • mkdj
              • Mar 2025
              • 51
              • France
              Dear m1ch43lzm,
              Thank you for your explanation and the BIOS file. I flashed the file you produced, re-soldered the chip, and the laptop booted up. Can you tell me what you did exactly to produce this file? I haven't tried the file I produced with FIT, as I did not want to re-solder and de-solder the chip again in case it did not work. I directly used the file you gave me.
              Anyway, I was really happy: I managed to get access to the BIOS.
              But then I noticed that the laptop froze, in the BIOS. I also saw some thin green horizontal lines flashing at some point. I turned the laptop off, and it booted again, but not instantly, only after 10 seconds. I was on the BIOS again. I turned the laptop off, inserted a Linux Mint USB stick, and turned the laptop on: I saw the GRUB menu, but when I chose Linux Mint the screen stayed black (with backlight on).
              I turned it off, and now I can't get it to boot. I have the same symptoms as before flashing the BIOS: screen stays black, laptop taking 700mA, voltages are present.
              Is it possible that the BIOS got corrupted one more time during the few minutes I used the laptop?
              If not, I wonder if this was really a BIOS issue in the first place. Could it be possible that the fact that I heated the board to re-solder the chip made the laptop work? And that now that the board is cool, it doesn't work anymore?
              Regards,
              mkdj
              • mkdj
                • Mar 2025
                • 51
                • France
                Hi guys,
                Regards,
                mkdj
                • m1ch43lzm
                  • Mar 2019
                  • 1179
                  • Peru
                  I used FIT 12.0.40.1434 and the ME region update contained in the BIOS update from ASUS
                  To get the ME region, open the BIOS with UEFI tool, expand AMI Aptio Capsule -> UEFI Image, in the last GUID expand until you get LzmaCompressed or LzmaCustomCompress or something like that (I'm not at my PC right now, don't remember the exact name), right click -> Body hex view, if you see FPT, then it's the ME region update
                  Right click, Extract Body, save, open with FIT, it will decompose and you will get "ME Sub Partition.bin" on a folder with the file name you saved the ME update
                  Close FIT, open FIT again and follow the winraid guide, use the ME Sub Partition.bin you got on the previous steps instead of the one from the repository
                  For the BIOS region there's this guide: https://www.badcaps.net/forum/troubl...t-by-razor_amd
                  After you trim the first 000-7FF you have to cut that to the length of the BIOS region, yours is 0x700000, check with UEFITool
                  Maybe faulty onboard RAM or a cracked solder ball in the area, heat or pressure may have made it work temporarily (i don't know if you removed the motherboard or not when soldering the BIOS chip)
                  EDIT: just saw your last reply, that confirms it, maybe You need to remove and reball the RAM
                  • mkdj
                    • Mar 2025
                    • 51
                    • France
                    Thank you for the detailed explanation, it helps me understand a bit more the process of editing BIOS files.
                    • LBTT1121
                      • Nov 2024
                      • 1261
                      • Việt Nam
                      Hi guys,
                      Regards,
                      mkdj
                      replace RAM onboard
                      • loopster
                        Need help cleaning ME region on Zbook 17 G1 bios dump
                        by loopster
                        Hello guys,
                        could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                        Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                        I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                        Error 10: Failed to open with processed commands.
                        Unable to open file: C:\Users\Elitebook...
                        06-16-2024, 09:57 AM
                        ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                        This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 06:31 AM
                      • cafjc2k
                        Need ec dump for Asus Zenbook 14X UX5401Z
                        by cafjc2k
                        Hello! I have an Asus UX5401ZA laptop with a damaged ITE
                        I need the EC dump please.
                        06-27-2025, 04:26 PM
                      • Destroyer-Br
                        [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
                        by Destroyer-Br
                        I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
                        When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
                        If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
                        After flashing it, the board does not power on — no signs of life.
                        I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
                        11-23-2025, 02:48 PM
                      • harshadcpalace
                        ASUS Zenbook 14 UM425IA BIOS dump
                        by harshadcpalace
                        Hii Brother
                        anyone have EC firmware for this laptop
                        ASUS Zenbook 14 UM425UA
                        post moved..
                        01-19-2025, 12:38 AM
