mec 16xx dump with info block
    Re: mec 16xx dump with info block
    Yeap, they are named "pogo pins".
      Keyboard connector is easier to use in some cases No need to solder anything except that one resistor.
        Originally posted by LenBios View Post
        this pins
        where i can buy it?
          which one works better, more reliable rt809 ?
          or is the svod3 just as good, keyboard connector sounds so good..
            When it comes to the keyboard connector, it doesn't matter if you use rt809 or svod3. That cable you need to make yourself anyway.
                Who here even uses SVOD3 and can successfully unlock all thinkpads with it? What's the secret? Thus far it seems just as bad as SAS JIG when it comes to that.
                  Do you use this adapter for rt809h for programming via keyboard ??::
                  https://www.eliptor.pl/index.php?p10...-rt809f-simple
                  if not please send what did u use.
                    No. I took some random flex from some random HP laptop, attached it to some random project board that had that same connector connected to pin header and used jumper wires to connect it to programmer. So it's totally diy.
                    I guess that adapter board would work aswell but not sure.
                      Yesterday there was an update for the programmator: "Vertyanov" which can read and write the eeprom area.
                      https://www.vss.store/magazin/product/programmator
                      Now you do not need to erase the entire firmware and you can edit only the eeprom area.
                      You can download it from here:
                      https://drive.google.com/file/d/1cWB...ew?usp=sharing
                        Which programmer works best just about to buy one
                        1. svod
                        2. rt809h
                        3.Vertyanov
                        which is most consistent and trouble free
                        thanks
                          Out of those 3, only rt809h has worked fine for me... Until somebody who owns a svod finally tells me how they use it to unlock lenovos...
                            Of these, only the programmer Veryanov can read and write eeprom, this is the DMI block where the password is stored.
                              @evserv have you used one to unlock a Lenovo ?
                                programmer Vertyanov yes used
                                  Also
                                  Anyone cleared the password on a x1 yoga 4th gen or x1 carbon 7th gen ?
                                  using this method..
                                  thanks
                                    Too bad it's difficult to buy the original but it's easy to buy the copy. And I guess it's not possible to just buy the software license to use vertyanov software with the copy board.
                                      Today I spoke with the author at your request ...
                                      Anyone can activate a clone of the programmer through the author of the programmer Vertyanov and make the programmer licensed. It will work with the latest software version 8.2 which can work with the eeprom area. The activation cost is $ 50.
                                        Now not difficult to buy original.i just order yesterday.i have also Sas copy programmer but copy is copy not work like original.
                                          Everyone understands that the original is the original!
                                          This is news for those who might want to activate their clone so they can work now.
                                          Once activated, the clone will work just like the original.
