  • Habble7
    • Jul 2023
    • 14
    • UA
    Suspected Cause:
    Troubleshooting Attempts:
    No hardware faults were found during physical inspection
    Attempted to integrate the official firmware into the original dump using ChatGPT
    Achieved only temporary LED illumination (5 seconds) in a repeating cycle, which further suggests BIOS-related issues
    Additional Notes:
    The current symptoms indicate potential BIOS corruption rather than hardware failure. The partial response after firmware modification suggests the repair path might involve:
    Finding a clean BIOS dump.
    Would appreciate any advice on:
    Where to obtain a verified BIOS dump for this model? Attaching the original BIOS dump from IC802 chip.
    Additionally attaching:
    Firmware dump from IC801 (EEPROM 24C512)
    Modified BIOS generated by ChatGPT (this version successfully activated the power LED indicator)
    And I also added the official firmware file
  • Habble7
    • Jul 2023
    • 14
    • UA
    I've captured a UART log from the TCON board (pin MDEBAG_TX and pin SDEBAG_TX​ baud rate 115200).
    The board has two processors — one labeled Master (ICT_M) and the other Slave (ICT_S).
    The messages are being repeated in a continuous loop.
    Below are the log results:
    Slave :
    ERROR : FW#1_CORE0 magickey error(0x0)
    BL1 EMMC FW#2 core0,1
    _________________ BTA0FW DQHD(VD) _________________
    Keil 5060183, Build(Apr 23 2023 14:06:03)
    Multi Inferface Slave SPI Init
    FW 1, CFG/MS 1
    Boot GPIO CNT Over
    system reset!
    _____ BTA0BL1 Core[0] EMMC_____
    Master:
    Multi Inferface Master SPI Init
    FW 1, CFG/MS 1
    Boot GPIO CNT Over
    system reset!
    • LoriLori
      • Oct 2025
      • Czech
      I could provide.
      I have changed t-con and trying to fix calibration now.
      Could you please re-upload images/dumps to confirm which chip is which?
      Thx
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
