mec 16xx dump with info block
  • superhansi
    • VAE
    anyone can share a (256kb) MEC dump with info block? (containing SER#,CON#,USR#...) or share the SVP offset (e.g. for DXE mapped its 0x1F400)? With SVP would be great.
    thanks
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: mec 16xx dump with info block
    If you want to unlock lenovo, use the patch method instead.
    • superhansi
      • VAE
      doesnt work on t490 and above
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Okay, thats where you should have started sadly I have no information on what you asked.
        I think there is a checksum aswell. So if you want to delete SVP, got to consider that aswell. But since I have not modified mec-s, I am not sure if it is important or even true
        Anyway, good luck with trying and let us know how it goes.
        • superhansi
          • VAE
          i only need a dump with this block, e.g. v**fix has but i dont wanna buy it...
          FYI: erasing+rewriting MEC to get rid of SVP works like a charm, unfortunately UUID,SN and such are "lost" due to the fact that this info block seems to be read protected in mec1663, with the offsets avail i could skip this block during erase/write and then I wouldnt need to rewrite it... so any dump should do thus i didnt mention T490 and later
          • xmasterboss
            • Apr 2014
            • 46
            Hy. I also have a T490s. Did you remove the chip or connected the programmer via wires to the motherboard? I can't find schematic or where the pins are. Also, did you succeed in removing SVP ?
            • Aditya11ttt
              • Feb 2019
              • 200
              • India
              • Knowledge
              try this try to find jtag1 connector name on the board only space will be there without connector !!
              • xmasterboss
                • Apr 2014
                • 46
                Thanks. Did you find the MEC Dump you were looking for? even if it's for sale i will buy and share it with you.
                • zomi
                  • Nov 2011
                  • 544
                  On these if you replace the mec ic will that solve the password ?
                  remove ic and put another one in ?
                  Is that confirmed solution ?
                  • iTec
                    • Oct 2017
                    • 32
                    Do you know which or where is the RST#? It's a T490 with the MEC1663
                    Any help is really appreciated.
                    • black0hackers
                      • Jul 2020
                      • 380
                      Where is point to connect?
                      picture add of T490S
                      • AAAC
                        • Jan 2020
                        • 459
                        • Mexico
                        • PLC's, uControllers, FPGA's, RE...
                        @black0hackers
                        Upload another picture of complete motherboard, as most of the JTAG signals may be already in a connector pads.
                        • So the JTAG signal wires will need to be soldered to this connector pads.
                        • You will need to move a very tiny PULL-UP resistor and make it a PULL-DOWN resistor to enable JTAG interface.
                        • Then you will need to locate RST# signal somewhere around MECxxxx chip by looking at schematic for this T490S, or by looking at another model schematic that uses the same MECxxxx chip part number (although I've read that this signal is not needed, someone with more JTAG experience may confirm/deny this).
                        • JOHNLAG7
                          • Nov 2014
                          • 20
                          • Greece
                          There is a photo t490 jtag1 and pins ,can someone draw the connection ?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            Looks like JTAG reset resistor is marked in red box. Move the resistor next to that capacitor on the empty pads.
                            I will test it tomorrow.
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              The resistor in my last picture was indeed correct. I can read/write MEC now.
                              The problem is, looks like my SAS JIG (which doesnt have MEC1663 in support list) is not able to clear the write-only area for some reason. What programmer should be used?
                                • 24681
                                A Vertyanov jig or SVOD3
                                • AAAC
                                  • Jan 2020
                                  • 459
                                  • Mexico
                                  @RethoricalCheese
                                  In your last post you mention you can read/write MEC now, but you describe your problem as is not able to clear the write-only area... have you tried to disconnect all sources of energy for 2-3 minutes? seems like this area is temporarily copied to volatile memory too (ram), so removing energy for a couple of minutes will do the trick.
                                  After this you will have to use Lenovo UEFI Maintenance utility to write Model Number, Serial Number, TYPE and other data for ThinkPad to be left as it was before programming MEC chip.
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    Thanks, will try. Did not try removing power for more than a few seconds.
                                    • keczuk
                                      • 102
                                      • WWW
                                      Hi
                                      I have question. I use svod3 for program this mec and when i read few times mec dump in hxd i see all dump are different. When i try write my clean ec dump i have error in veryfiication. Any idea how solve of my problem ?
                                      • AAAC
                                        • Jan 2020
                                        • 459
                                        • Mexico
                                        @keczuk
                                        Upload a picture of your setup. Have you added PULL-UP resistors to JTAG signals.
                                        At the time we did this one we couldn't find a schematic for T490, but X1 Carbon 6th Gen (T480s and others) have same MEC1663 EC/KBC chip so we used them as reference.
                                        • BigPete
                                          Panasonic LED TV Dead after EMMC dump
                                          by BigPete
                                          I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
                                          The dump was successful and the program finished without errors.
                                          I used a XGecu T48 to do the dump.
                                          I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
                                          One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
                                          I also shorted out the crystal of the adjoining ECU together and at one...
                                          03-15-2026, 03:08 AM
                                        • s.izadbakhsh
                                          Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
                                          by s.izadbakhsh
                                          I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
                                          Here are the motherboard details:
                                          • Model: Tongfang GM5AGFO MB V1.1
                                          • CPU: Intel 12th Gen (Alder Lake)
                                          The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
                                          Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
                                          Could someone please provide...
                                          06-24-2026, 09:10 AM
                                        • delosit
                                          Lenovo IdeaPad XiaoXin Chao7000-15ARR – only motherboard available, need help reconstructing clean BIOS
                                          by delosit
                                          I’m working on a Lenovo IdeaPad XiaoXin Chao7000-15ARR (Ryzen platform) and I need some help with BIOS reconstruction.
                                          Unfortunately I only have the bare motherboard (no original chassis, no sticker, no working system).
                                          The laptop came with black screen.
                                          What I have:
                                          - Original SPI dump read from the board (W25Q64DW 1.8V, 8MB)
                                          - Official Lenovo BIOS update (.CAP file)
                                          - Photos of the motherboard (front and back)
                                          - Board powers on, but with original dump it stays black screen
                                          What I tested:
                                          01-15-2026, 09:11 AM
                                        • Trademark
                                          Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                          by Trademark
                                          I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                          This is NOT a BIOS password removal request.
                                          I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                          Laptop Information
                                          • Model: Acer Predator Triton 16 PT16-51-99GL
                                          • Motherboard: DA0ZQDMB8AE Rev. E
                                          • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                          • Secondary
                                          07-22-2026, 08:57 AM
                                        • weisian
                                          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                          by weisian
                                          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                          03-12-2026, 05:54 AM
