DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
  • Mephysis
    • Mar 2025
    • Philippines
    Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
    I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
    • 25680
    Post both dumps and we`ll see.
    • Mephysis
      • Mar 2025
      • Philippines
      Here are the both dump files, appreciate the help Thank you!!
      • weisian
        VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
        by weisian
        I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
        1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
        2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
        03-12-2026, 05:54 AM
      • Bruggefan
        MD71-HB0 Firmware bricked of X557-AT2 NICs
        by Bruggefan
        Hi all
        I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
        I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
        What happened:
        - Did BMC firmware update in 2020
        - Doing this, my MAC adresses were cleared from my nics
        - Added MAC adresses with an eeupdate tool
        Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
        Since then, both my 10Gbit and my 1Gbit NICs stopped working.
        The amber led on the NICs is solid on, no matter...
        12-18-2025, 03:12 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • jovani1989
        HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
        by jovani1989
        HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...
        06-11-2025, 01:54 PM
      • FluxCapacitorish
        Aiwa TV-49UF30H (VM6901 / LC490EGY) stuck in bootloop, need install.img firmware dump
        by FluxCapacitorish
        I’m working on an Aiwa TV-49UF30H that is currently stuck in a bootloop. I’ve done a full teardown and diagnostics and wanted to see if anyone has a firmware dump or matching install.img.
        Symptoms:
        • Without USB: power LED flashes, TV immediately shuts off (bootloop)
        • With USB (install.img): green LED + grey screen (appears to enter recovery mode but does not proceed)
        What I’ve confirmed:
        • Main chipset: VM6901
        • Storage: eMMC (Kioxia THGBMNG5, integrated MCP under heatsink)
        • No SPI flash present on board
        • USB recovery bootloader is working and detects
        04-06-2026, 03:04 AM
