mec 16xx dump with info block
  • pokyss1
    • Mar 2019
    • 60
    • TUNISE
    #441
    Originally posted by volinakis
    Vous devez fournir votre fichier MEC et votre numéro de série. Il existe quatre versions pour ce modèle.
    Numéro de série Carte système : L1HF9C300MT
    Numéro de série de l'unité système : pf216zhf
    • pokyss1
      • Mar 2019
      • 60
      • TUNISE
      #442
      SYSTEM BORD SERIAL NUMBER:L1HFC9300MT
      SYSTEM-UNIT SERIAL BORD NUMBER:PF216ZHF
      • pokyss1
        • Mar 2019
        • 60
        • TUNISE
        #443
        good ficher
        • hoaca388
          Badcaps
          • Jan 2022
          • 12426
          #444
          What is your problem ? Both files are full 00, reading failed.
          • pokyss1
            • Mar 2019
            • 60
            • TUNISE
            #445
            i cant read this file i always ihave errors to read vertyanovo and ht809 houw can do .
            thax
            • pokyss1
              • Mar 2019
              • 60
              • TUNISE
              #446
              good file naw for unlock
              • hoaca388
                Badcaps
                • Jan 2022
                • 12426
                #447
                Try
                • pokyss1
                  • Mar 2019
                  • 60
                  • TUNISE
                  #448
                  Try
                  i try this bat the laptop not turne on
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12426
                    #449
                    Does the laptop work with the original file ?
                    • pokyss1
                      • Mar 2019
                      • 60
                      • TUNISE
                      #450
                      SORRY I HAVE errer
                      sorry i have errer withe file this fil withe machin working good
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12426
                        #451
                        SORRY I HAVE errer
                        This is what you read, from top to bottom.
Name:	2025-04-15 16_27_48-HxD - [F__MEC1633_256K_20250415_15118.BIN].png
                        • nesredin
                          • Feb 2018
                          • 40
                          • ethiopia
                          #452
                          Originally posted by vuquanghoanh
                          I followed Maxpower3's instructions and it worked. Follow him, you will also succeed.
                          Let's thank Maxpower3.
                          hello how to read and write with rt809f mec1663 with this x1 carbon
                          NM-B861 REV 1.0​
                          • pokyss1
                            • Mar 2019
                            • 60
                            • TUNISE
                            #453
                            NM-B861 REV 1.0​
                            yes
                            • khaledmosa99
                              • Dec 2014
                              • 75
                              • egypt
                              #454
                              hello i got thinkpad t14 gen1 20s0 with burn mec1663 i replaced it with a new one i got the jtag connection with my vertyanove programmer try to cut ec when i write it i got blinking white led 3 times only can some one help me to fined the file flash+epperom
                              nm-c931 rev 1.0 my s/n PF2A58EN
                              thank all for help
                              • saman mawlod
                                • Apr 2022
                                • 55
                                • iraq
                                #455
                                [QUOTE=hoaca388;n3615433]
                                lenovo p52
                                type 20ma-s6hh00
                                sn pf-1ns7hl
                                mec1653
                                can unlock
                                • jaglion19
                                  • Oct 2017
                                  • 110
                                  • TURKEY
                                  #456
                                  I have a Dell e7440 la-9591p motherboard, no matter what I did on the device, I couldn't start it. It uses MEC5075. On the first page, someone shared the jtag paths for tx390, I searched from the schematic and found the same legs. Can I make this read by soldering it in the same way as SWOD? or with rt809f? or what are its legs? Also, I think the place where it says rp1 is for jtag, but there is a resistor with 103 written on it. Can I remove it, solder the 5 paths and 3 gnds and read it?
                                  • djacksod
                                    • Jan 2017
                                    • UKRAINE
                                    #457
                                    I am posting the mec1663 Lenovo T14 nm-c931 1st gen intel 10th that I read, the eeprom address where the password is located is at offset 0x300.
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1356
                                      • France
                                      #458
                                      lines 350 and 360 should not be deleted
                                      It's easier to find your way around with the decrypted file
                                      • antongoikoetxea
                                        • Aug 2019
                                        • Valencia
                                        #459
                                        Thanks to everyone for the help.
                                        My case was a ThinkPad X1 Carbon Gen 7 with motherboard NM-C661. I used an SVOD3 and the pinout from the picture I’m attaching. The reset is not needed when using the pull-down resistor.
                                        In the SVOD software I selected EEPROM, and once the dump was read I changed the data from 0x300–0x34F to FF. After reprogramming, the password issue was solved.
                                        Many thanks again to all, and I hope this can help anyone else who has the same model.
                                        • osman68i
                                          • May 2015
                                          • 354
                                          • The Netherlands
                                          #460
                                          Hi Badcaps Team,
                                          T15 Gen1 with bios lock.
                                          SN: PF2RVTMS
                                          I have checked the dump but I cant find the location of the pass
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
