Hp elitebook 840 g5 bios password
AgainAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Thank you very much hoaca388 , with this file the laptop starts in "manufactured" mode (I guess that's how it should be?), after filling in the missing data in the BIOS, everything works as it should. I would like to know how to unlock the 32MB bios myself, but it's probably a secret?
Thank you again for your help and best regards
HP Elitebook 840 G5
Serial Number : 5CG9183NQT
Password Remove please
Attaching Backup BiosAttached Filesif you find these attachements useful please consider making a small donation to the site
attaching other chip
only flash this ec. use RC unlocker in all HP 16MB ec next time.Attached Filesif you find these attachements useful please consider making a small donation to the site
If it is attach with pin 6 than its a SPI_CLK resistor
you can take a reverence of any schematic which has 25Q128JVPQ
(you can check pin 5 resistor value and place same ohm on missing resistor )Last edited by qayyum786; 02-25-2024, 09:44 AM.Comment
Removing BIOS Password please
HP Elitebook 840 G5
S/N : 5CG936B9WW
Attaching BIOS dump of MX25L256 Chip
Thank you...Attached Filesif you find these attachements useful please consider making a small donation to the site
i don't know why i cant upload directly a file so i attached this link instead.
no need EC file.
first boot press f10 apply factory setting to defaults and exit, and 2nd boot reset security settings to defaults.
here's your DMI info use BCU:
Serial Number: 5CG936B9WW
Product Number: 2FA64AV
CT Number: PGWHQ00WBCQ2YU
Description: HP EliteBook 840 G5
build_id: 17WWCSCT601#SABD#DABD
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkjh.Rq
MAC Address: 04-0E-3C-CC-6D-C6
Thank you very much!
Your patched bios file worked perfect without touching the EC chip.Comment
RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
computro 6050a2945601-mb-a01(1a)
HP Elitebook 840 G5Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
- Loading...
