TONGFANG "GM7TG7P" Bios Password Problem?
  • traxformania
    • Nov 2023
    • 3
    • Turkey
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries are removed, so I thought I'd try it anyway.
    -I dissambled the laptop and checked if there was any bios reset button/switch/jumper, but I couldn't see it.
    -CMOS reset by a hotkey. Didn't work.
    I see an instruction that states there is a method can be used to overwrite a faulty or incompatible BIOS with a new ROM under certain circumstances.
    Method is described like this :
    Code:
    5. BIOS recovery with Recovery ROM on USB drive
    This method can be used to overwrite a faulty or incompatible BIOS with a new ROM under certain circumstances.
    For this purpose, the laptop is started in a special mode to search for a suitable BIOS ROM on a USB stick. The USB
    stick must be formatted with FAT32 and the ROM must have a specific file name. Data carriers with USB-C
    connection are unfortunately not suitable.
    Prepare a USB stick with FAT32
    The USB stick can follow the USB 2.0 or USB 3.0 standard. It helps if the USB stick has a status
    LED that flashes during read and write operations.
    The USB flash drive may contain other files – but it is better to format the stick for this process,
    as a fairly full USB stick may cause read problems during the recovery process. Make sure that
    the USB stick is formatted in FAT32. All data on the USB stick is deleted.
    Correct BIOS ROM with correct file name
    A BIOS update in our download portal is usually a ZIP file with various contents. The ROM is
    usually the largest file in the ZIP, with over 10 megabytes file size. The ROM file can have different file extensions,
    such as . BIN or . ROM, but on some systems it does not have a typical file extension. The correct file name usually
    contains part of the version number of the BIOS update, but not necessarily the complete version number.
    For some BIOS updates, the ZIP file contains a "recovery" subfolder. The ROM with the correct file name is already
    stored there. If this is not the case with your model, please contact our support.
    If you are not sure how to locate the Recovery ROM or if it has the correct filename, please contact support.
    Hotkey combination
    • Insyde BIOS: [Fn] + [B]
    • Aptio BIOS: [Ctrl] + [Home]
    The combination "Ctrl+Home" might not be obvious to find. On many laptops, the [Home] function is integrated into
    the numeric keypad. The [Fn] key does not need to be pressed because the [Pos1] function is a primary function as
    long as Numlock is disabled – which is already the case by default when booting.
    For laptops with Aptio BIOS, which do not have a dedicated [Home] function, you can hold down the right [Ctrl] key
    and the [Home] key in the numeric keypad with one hand.
    Step-by-step instructions
    • Prepare the USB stick with the BIOS ROM in the root directory
    • Turn off the device completely, if necessary by pressing and holding the power button for about 5 seconds.
    • Connect the USB flash drive to one of the USB ports.
    • Press the power button and start holding down the key combination as early as possible. You can also hold
    down the key combination before pressing the power button.
    • Keep holding down the keyboard shortcut – but you can release the power button.
    • Once you see a message on the screen, you can release the keyboard shortcut.
    • Ideally, you will now see a progress bar that represents the recovery process.
    If you are sure that you have the correct ROM file with the correct file name and if this process still does not work,
    please try a different USB stick.
    How can I found recovery / bios file for my laptop?
    The warranty of my laptop has expired and I do not want to give it to the service because even for such a simple thing, the laptop will probably remain in the service for a long time and they will ask for more money.
    This is my first time opening a topic on the forum, I have read the forum rules, but I'm sorry if I still violate any rules.
    Thanks.
  • mon2
    • Dec 2019
    • 14631
    Re: TONGFANG "GM7TG7P" Bios Password Problem?
    Fault may be with your internal keyboard.
    Test with an external usb keyboard.
    • traxformania
      • Nov 2023
      • 3
      • Turkey
      I already tried but it didn't work.
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
      • Sebastian Codrean
        BIOS file for ASUS F542UN laptop
        by Sebastian Codrean
        Hello to all of you! I need help with a BIOS file.
        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
        02-20-2025, 10:25 AM
