Hp elitebook 840 g5 bios password
  • rddube
    Aspiring Expert
    • Jun 2013
    • 950
    Originally posted by angeleyes
    I have no idea how you came to this conclusion. I didn't even say I was running a Windows OS. I'm using Linux Mint.
    Well why in the world would you have it open all the time on the BIOS password? That's what operating systems are for, password protection. But anyhow, did you test your keyboard, i.e. plug in a known USB keyboard and try your password this way?
    • angeleyes
      • Apr 2025
      • 5
      • Nigeria
      #382
      You may be right, but I prefer such a defense-in-depth. The other night, a thief cut a hole through my window while I was sleeping, trying to steal my phones from my bedside using a long stick. But I woke up before any damage could be done.
      I initially thought as much, but didn't think that was the issue. The same password that didn't work happened to work again. I have not restarted my laptop again since then, as I always put it in sleep mode. I don't know if the problem will continue to persist or not. ​
      • ridouane
        • Mar 2019
        • 24
        • casablanca
        #383
        HP Elitebook 840 G5
        Serial Number : 5CG8524YZM
        ProID:3JX27EA#ABE
        Password Remove please
        Attaching Backup Bios
          • 21692
          Originally posted by ridouane
          HP Elitebook 840 G5
          ProID:3JX27EA#ABE
          RCUnlocker
          https://www.badcaps.net/forum/troubl...17#post3560417
          https://www.badcaps.net/forum/troubl...ls#post1622423
          • ridouane
            • Mar 2019
            • 24
            • casablanca
            #385
            Thank you very much my brother Puce SMD.
            • Zadiq
              • Mar 2020
              • 7
              • Nigeria
              #386
              840 g5 Please unlock
            • danito
              • Jun 2016
              • 1070
              #387
              read the other chip aka 256
                • 21692
                RCUnlocker
                • Toha378
                  • Feb 2023
                  • 6
                  • ukraina
                  #389
                  HP EliteBook 840 G5 (Board ID 83B2) — need clean dump for 25Q128JVPQ (EC/SureStart)
                  I need a clean dump for the second SPI chip (EC / SureStart) on an HP EliteBook 840 G5.
                  Laptop details:
                  - Model: HP EliteBook 840 G5
                  - Board ID: 83B2
                  - System BIOS: Q78 (version 01.09.01)
                  - Main flash: W25Q256JVEQ (32 MB) — I already have a clean working dump with my serial numbers.
                  - Secondary flash: 25Q128JVPQ (16 MB, EC) — my dump is attached below.
                  Symptoms: The laptop works only with the main 32 MB chip replaced, but I suspect the EC/SureStart flash (25Q128JVPQ) is corrupted.
                  Since HP SureStart uses this chip, I need a proper clean dump to reprogram it.
                  Could someone please share a clean working EC dump for this exact board (ID 83B2)?
                  Any help would be greatly appreciated. Thanks in advance!
                  Добрый день!
                  Ищу чистый дамп для второй SPI-флешки (EC / SureStart) ноутбука HP EliteBook 840 G5.
                  Данные по ноутбуку:
                  - Модель: HP EliteBook 840 G5
                  - Board ID: 83B2
                  - System BIOS: Q78 (версия 01.09.01)
                  - Основная флешка: W25Q256JVEQ (32 МБ) — дамп уже собран, чистый с моими серийниками.
                  - Дополнительная флешка: 25Q128JVPQ (16 МБ, EC) — мой дамп прикладываю ниже.
                  Симптомы: ноут работает только после прошивки основной флешки, но подозреваю, что дамп EC (25Q128JVPQ) повреждён.
                  Так как HP SureStart использует этот чип для восстановления, нужен правильный чистый дамп, чтобы прошить его программатором.
                  Буду благодарен, если кто-то поделится рабочим чистым дампом под эту модель (Board ID 83B2).
                  Заранее спасибо!
                  • peste
                    • 13451
                    • ROMANIA
                    #390
                    post S/N, product number,post the contents of the bios chip even if it is corrupted..
                    ,etc.
                    • Toha378
                      • Feb 2023
                      • 6
                      • ukraina
                      #391
                      Серийный номер: 5CG9207TJ1
                      W25Q256JVEQ (32 МБ)
                      I'll post the second one tomorrow because I didn't have time to take it off today.
                      • Toha378
                        • Feb 2023
                        • 6
                        • ukraina
                        #392
                        here is the second one as promised
                        • krogs214
                          • Sep 2017
                          • 84
                          • Philippines
                          #393
                          Hi anyone can help remove bios password
                          HP Elitebook 840 G5
                          SN: 5CG9050GJH
                        • krogs214
                          • Sep 2017
                          • 84
                          • Philippines
                          #394
                          Thank you
                          already removed via rcunlocker
                          but everytime i bootup there is MEBx Login
                          anyone how to remove this ?
                          • Toha378
                            • Feb 2023
                            • 6
                            • ukraina
                            #395
                            Разблокировать биос:
                            на флешке 128мб заменить все на FFF-ки
                            Начало блока:37000
                            Конец блока: 37BE0
                              • 21692
                              Начало блока:37000
                              Конец блока: 37BE0
                              Please post in english !!!
                              • senz1693
                                • Jul 2016
                                • 19
                                • indonesia
                                #397
                                Hi need help remove bios password, i already try using RCunlocker with 16mb chip, but the password still there.
                                here i upload both 16mb and 32mb original file.
                                HP Elitebook 840 G5
                                SN: 5CG9052M48
                                • peste
                                  • 13451
                                  • ROMANIA
                                  #398
                                  HP Elitebook 840 G5
                                  SN: 5CG9052M48
                                  try..
                                  • Toha378
                                    • Feb 2023
                                    • 6
                                    • ukraina
                                    #399
                                    Unlock the BIOS:
                                    Replace all 128MB W25Q128 flash drives with FFFs
                                    Block start: 37000
                                    Block end: 37BE0
                                    • senz1693
                                      • Jul 2016
                                      • 19
                                      • indonesia
                                      #400
                                      Originally posted by peste
                                      try..
                                      its work, thank you sir
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                        I'm trying to reset my bios without success.
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        >Read BIOS guides, methods, resources and tools
                                        Ack
                                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                                        Ack
                                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                        01-30-2025, 04:26 AM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
                                      • Wutru
                                        HP Elitebook 820 G4 BIOS repair assistance required
                                        by Wutru
                                        Hi guys,
                                        If someone would be able to provide some expertise, I'd be very grateful.
                                        BIOS Corruption - Cause
                                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                        09-06-2025, 10:32 AM
