  • zenius
    • Dec 2024
    Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also, I am not sure any of the setup_var* changes actually worked- they stay persistent after reboot, but I changed a few options that did not seem to take effect.
    Two key requests:
    1. Remove the BIOS password and reset my device to the manufacturing state where I can re-enter my details.
    2. If possible, help me remove/bypass "AMI v2 protected ranges" which guard all SMM modules in my BIOS to allow for modifications. This is NOT Intel boot/bios guard, which afaik is fused.
    For #1, I took a look at some old threads, including using HxD to diff BIOS password unlock images from other user requests. I also tried an automatic 8FC8 BIOS unlock patcher recently posted on this forum [1]. Both approaches failed (former could not find equivalent data in my BIOS dump to modify, latter the patterns were not found in my BIOS). I also tried some SMM driver modifications, but ran into #2.
    For #2, I am able to flash all addresses, but touching any SMM region in yellow under UEFITool (not red/boot guard) leads to Dell BIOS recovery prompt. I am fairly confident that my image with a modified SMM driver was well-formed. What is quite frustrating is that many of these SMM drivers are not protected on other similar Dell device BIOS'. I looked at a Dell XPS 13 9350 image and Latitude 3440 image in UEFITool, both still had AMI protection, but not on most SMM drivers. I would greatly appreciate it if you could take a look at this issue beyond just the BIOS password.
    Please let me know if I can provide anything else. Thank you.
    [1] https://www.badcaps.net/forum/troubl...l-8fc8-patcher
  • zenius
    • Dec 2024
    Oops, forgot to attach my dump. Here it is:
    • hoaca388
      Badcaps
      • Jan 2022
      • 12684
      Try
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • zenius
        • Dec 2024
        Originally posted by hoaca388
        Try
        I sincerely appreciate the prompt response! I also love the creative approach of swapping the SMI BIOS and Boot Guard regions with one from another firmware image. Unfortunately, while this unlocked my admin password to change bios options, the other firmware region you swapped with has a similar AMI v2 Protected Ranges hash file covering most SMM drivers. This is the real issue as I was already able to boot into my OS without the Admin password.
        I tried flashing an image with an SMM driver modified (high confidence it is well-formed, replaced/rebuilt with UEFITool v28 to tmp file, then exported FFS for use in MMTool on your image). It resulted in the familiar Dell BIOS recovery screen. As a suggestion, many other Dell firmware images have most SMM drivers in a region outside the AMI protected ranges hash file. Two examples are a Latitude 3440 and Dell XPS 13 9350 firmware image. I wonder if we can find a firmware image for another Dell device with near identical key hardware components (like EC), and swap my laptop's with the less restrictive but legitimate boot guard & BIOS region, similar to what you have done here.
        In case it helps, I have attached an updated dump from after my laptop booted successfully into your original modified image (without my SMM driver change). Also, I ran chipsec on your image and compared to output on my previous image I modified with FIT. Of note, your image was detected as having ME in manufacturing mode, mine had not. I don't know if this helps defeat Dell/AMI bios guard.
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • TopPop
          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
          by TopPop
          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
          12-14-2025, 09:40 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • Deniz
          IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
          by Deniz
          Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
          I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
          I had the BIOS cleaned, but the issue was not resolved and there was still no image.
          Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
          After that, I tried to update the...
          01-27-2026, 06:56 AM
