Hp elitebook 840 g5 bios password
Re: Hp ellİtebook 840 g5 bios password
Hi.
I've used HPunlocker multiple times and never had a problem. Now I'm trying to unlock the 840 G5, the program generates the _unlocked file but after playing it to memory the password is still there. will you help?Last edited by SMDFlea; 04-10-2023, 12:54 PM.Comment
Upload the dump from the second bios chip.
It's not a good approach to solve the matter in this case.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
This is my secondary dump.
Would you share a solution for the future?Attached FilesPremium supporters get full download access and other benefits.
Read that Post to learn:
https://www.badcaps.net/forum/showpo...40&postcount=2----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Maybe I'm blind, but the HP BIOS update tool only shows me two options.Read that Post to learn:
Update or create a recovery flash drive.Comment
Did you read the Post? You should to use a Hardware Programmer in order to take a Backup for your BIOS Chips (Main & EC).----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi there! I am attempting to remove the bios password from a decommissioned Elitebook 840 G5. I came across post #56 of this thread which fit my laptop's criteria exactly, and followed the directions offered by the response in post #57. I used a ch341a with the BIOS chip soldered onto the adapter to read and verify the original bios and then used the HPUnlocker v1 program to generate the unlocked bin file (both attached here). I rewrote the unlocked file to the chip and then soldered back into place on the motherboard.
After putting it together, I'm now experiencing an issue where the capslock button light and power button are flickering (see image ezgif-2-da60db5cdd.jpg). I read that this might be an indication of a bios corruption and I tried to do the Win+B during startup to see if it would reset it, but to no avail. I'm hesitant to desolder and reflash the bios again due to how difficult it was for me to get it back into place, but I will do it if it means I'll have a working laptop again.
If anyone could provide me guidance, I would greatly appreciate it. Thanks for your time.Last edited by SMDFlea; 04-10-2023, 12:54 PM.Comment
here is your unlocked fileAttached FilesPremium supporters get full download access and other benefits.
these are my bios files. maybe they are damaged. it behaves the same with themComment
Wich one that you have unlocked , with wich tool !Comment
by chriswfrye21Hi everyone,
I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
Model: HP 255R 15.6 inch G10 Notebook PC SK...-
Channel: BIOS Requests ONLY!
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by ShadeRunnerHi everyone,
I’m a student currently locked out of the BIOS on my HP EliteBook 830 G6. I bought the laptop second-hand, and the previous owner didn't provide the password. I really need access to the BIOS to change storage settings and boot orders for my studies.
System Details:- Model: HP EliteBook 830 G6
- Processor: Intel Core i5 (8th Gen)
- Serial Number: 5CG0080LKD
- Halt Code (from 3rd fail): qeh11u1kst
I'm hoping someone here can help me generate an SMC.bin file or provide a master password that works for this generation. Any guidance on how to get back...-
- Loading...
