pls help me to my locked file
Hp elitebook 840 g5 bios password
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Try to clean your self first https://www.badcaps.net/forum/troubl...elines?t=88758
if your still having issues send the 16mb bios file.Comment
Hello!
I unlocked the bios password with RCUnlocker of the 840 G5, but since then every time I turn it on I get an HP Endpoint Security Controller problem. I am attaching the backup copy of the 32MB chip, please help me with the solution!
HP EliteBook 840 G5
PN: 2FA66AV
SN: 5CG8253GZDAttached FilesPremium supporters get full download access and other benefits.
Last edited by Echoo; 05-30-2024, 12:49 AM. Reason: I tried to write about this in the appropriate topic, but there was no reply. Here it is disassembled on my desk...Comment
flash this main and the original locked EC.Hello!
HP EliteBook 840 G5
PN: 2FA66AV
SN: 5CG8253GZD
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
after following my instruction to get rid of Manufacturing mode. use BCU. or flash the original main.Attached FilesPremium supporters get full download access and other benefits.
Thank you for your help! Perfect!Comment
Could someone please help remove the password from the attached files?
I've attempted using the unlock tool, but it still prompts me for the password.
Attached are the files from both ICs and the unlock files as well.
SN: 5CG85033FH
Model: HP EliteBook 840 G5
Motherboard: COMPUTRO-6050A3079801-MB-A01
Thank you!Attached FilesPremium supporters get full download access and other benefits.
read the rules..https://www.badcaps.net/forum/troubl...before-posting
post the S/N, , the motherboard model, the full name and model of the laptop,
etc.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Thank you - I update the post with requested info
etc.Comment
only flash this 16mbCould someone please help remove the password from the attached files?
SN: 5CG85033FH
Thank you for your help. I followed your instructions but encountered an issue. I received a message indicating that the BIOS blocks don't match and that I need to update the BIOS. However, when I reached the battery screen (the battery capacity error message due to the battery not being connected), the system froze.
Upon restarting the laptop, I observed six orange flashes and then nothing happened. I removed the chip again and compared the files, noting that some changes had been made.
Do you have any suggestions on how to proceed?Comment
Serial Number: 5CG85033FH
Product #/SKU: 3UP81ET#ABU
CT Number: PGWNQ00WBBO1RJ
Description: HP EliteBook 840 G5
BuildID: 17WWCSBT602#SABU#DABU
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhkjh.GE
MAC Address : E4:E7:49:9E:89:F2Attached FilesPremium supporters get full download access and other benefits.
Hi request to unlock bios HP ELITEBOOK 840 G5
i tried to unlock with hp unlocker but password still there.
productid 6AU11UP#ABA
SN 5CG9292NXS
i have read most of posts about unlocking the bios but i am so confused could you please tell me all steps just for my case
i am attaching dump fileAttached FilesPremium supporters get full download access and other benefits.
HP EliteBook 840 G5Hi request to unlock bios HP ELITEBOOK 840 G5
SN 5CG9292NXS
Serial_5CG9292NXS
Sku_6AU11UP#ABA
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkj4jh.mh
Build Id_17WWCSCT601#SABA#DABA
CT Number_6GPRE05WYAS7WBAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
I did reprogram the main chip with bin file you provided but i also de assembled and reprogrammed the chip which is located at back of board. Saved original bin then unlocked with hp unlocker. But laptop doesn’t power up now no sign of light even the charging plug on. No light on keyboard.Comment
Hi. Somebody help please. BIOS PASS --- Thanks a lot!
HP EliteBook 840 G5
Chip -- W25Q256JV
S/N -- 5CG9052CP3
MB -- L15516-601
P/N -- 2FA64AV
try..Attached FilesPremium supporters get full download access and other benefits.
There is the original bios password attached, can you please help me clear it. I installed another bios and it shows the first image very late
840-G5
P.id: 4RU26EC#AB8
SN: 5CG91214GLAttached FilesPremium supporters get full download access and other benefits.
HP EliteBook 840 G5
Serial_5CG8471ZB4
Sku_4RU28EC#AB8
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saEapaqauawbUcAdUdpdqeMfXgdhKhkjh.f
Build Id_17WWCSBT602#SAB8#DAB8
CT Number_6GPRF06TZBYBP7Attached FilesPremium supporters get full download access and other benefits.
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
Channel: BIOS Requests ONLY!
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by ShadeRunnerHi everyone,
I’m a student currently locked out of the BIOS on my HP EliteBook 830 G6. I bought the laptop second-hand, and the previous owner didn't provide the password. I really need access to the BIOS to change storage settings and boot orders for my studies.
System Details:- Model: HP EliteBook 830 G6
- Processor: Intel Core i5 (8th Gen)
- Serial Number: 5CG0080LKD
- Halt Code (from 3rd fail): qeh11u1kst
I'm hoping someone here can help me generate an SMC.bin file or provide a master password that works for this generation. Any guidance on how to get back...-
by DudebromanHello Hello,
I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
- Loading...
