Hp elitebook 840 g5 bios password
AgainAttached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Thank you very much hoaca388 , with this file the laptop starts in "manufactured" mode (I guess that's how it should be?), after filling in the missing data in the BIOS, everything works as it should. I would like to know how to unlock the 32MB bios myself, but it's probably a secret?
Thank you again for your help and best regards
HP Elitebook 840 G5
Serial Number : 5CG9183NQT
Password Remove please
Attaching Backup BiosAttached FilesPremium supporters get full download access and other benefits.
attaching other chip
only flash this ec. use RC unlocker in all HP 16MB ec next time.Attached FilesPremium supporters get full download access and other benefits.
If it is attach with pin 6 than its a SPI_CLK resistor
you can take a reverence of any schematic which has 25Q128JVPQ
(you can check pin 5 resistor value and place same ohm on missing resistor )Last edited by qayyum786; 02-25-2024, 09:44 AM.Comment
Removing BIOS Password please
HP Elitebook 840 G5
S/N : 5CG936B9WW
Attaching BIOS dump of MX25L256 Chip
Thank you...Attached FilesPremium supporters get full download access and other benefits.
i don't know why i cant upload directly a file so i attached this link instead.
no need EC file.
first boot press f10 apply factory setting to defaults and exit, and 2nd boot reset security settings to defaults.
here's your DMI info use BCU:
Serial Number: 5CG936B9WW
Product Number: 2FA64AV
CT Number: PGWHQ00WBCQ2YU
Description: HP EliteBook 840 G5
build_id: 17WWCSCT601#SABD#DABD
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkjh.Rq
MAC Address: 04-0E-3C-CC-6D-C6
Thank you very much!
Your patched bios file worked perfect without touching the EC chip.Comment
RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
computro 6050a2945601-mb-a01(1a)
HP Elitebook 840 G5Attached FilesPremium supporters get full download access and other benefits.
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
Channel: BIOS Requests ONLY!
by DudebromanHello Hello,
I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
- Loading...
