HP Elitebook 820 G4 BIOS repair assistance required
  • Wutru
    • May 2024
    • 8
    • Netherlands
    Hi guys,
    If someone would be able to provide some expertise, I'd be very grateful.
    BIOS Corruption - Cause
    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC. So the BIOS was not corrupt but at least no video out.
    EliteDesk Repair
    I had this exact same situation happen to me (because then I did *not* include the MSFT keys) on a HP EliteDesk 800 G2 DM, which I managed to repair by desoldering the SPI ROM and replacing the BIOS region with UEFITool 0.28 with a fresh BIOS region extracted from an HP update executable- That is all I had to do.
    Their behaviour was fully shared between the Elitebook and Elitedesk, no video, but able to get in BIOS and trigger beeping with Esc or F10.
    My tools:
    - CH341A (3.3V modification)
    - EZP2023+
    - UEFITool A78 (latest I think)
    - UEFITool 0.28
    Elitebook Repair
    Because of this earlier success, I went straight ahead with this machine. Desoldered the ROM, dumped it and replaced the BIOS region, and resolder it.
    Then it had the following behaviour:
    1. When connecting power (battery or ext. power), the charging LED flashed white/amber (white/orange) for a few seconds.
      1. This would indicate, according to the 820 G4 Maintenance and Service Guide (page 70): "The embedded controller is recovering the boot block or DXE. Since it takes 10 sec. or so to load the DXE image and get video in the DXE case, this blink code is necessary. (SureStart)"
    2. Then it went off for a few seconds, and then the charging LED came back on solid amber/orange, either with or without battery present.
    3. But the machine would not start up, no power LED, no fan spin nothing.
    4. Removing the power, holding the power button, windows + B, or other button combinations etc. all did not work.
    5. When reconnecting the power, I experienced the same as step #2 & step #3.
    I then went ahead and removed the board from the case and disconnected the CMOS battery from a few minutes. The behaviour changed:
    1. A lot more LEDs(I think WiFi, charging and power) came on, and stayed on.
    2. The Power LED came on when pressed, and after a few seconds the fan started spinning up to max speed
    3. Still no video.
    I have backup of the original dump, (triple verified before reprogramming anything) and the repaired BIOS. There is a separate 64MBit EC ROM and the Embedded controller is a Nuvoton NPCE586HA0MX.
    Any help will be greatly appreciated.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12710
    Originally posted by Wutru
    Hi guys,
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • Wutru
      • May 2024
      • 8
      • Netherlands
      Hi hoaca388, thank you for your reply, please see my answers in italic below:
      Originally posted by hoaca388
      (list of points)
      You MUST:
        • I have read this (very well written) guide and used it up to get to this point where I get stuck
        • I have tried the methods in this (very well written) guide and used it up to get to this point
        • I have succeeded with the methods in that (very well written) guide on another machine, the EliteDesk 800 G2 DM
        • But the EliteBook 820 G4 does not succeed as it behaves differently
        • I have used the search function extensively, but it is difficult to find threads only related to elitebook G4 models. It appears the search function ignores the G4 part
        • I have seen similar threads but they usually include CAPS Lock LED blinking or other symptons and totally different hardware models
        • I did not find sufficiently related threads to an HP Elitebook G4 (820/840/850) discussing problems (all I could find were just bios dump or repair requests) so I decided to open a thread
        • Product Number: Z2V91ET#ABH
        • Serial: 5CG8210XWC
        • GbE: 10:62:E5:4F:8A:96
        • I think I did this
        • See attached zip file with my dumps in this post
        • I have included:
          • Original dump
          • clean HP BIOS extract
          • my repaired BIOS by replacing BIOS region with UEFITool 0.28
        • I am hesitant to desolder the EC because it is surrounded by 0402 SMD resistors
        • When connecting power (battery or ext. power), the charging LED flashes white/amber (white/orange) for a few seconds.
        • Then it goes off for a few seconds, and now the Power, charging and WLAN LED turn on, the power button LED turns on, and after a few seconds the fan starts spinning to max speed
        • No video, black screen
      • hoaca388
        Badcaps
        • Jan 2022
        • 12710
        HP EliteBook 820 G4 Notebook PC
        • Wutru
          • May 2024
          • 8
          • Netherlands
          Thank you. Sadly, no improvements are noticed.
          I have included a dump of the EC.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12710
            New EC
            • Wutru
              • May 2024
              • 8
              • Netherlands
              Thank you. No improvements however - charging LED keeps blinking, with an extremely short blip of the power LED.
              Managed to fan spin once, but it went to max speed. No video or even impression of backlight turning on.
              Now it just it won't fanspin even and keeps at white/orange blinking
              I don't know how to proceed. I would not suspect hardware issues because the computer worked fine initially until I rebooted it after setting custom Secure Boot keys in Linux
              • Wutru
                • May 2024
                • 8
                • Netherlands
                I have ordered and received new Winbond chips for both the BIOS and EC, and reflashed them with the files in this thread.
                No improvement yet so it is not that I broke the chips with temperature.
                Can someone please double check the files? Maybe the BIOS got partially repaired by the EC (SureStart) but become damaged, then the EC got corrupted by the damaged BIOS?
                • Wutru
                  • May 2024
                  • 8
                  • Netherlands
                  Sadly I had another mishap with another G4 820.
                  I have included dumps of BIOS and EC ROMs
                  I would be very grateful if this machine could be restored.
                  Code:
                  Model: HP EliteBook 820 G4
                  Serial: 5CG820571S
                  MAC: 10:62:E5:4D:DC:E3
                    SMDFlea commented
                    Editing a comment
                    Thread merged.
                • Wutru
                  • May 2024
                  • 8
                  • Netherlands
                  New EC
                  Hi sir, can you please help me out? I'd be very grateful!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12710
                    Code:
                    Serial: 5CG820571S
                    • STKR123
                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                      by STKR123
                      Greetings badcaps community,
                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                      I learned that desoldering...
                      10-29-2024, 06:03 AM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • wrinex
                      bios request/fixing dump HP elitebook 840 G6
                      by wrinex
                      Hi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
                      i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...
                      04-09-2026, 12:39 PM
                    • Trademark
                      Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                      by Trademark
                      I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                      This is NOT a BIOS password removal request.
                      I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                      Laptop Information
                      • Model: Acer Predator Triton 16 PT16-51-99GL
                      • Motherboard: DA0ZQDMB8AE Rev. E
                      • Main SPI flash: Winbond W25Q256JVEN (32MB)
                      • Secondary
                      07-22-2026, 08:57 AM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
