SVOD4 NPCX997
Thank you James Bond, I have done what you say from 1 to 11 and I get error 20, when I ask SVOD4 Support they say "arm not answer" maybe there is differences on the circuit between T14 GEN 3- NM-E441 and T14 GEN 4-NM-F261 on the NPCX997 circuit on the schematic although they look similar although I see someone able to read it on NM-F261Comment
Attached FilesComment
OK, I'll read through the thread today and do it later and report back.
β
Sharing the latest version of Lenovo Golden Key I found to change DMI information such as serial number, MTM, UUID. Run the U1 application and create a bootable USB. It may show an older version upon making the usb. Restart the program and it will update the USB to the next version available. For some reason the updater programComment
by couillu76before you start the procedure read the bios eeprom and save it you might need it at the end
1do not power on your svod yet
2plug you ribbon 30x0.5 to the left of the keyboard connector
3test pin with testeur if it beep go to next stage
4 open svod software select 1.8v
5 now plug your svod
6 select nuvoton
7 plug charger on the board/laptop
8 press read id
9 select 256k
10 read nuvoton
11 save reading, now unplug the svod
12 open HxD software and open your 256k file the one you just saved
13look...-
Channel: BIOS Requests ONLY!
I can't read EC Npcx997, device not found
Can anyone help me?
Where did I go wrong or what else am I missing to read it?β
Lenovo T14 Gen 4
S/N :PF4YA55W
M/B : NM-F261 RE 1.0
Thank... -
by x16Hi,
I have a problem with a Lenovo L14 gen 2 (intel) with Nuvoton npce68b.
I connected my svod4 with a 32pin cable to the keyboard connector. Ground is also connected and power for the mainboard. I can read the Nuvoton ID, but the dump is always empty. Does anyone have an idea?-
by magicpcHello, is svod 4 able to read emmc? Do I need a special board or is it enough to solder into the pinout and insert the other side of the cables into the programmer? somehow especially set the svod?
by PfudanielHello, im trying to read the EC of lenovo NM-D271 butthe files come up empty after read.
Im using pinout provided from online database made by Adytia.
Pin detection is succesfull and i read in 384 size.
I was hoping to have some help to get the EC read succesfully. might be a pinout issue ? if anyone got more info on this id love to hear it.
Thanks.-
- Loading...
