SVOD4 NPCX997
    Originally posted by james-b0nd View Post
    13. Open the file with a HEX editor
    Click image for larger version Name:	HEX1.png Views:	0 Size:	119.2 KB ID:	3642181
    14. Fill the displayed area with 00
    Click image for larger version Name:	HEX2.png Views:	0 Size:	16.8 KB ID:	3642178
    clean 3e420 too
    try but not working because many repetitions
      I'd like to send you my original .bin file. Could you edit it completely for me?
      We have two layers here:
      3e320 and 3f320 (see images)
      I've already scoured the internet with the help of AI
      And there are many different methods for what needs to be zeroed out.
ID:	3642336 Click image for larger version
        Perhaps this guide will help someone who's just starting out.
        Thank you James Bond, I have done what you say from 1 to 11 and I get error 20, when I ask SVOD4 Support they say "arm not answer" maybe there is differences on the circuit between T14 GEN 3- NM-E441 and T14 GEN 4-NM-F261 on the NPCX997 circuit on the schematic although they look similar although I see someone able to read it on NM-F261
          Sorry I forgot to say that I can only get that error reading when I select motherboard, if I select Nuvoton and config I can't detect anything but when I select NM-F261 motherboard and read ID it will give me ERROR 20
            Originally posted by Maxpower3 View Post
            clean 3e420 too
            Click image for larger version  Name:	image.png Views:	47 Size:	321.3 KB ID:	3642310
            As soon as I reset the three numbers in the 3e420 line to zero, the supervisor password is activated again and I can't access the BIOS.
            What exactly did you do to make it work for you?
              try
                GREAT! Thanks Maxpower3.
                Now I can edit all the data in the BIOS.
                I still get the following messages at startup:
ID:	3644885 Click image for larger version
ID:	3644884 Click image for larger version
                  Click image for larger version  Name:	Messages.jpg Views:	0 Size:	137.1 KB ID:	3644885 Click image for larger version  Name:	BIOS-MainPage.jpg Views:	0 Size:	131.7 KB ID:	3644884 Click image for larger version  Name:	data.jpg Views:	0 Size:	88.2 KB ID:	3644883
                  use lenovo golden key for clean dump and restore your number after
                    If you can send a reading after the clean dump eprom on the forum, it will be useful to everyone, thank you.
                      OK, I'll read through the thread today and do it later and report back.
                      Sharing the latest version of Lenovo Golden Key I found to change DMI information such as serial number, MTM, UUID. Run the U1 application and create a bootable USB. It may show an older version upon making the usb. Restart the program and it will update the USB to the next version available. For some reason the updater program
                        B0 (8) SB21H32283L1HF34X00KA
                        C0 (1) S21CGS1D600PF4AFKP5
                        Model type ThinkPad T14 Gen 3
                          I can't get any further here
                          Click image for larger version  Name:	failed.png Views:	0 Size:	34.2 KB ID:	3644902
                          OK, just ignore step 2 and then click on "Update" and it will work.
                            OK, here's what I did.
ID:	3644934 Click image for larger version
ID:	3644933 Click image for larger version
ID:	3644932 Click image for larger version
ID:	3644931 Click image for larger version
ID:	3644930 Click image for larger version
ID:	3644929 Click image for larger version
ID:	3644928 Click image for larger version
                            I can't set the "C0"
                              Click image for larger version  Name:	A (2).jpg Views:	0 Size:	215.1 KB ID:	3644934 Click image for larger version  Name:	A (3).jpg Views:	0 Size:	178.1 KB ID:	3644933 Click image for larger version  Name:	A (4).jpg Views:	0 Size:	193.2 KB ID:	3644932 Click image for larger version  Name:	A (5).jpg Views:	0 Size:	144.8 KB ID:	3644931 Click image for larger version  Name:	A (6).jpg Views:	0 Size:	157.6 KB ID:	3644930 Click image for larger version  Name:	A (8).jpg Views:	0 Size:	166.2 KB ID:	3644929 Click image for larger version  Name:	A (7).jpg Views:	0 Size:	156.7 KB ID:	3644928 Click image for larger version  Name:	A (9).jpg Views:	0 Size:	150.1 KB ID:	3644927
                              C0 1S21CGS1D600PF4AFKP5
                              Click image for larger version  Name:	image.png Views:	0 Size:	75.3 KB ID:	3644946
                              And B0 must start with 8S I believe. I marked in parentheses
                              Did you clean the dump before rewriting the numbers?
                              It's better to start with a clean dump.
                              Otherwise you risk having errors.
                              Use the eeprom operations function.(5)
                                That worked
                                  He writes that he wrote the SN, but unfortunately, it wasn't written. What is the reason for this?
ID:	3645134 Click image for larger version
                                    Click image for larger version  Name:	2.jpg Views:	0 Size:	82.0 KB ID:	3645134 Click image for larger version  Name:	1.jpg Views:	0 Size:	238.5 KB ID:	3645135
                                    try with planar service
                                    what version of U1 (3.5.40)??
                                    try maybe last update
                                      I've now tried 3.5.75, and it shows me that the system is locked.
                                      At least I've gotten a few fewer error messages.
ID:	3645224 Click image for larger version
Name:	2 errors.jpg
                                        Click image for larger version  Name:	locked.jpg Views:	0 Size:	137.0 KB ID:	3645224 Click image for larger version  Name:	2 errors.jpg Views:	0 Size:	119.5 KB ID:	3645223
                                        USB key incorrectly formatted, use the usbmtpw utility and put files in the key after.
                                          Everything worked now!
                                          All error messages are gone.
                                          GREAT, thanks Maxpower3 😁
