Lenovo Thinkpad Ec Pwd Bypass
  • volinakis
    • Jan 2021
    • 2876
    • N/A
    #801
    Originally posted by Andromedus_81
    Thank you volinakis, it works — I can enter the BIOS, but for some reason I can't save any changes. I get the same message every time. I'm only having this issue with this model. Is it possible that the EC is write-protected?
    don't save anything, follow Maxpower3 steps:
    Don't save with F10, just clean Pwd with Enter twice. and reset security chip. Then restart with ctrl+alt+del
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1358
      • France
      #802
      Originally posted by Kakkoishonen
      Boss, the laptop finally worked!!!
      I flashed the 25Q128FV rom and it finally entered the BIOS menu!
      Thank you so much!
      It still has blue screen when windows is starting up but I'll try to install a new one and try Lenovo Golden Key
      just clean Pwd with Enter twice AND CLEAR SECURITY CHIP
      or try type a new password
      Then CTRL ALT DEL
      Formset Main 1247C8E8... Failed to save storage. System. Status:Write Protected.
      This message appears when you press F10, it's not necessary!
      MEC16 33/53/63.
      The timing is a bit annoying; you have to start shunt earlier.
      Each EC has a different timing.
      • Andromedus_81
        • Aug 2023
        • 67
        • United Kingdom
        #803
        Thank you very much, volinakis and Maxpower3. I don't know, I must have had brain fog and wasn't following the Maxpower3 steps. Everything works now — thank you so much
        • Andromedus_81
          • Aug 2023
          • 67
          • United Kingdom
          #804
          Then CTRL ALT DEL
          MEC16 33/53/63.
          One more problem with this Lenovo model: pressing Enter twice or entering a new password doesn't confirm that the password has been saved. After restarting the laptop, the password is still not removed.
          • volinakis
            • Jan 2021
            • 2876
            • N/A
            #805
            "AND CLEAR SECURITY CHIP"
            • Andromedus_81
              • Aug 2023
              • 67
              • United Kingdom
              #806
              I did that, but earlier there was no confirmation that the changes were saved when I pressed Enter twice
              • volinakis
                • Jan 2021
                • 2876
                • N/A
                #807
                what I can tell you for sure is that I didn't have problems in clearing passwords following Maxpower3 steps. And I used this method tens of times.
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1358
                  • France
                  #808
                  Which EC, ITE doesn't work sometimes.
                  Try Boot F12 with shunt and golden key. Delete eeprom
                  • Andromedus_81
                    • Aug 2023
                    • 67
                    • United Kingdom
                    #809
                    It saves when I press Enter—if I reset the CMOS jumper on the motherboard with the battery disconnected, before connecting the power adapter.
                    • Petrona
                      • Sep 2025
                      • 3
                      Maxpower3 Thanks for sharing ur knowledge!
                      It works on E14 gen 3 NM-D481
                      • azanwaqas771
                        • Feb 2019
                        • 50
                        • Pakistan
                        #811
                        hi everyone some know how make bios patch file for MEC1503 unlocking
                        • Andromedus_81
                          • Aug 2023
                          • 67
                          • United Kingdom
                          #812
                          Can you share your knowledge about which pin should be used?
                          • Petrona
                            • Sep 2025
                            • 3
                            This one
                            • Roma Gherasimciuc
                              • Sep 2024
                              • 23
                              • Chisinau
                              #814
                              Hi everyone, and thank you for sharing such info, its very helpful ! I have 10 units Lenovo x1 carbon Extreme 2th gen (9th gen cpu), can anubody share which pins should be grounded to remove bios password ? Tried this method on T490 and worked like a charm, but cant find any info about x1 carbon extreme 2th gen. Thank you !
                              • moljac
                                • Sep 2025
                                • croatia
                                #815
                                hello boss!i have lenovo l13 gen2 20vh.one request, please, does this method also work with an intel cpu? I've been trying for several days without success... thank you... it says entering setup and comes back to asking for a password again
                                • kicker12
                                  • Jul 2022
                                  • 21
                                  • Italy
                                  #816
                                  Hi!
                                  So, strange issue here...
                                  I got myself a very nice T490... But BIOS is (was?) locked... I THINK I have been able to delete the password: now I can enter BIOS with NO password... Anyway some parameters still greyed out: Secure boot and -for istance- reset to OS default are greyed out. All password are DISABLED... I CAN edit boot order...
                                  i.e. SECURE BOOT is now TURN ON and, being greyed out, I cannot turn it off. I tried to Restore Factory Keys, I tried to reset BIOS to factory settings but still cannot have SECURE BOOT turned OFF. It is actually on USER MODE (for Platform mode) and STANDARD MODE (for Secure boot mode), although I cannot change these parameters. Kernel DMA protection (in virtualization) is DISABLED. Also I tried to set up a BIOS password (both supervisor and system management) BUT Sexure Boot still active and greyed out... Grrrr....
                                  What is wrong here???
                                  • Usering
                                    • Sep 2024
                                    • 51
                                    Patching bios for unlock mec1503 and mec1723
                                    and USB2 Dongle directly unlock
                                    Is this thing real?
                                    Please, is there an explanation or someone to explain? Thanks
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1358
                                      • France
                                      #818
                                      Originally posted by Usering
                                      Is this a real thing unlock via usb?
                                      Mec1503 & Mec1723 ??????????
                                      I think it's possible. I've already heard about a USB solution. I don't know any more.
                                      Is this thing real?
                                      I don't have any information for you. Sorry, but I'm interested too.
                                      Also, stop asking me in private messages about MEC 17 or 15.
                                      I don't know. Never done it
                                      ​​ Click image for larger version  Name:	image.png Views:	0 Size:	9.6 KB ID:	3752959Click image for larger version  Name:	image.png Views:	0 Size:	10.1 KB ID:	3752960Click image for larger version  Name:	image.png Views:	0 Size:	13.0 KB ID:	3752961
                                      ETC ......
                                      Originally posted by Angry birds
                                      I even came to think that he knew what he was doing, that he was someone with a bit of intuition and talent. I am referring to MaxPower3.
                                      It bothers me to know that the people who perhaps you thought that contributed good things are the ones who contribute the least. and that when they do it they only transmit useless things.
                                      Advice, do not download file coming from Maxpower3 of you will infect your computer.
                                      Click image for larger version  Name:	bitcoin-cheers.gif Views:	0 Size:	3.65 MB ID:	3752962
                                      • zomi
                                        • Nov 2011
                                        • 513
                                        #819
                                        Some interesting times.. glad to see solutions have been done.
                                        I suppose sometimes u have to pay..
                                        but really great news.
                                        • rediii
                                          h???, spurrrn
                                          • Mar 2018
                                          • 504
                                          • somewhere in europe
                                          #820
                                          i don't think this is great. nothing changed...
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
