Wireless Router only works 'Wired'
  • B757
    replied
    Re: Wireless Router only works 'Wired'
    I rolled the drivers back a few generations and now it works fine, though I now lose WPA2. No big deal, WPA and a long password is good enough. Thanks!
    The thing has Lelons though, though I'm not particularly intent on pumping any money into this old thing. Also the general capacitors area is very cool so not worried at all.
  • digge
    replied
    Originally posted by B757
    I flashed my router's firmware (D-Link Di-624, sort of old but works) yesterday and now I'm getting this problem. Ethernet works fine, but internet on wireless drops on a regular basis - my wireless card talks to the router just fine but after about 10 minutes I get no Internet. I usually have to disconnect from the router and then reconnect, in which case it then works for another 10 minutes before Internet again gets dropped. This was not an issue before the firmware flash.
    FYI it is not overheating. I've already rigged a heatsink onto the hottest chip on the router's PCB and also over a really hot voltage regulator, and I've rigged an 80mm fan over it. It runs super cool now. No blown caps either.
    Really hot voltage regulator might suggest a bad walwart or bad filtering due to bad caps in router (don't quite remember what that router looked like inside). D-Link was notorious for bad power supplies back when the 624 was new (at least around here). So see if you can find another powerbrick around the house with the correct voltages and polarity and try that.
  • PCBONEZ
    replied
    Caps blow without bloating too.
    Roll back the firmware.
  • B757
    replied
  • Junk Parts
    replied
    I use a Westell Modem/Router. It has a home page on the net where I can go to change its wireless settings. Right now I have the wireless side turned off and no antenni installed on it. My new pc has wireless built into it and it hasn't picked up the Westell. I don't know if this is of any help to you but its how my junk works.
  • inuyasha.rules
    replied
    Originally posted by kc8adu
    +1
    i do not remember having ANY wrt54g series with hardware issues other than bad caps.and i have had 150+ go through my hands.they get caps,tomato or ddwrt,and i never hear of problems again except 2 that were hit by lightning.
    Caps just wernt big enough to handle the voltage spike or good enough esr. their hardware is so basic I've never had issues with it so I always say software. Ran a city wide wifi off a bunch and never had stability issues after we went ddwrt, other than the white collars scrapping it after we had everything running smooth
    Originally posted by weirdlookinguy
    Was moola shovenose?
    Once a troll always a troll, if it turns out they are the same person
  • weirdlookinguy
    replied
    I suspected it, same type of vague posts that add nothing to the conversation. That guy just will not quit.
  • Per Hansson
    replied
    weirdlookinguy; Topcat seems to think so yes:
    https://www.badcaps.net/forum/showth...545#post167550
  • weirdlookinguy
    replied
  • moola
    replied
    I prefer Netgear. But to each his own.
  • kc8adu
    replied
    +1
    Name one brand that is better while not being 10 times more expensive than the old venerable WRT54G series
  • Per Hansson
    replied
    Originally posted by moola
    Probably your first issue is that Linksys is junk...
  • lmcancu
    replied
    Basic question, but are you sure you have your wireless security settings set correctly on the router? WEP, TKIP, etc.
    As previous folks have said, wireless is less relaible than a fixed line and especially if you live in a multi-dwelling environment there will be many routers contending for the 3 channels (1, 6, 11) if you have a 2.4 GHz AP/router. Most default to channel 6 and stay there. If you have 802.11n support than some AP/Routers can use 2 channels. Also, for the co-existence aspect, the 802.11 standards define co-existence mechanisms (CSMA - Listen before talk), but not all AP vendors implement it the same way.
    You should be able to play with some of the wireless settings on your AP to see if its an interference or coverage issue. (i.e. you are too far away from the access point).
    1) Try changing the channel
    2) Try changing the security settings (both at the router and the client)
    3) Try fixing the AP transmit power (set it to maximum)
    4) Disable 802.11n, and use 802.11g
  • c_hegge
    replied
    ...Linksys is junk...
    They are the best IMO
  • moola
    replied
    But yeah try moving the antennas around.
  • digge
    replied
    My sister had a similar problem, all i did was tilt the antenna a bit so it was sitting in 45 degree angle and never happened after that. This is of course not a solution for everyone, just saying small things can make a huge difference.
    I doubt its due to channel, wireless networks are supposed to be able to coexist quite ok, you wont get full speeds but shouldn't disconnect.
    Another possibility is interference, like the Belkin HD Powerline adapters for example.
    http://www.youtube.com/watch?v=utfUEEhmHYY
    The same guy have a few videos explaining what happens when they are used.
    Last edited by Per Hansson; 08-16-2020, 04:00 AM. Reason: Correct spelling of Belkin
  • inuyasha.rules
    replied
    Its my belief that linksys uses some crappy algorithm to decide which antenna and thus which radio has the best signal. Try powering up with only one antenna. Or go the route I and a ton of others have and dump the crap firmware for ddwrt or openwrt.
    @retiredcaps 9 times out of 10 when I've dealt with this issue it was software. Installing ddwrt cleared it right up and made this router into a decent piece of midrange equipment at rock bottom price.
  • bp1
    replied
    Originally posted by jakdedert
    I've been reading the forum and wondered why this was so common, especially with Linksys products, but with others as well. Is this a common failure mode, or is it just me? If it's as common as I've found it to be, is there a common failure point, or are there multiple issues with different routers?
    For instance, I've had at least four Linksys routers, obtained from various sources, which failed to connect wirelessly, but which worked fine from the ethernet ports. Is Linksys unreliable, did I get bad ones (probable, considering my usual 'thrift store' acquisition technique), or is it just that they are so common that my scrounging finds them most often? Conversely, I've seen a couple work flawlessly for years.
    To reiterate; many routers I have obtained work 'wired' but will not connect via wifi. Almost always the router is visible on the air, and will apparently connect to a remote computer, but will not pass data. I've had professionals come in (as a favor) and in vain try everything possible to make a connection...cloning MAC addresses, different modes of connection, flashing BIOS etc.
    Some have failed after working for a time, others were obtained used and probably didn't work when I got them; while others were defective--brand new--right out of the box...various brands and models, but most often Linksys (although I've never had a brand-new Linksys fail out of box).
    If your wireless is failing the 1st thing to try is changing the channel in the router. Interference is most likely the cause of poor or very limited wireless connection. Do bear in mind that with most house holds now with wireless routers you will get some interference from their routers. I work a lot on installation of networks and the symptons you describe is nearly always resolved by ensuring you have the latest drivers for your wireless device and changing your routers default wireless channel.
    Kind Regards
    bp1
  • jakdedert
    replied
    Originally posted by retiredcaps
    Well, take one apart where the wifi doesn't work and post a clear focused pictures using the manage attachments button and please do not post inline.
    Thank you. This was more a general discussion question than a direct call for help, although I will eventually do as you ask. It seems odd that I keep having the same symptom across a variety of routers. Right now, using a Belkin that has been reliable after a BIOS upgrade.
    No reason to have two (the others were scrapped) defective Linksys routers--as well a couple other brands--laying around. Someone could probably use them. Thanks again.
  • delaware74b
    replied
    My 1.5 year-old Linksys WRT54GL did this last week. Wired side okay and no wireless. Unplugged the router for 15 minutes and it cleared itself up. I have a set of Panasonic FC's waiting to be installed if it acts up again. It has crap caps in it, waiting for a good time to change them out.
    RCA WHP141 wireless headphones wired up
    by momaka
    OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
    Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
    As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
    02-22-2023, 06:28 PM
  • double_DD
    Why does my ISP router hate my "homemade" power supply??
    by double_DD
    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
    07-12-2025, 03:09 AM
    HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 03:30 PM
    HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
