Why does my ISP router hate my "homemade" power supply??
  • double_DD
    • Mar 2024
    • 50
    • Croatia
    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof, as the charger cannot supply 5V, 12V and 20V in case I add more devices to it), I decided to create my own charger (x2) consisting of 20V PD trigger + 12V buck converter, so at the output I have 12V that both routers need. Charger provides 3A, buck converter has only 2A, but I've monitored the consumption of both routers and I haven't seen usage of more than 1A (per device), so power-wise everything should be OK. Each router receives 12V/2A and only uses around 0.6A, max 0.8A.
    So what's the issue? My router works perfectly, the ISP one is giving me a headache. In any combination of USB-C port, cable, and charger, my router always powers up and runs normally. ISP typically goes into "bootloop", where it restarts constantly (half a minute after starting the first LED goes to green, then they all turn red and router restarts, constantly). Every once in a while, it will start up normally and work for a couple off days, when we have this weird dance all over again. When I connect it back to mains adapter, it will boot properly the very first time. Plug is normal, 2-pin barrel jack of 6.3mm diameter, on both routers.
    So, does anyone have any idea why the ISP router hates my guts??? What am I doing wrong here?
    Any comment will be appreciated.
    Thank you!!
    ( I don't have a load tester or oscilloscope to check if there are some weird spikes in the output voltage or behaviour of my chargers under load, but my router works with any port, cable or charger connected, so they both probably work just fine)
  • CapLeaker
    Leaking Member
    • 8352
    Maybe the PSU doesn’t have enough filtering, not enough oomph, SMPS design, whatever…
    I powered modems and routers on a linear PSU before without any ill effect. Maybe show us your PSU, cables etc…
    • double_DD
      • Mar 2024
      • 50
      • Croatia
      Good questions.
      I don't know what's in the USB-C charger, but the rest are cheap AliExpress components on the attached pictures. Should I buy different buck converter, something with a few more capacitors?
      This is data from AliExpress for buck converter:
      Input Voltage: 5v~30v (Must Be Higher Than The Output Voltage) Preferably Below 28v.
      Output Voltage: 12v.
      Output Current: 3a (Max) Normal 1.8a Over Plus Heat Sinking
      Conversion Efficiency: 96% (Maximum)
      Output Ripple: 30mv
      Output Accuracy: ±0.1v
      No-Load Current: 1ma
      Operating Temperature: -40℃~+85℃
      Operating Humidity: 20%~90
      Annoying part is that it *sometimes* works, but usually not.
        • 31304
        high frequency noise is messing with the ADSL/VDSL signals
        and open your routers for a check, they often have rubish electrolytics in them that fail after a few years
        • double_DD
          • Mar 2024
          • 50
          • Croatia
          So, should I buy different buck converter, something with a few more capacitors? Would that help with the filtration? Or?
          I don't really wanna open it, it's working just fine with original mains adapter. If it dies, it will be replaced by ISP.
            • Jul 2011
            • 6070
            Or you might have to have more filtering capacitors to get a more efficient output supply plus I might even put a blocking device on each input but use a low voltage drop diode for this application
            • double_DD
              • Mar 2024
              • 50
              • Croatia
              Sorry, you went above my level 😀 If you have some schematic for me to build or a link to a product I can buy then i might be able to understand your point. i'm not this good at this hobby. 😀
                • 31304
                put some caps on the buck convertor output.
                preferably polymer or low-impedence electrolytics.
                maybe 470uf polymer or 1000uf electrolytic
                • double_DD
                  • Mar 2024
                  • 50
                  • Croatia
                  Thanks! Will try that!
                  • CapLeaker
                    Leaking Member
                    • 8352
                    Originally posted by double_DD
                    Good questions.
                    That this isn’t working right… I believe that.
                    So you got a power supply, then a buck converter going into the modem, in which has more buck converters inside? That’s inefficient and more of a cause something not good.
                    Next problem is that not all USB-C chargers are equal. Some of these USB-C chargers produce noise, ground loop, etc. they aren’t that clean. Also under load they drop voltage. Cabling becomes an issue as well. But this buck converter from Ali, has no real output filtering to speak of.
                    • double_DD
                      • Mar 2024
                      • 50
                      • Croatia
                      I mean, I do understand your concern, but realistically I'm not really that worried, after all we're talking about output power of <10W. Even if we exaggerate all the conversion losses, input power is still <15W. I certainly wouldn't use something like this to power something of 2kW.
                      Butt yes, lesson learned- it's never a good idea to buy the cheapest crap. I might try buying another buck converter from Ali with a few caps more, to see it's behaviour.
                      • CapLeaker
                        Leaking Member
                        • 8352
                        Look if you can fiddle with the PD charger to output 15V not 20v. Then you don’t need buck converters.
                        • double_DD
                          • Mar 2024
                          • 50
                          • Croatia
                          You don't think that both routers will mind 15V instead of 12V? Interesting...I might try that.
                          (I can get 12V on USB-C charger no problem, but the problem comes if I want to add more devices to charger, as it can't output 5V, 12V and 20V at the same time. I have a feeling it'll be exactly the same case with 15V.)
                            • Jul 2011
                            • 6070
                            You would not be able to do two different voltage at the same time as far as I know but you could use this device for more than one device but on the same usb power supply
                            https://www.ebay.com/itm/154199751911?var=454319125178
                            • double_DD
                              • Mar 2024
                              • 50
                              • Croatia
                              That was the reason why I went with this convoluted setup with using 20V PD.
                              I do generally also use this, but both routers use "non-standard" 6.3mm barrel jack which I hadn't found in this ready-made type. Thanks anyway!
                              • CapLeaker
                                Leaking Member
                                • 8352
                                I've got an older router here apart that was 12VDC fed. I looked at the 2 buck converters fed from the main power rail and one is max 16vdc input and the other is max 18vdc.
                                Set the PD to 15V, add a larger like a 3A to 5 A standard rectifier diode in series to drop 15V to 14.3V like a BY550 or HER503 or similar (to be more in tolerance) and bob is your uncle.
                                To be sure you'd have to open up the router and modem and check the datasheet on the buck converter or regulator right at the DC input section.
                                • double_DD
                                  • Mar 2024
                                  • 50
                                  • Croatia
                                  Thanks for the advice, it's much appreciated although this is going to be my "last resort", if I cannot get it to work any other way with 20V PD.
                                  • double_DD
                                    • Mar 2024
                                    • 50
                                    • Croatia
                                    So I did just that, I've put electrolytic 680uF/16V (all I currently have at home) on the buck output, and the router fired up on the first try! I'll of course monitor it over the next days/weeks, but this seems to be the solution (not surprisingly).
                                    Thanks again to everyone who contributed!
                                      • Jul 2011
                                      • 6070
                                      I am glad that fixed your issue with usb charger device
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                      • motormayhem
                                        Lenovo T460 Only Charges on One Charger
                                        by motormayhem
                                        Laptop Question
                                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                        05-12-2023, 01:46 PM
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                      • flat-earther
                                        how to prevent a connected charger from draining battery when not charging?
                                        by flat-earther
                                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                        So the battery is backfeeding the charger and being drained.
                                        How can I prevent...
                                        08-07-2025, 01:04 PM
