Wireless Router only works 'Wired'
  • jakdedert
    • Jun 2010
    • 19
    I've been reading the forum and wondered why this was so common, especially with Linksys products, but with others as well. Is this a common failure mode, or is it just me? If it's as common as I've found it to be, is there a common failure point, or are there multiple issues with different routers?
    For instance, I've had at least four Linksys routers, obtained from various sources, which failed to connect wirelessly, but which worked fine from the ethernet ports. Is Linksys unreliable, did I get bad ones (probable, considering my usual 'thrift store' acquisition technique), or is it just that they are so common that my scrounging finds them most often? Conversely, I've seen a couple work flawlessly for years.
    To reiterate; many routers I have obtained work 'wired' but will not connect via wifi. Almost always the router is visible on the air, and will apparently connect to a remote computer, but will not pass data. I've had professionals come in (as a favor) and in vain try everything possible to make a connection...cloning MAC addresses, different modes of connection, flashing BIOS etc.
    Some have failed after working for a time, others were obtained used and probably didn't work when I got them; while others were defective--brand new--right out of the box...various brands and models, but most often Linksys (although I've never had a brand-new Linksys fail out of box).
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Wireless Router only works 'Wired'
    Well, take one apart where the wifi doesn't work and post a clear focused pictures using the manage attachments button and please do not post inline.
    --- begin sig file ---
    --- end sig file ---
    • delaware74b
      • Apr 2009
      • 628
      My 1.5 year-old Linksys WRT54GL did this last week. Wired side okay and no wireless. Unplugged the router for 15 minutes and it cleared itself up. I have a set of Panasonic FC's waiting to be installed if it acts up again. It has crap caps in it, waiting for a good time to change them out.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • jakdedert
        • Jun 2010
        • 19
        Thank you. This was more a general discussion question than a direct call for help, although I will eventually do as you ask. It seems odd that I keep having the same symptom across a variety of routers. Right now, using a Belkin that has been reliable after a BIOS upgrade.
        No reason to have two (the others were scrapped) defective Linksys routers--as well a couple other brands--laying around. Someone could probably use them. Thanks again.
        • bp1
          • Jul 2010
          • 46
          If your wireless is failing the 1st thing to try is changing the channel in the router. Interference is most likely the cause of poor or very limited wireless connection. Do bear in mind that with most house holds now with wireless routers you will get some interference from their routers. I work a lot on installation of networks and the symptons you describe is nearly always resolved by ensuring you have the latest drivers for your wireless device and changing your routers default wireless channel.
          Kind Regards
          bp1
          • inuyasha.rules
            • May 2011
            • 43
            Its my belief that linksys uses some crappy algorithm to decide which antenna and thus which radio has the best signal. Try powering up with only one antenna. Or go the route I and a ton of others have and dump the crap firmware for ddwrt or openwrt.
            @retiredcaps 9 times out of 10 when I've dealt with this issue it was software. Installing ddwrt cleared it right up and made this router into a decent piece of midrange equipment at rock bottom price.
            • digge
              • Apr 2006
              • 296
              My sister had a similar problem, all i did was tilt the antenna a bit so it was sitting in 45 degree angle and never happened after that. This is of course not a solution for everyone, just saying small things can make a huge difference.
              I doubt its due to channel, wireless networks are supposed to be able to coexist quite ok, you wont get full speeds but shouldn't disconnect.
              Another possibility is interference, like the Belkin HD Powerline adapters for example.
              http://www.youtube.com/watch?v=utfUEEhmHYY
              The same guy have a few videos explaining what happens when they are used.
              Last edited by Per Hansson; 08-16-2020, 04:00 AM. Reason: Correct spelling of Belkin
              • moola
                Banned
                • May 2011
                • 20
                Probably your first issue is that Linksys is junk...
                But yeah try moving the antennas around.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Originally posted by moola
                  ...Linksys is junk...
                  They are the best IMO
                  • lmcancu
                    • Oct 2009
                    • 158
                    Basic question, but are you sure you have your wireless security settings set correctly on the router? WEP, TKIP, etc.
                    As previous folks have said, wireless is less relaible than a fixed line and especially if you live in a multi-dwelling environment there will be many routers contending for the 3 channels (1, 6, 11) if you have a 2.4 GHz AP/router. Most default to channel 6 and stay there. If you have 802.11n support than some AP/Routers can use 2 channels. Also, for the co-existence aspect, the 802.11 standards define co-existence mechanisms (CSMA - Listen before talk), but not all AP vendors implement it the same way.
                    You should be able to play with some of the wireless settings on your AP to see if its an interference or coverage issue. (i.e. you are too far away from the access point).
                    1) Try changing the channel
                    2) Try changing the security settings (both at the router and the client)
                    3) Try fixing the AP transmit power (set it to maximum)
                    4) Disable 802.11n, and use 802.11g
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Name one brand that is better while not being 10 times more expensive than the old venerable WRT54G series
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        +1
                        i do not remember having ANY wrt54g series with hardware issues other than bad caps.and i have had 150+ go through my hands.they get caps,tomato or ddwrt,and i never hear of problems again except 2 that were hit by lightning.
                        • moola
                          Banned
                          • May 2011
                          • 20
                          I prefer Netgear. But to each his own.
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            Was moola shovenose?
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              weirdlookinguy; Topcat seems to think so yes:
                              https://www.badcaps.net/forum/showth...545#post167550
                              • weirdlookinguy
                                • Sep 2007
                                • 1638
                                I suspected it, same type of vague posts that add nothing to the conversation. That guy just will not quit.
                                • inuyasha.rules
                                  • May 2011
                                  • 43
                                  Originally posted by kc8adu
                                  +1
                                  Caps just wernt big enough to handle the voltage spike or good enough esr. their hardware is so basic I've never had issues with it so I always say software. Ran a city wide wifi off a bunch and never had stability issues after we went ddwrt, other than the white collars scrapping it after we had everything running smooth
                                  Once a troll always a troll, if it turns out they are the same person
                                  • Junk Parts
                                    Court Jester
                                    • Jun 2006
                                    • 8953
                                    I use a Westell Modem/Router. It has a home page on the net where I can go to change its wireless settings. Right now I have the wireless side turned off and no antenni installed on it. My new pc has wireless built into it and it hasn't picked up the Westell. I don't know if this is of any help to you but its how my junk works.
                                    Mark Twain
                                    John Paul Jones
                                    Rod Serling
                                    • B757
                                      • Jul 2011
                                      • 10
                                      I flashed my router's firmware (D-Link Di-624, sort of old but works) yesterday and now I'm getting this problem. Ethernet works fine, but internet on wireless drops on a regular basis - my wireless card talks to the router just fine but after about 10 minutes I get no Internet. I usually have to disconnect from the router and then reconnect, in which case it then works for another 10 minutes before Internet again gets dropped. This was not an issue before the firmware flash.
                                      FYI it is not overheating. I've already rigged a heatsink onto the hottest chip on the router's PCB and also over a really hot voltage regulator, and I've rigged an 80mm fan over it. It runs super cool now. No blown caps either.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Caps blow without bloating too.
                                        Roll back the firmware.
                                        Mann-Made Global Warming.
                                        - Dr Seuss
                                          RCA WHP141 wireless headphones wired up
                                          by momaka
                                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                          02-22-2023, 06:28 PM
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                          HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 03:30 PM
                                          HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
